Old 21st June 2004, 20:49   #1
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
IATS kit installed, now ses light!
I had an enjoyable father's day playing in the garage. I installed my UF motorsport IATS relocation kit, and ran some ducting from the foglamp area to the airboxes. I put the temp sensor in the intake to the pass side airbox. The car runs fine, doesn't really seem much different, but it was around 70 deg. F when i took a drive this am. After maybe 20 miles, i got the SES light. I got home and checked the code, and i get code 29, table 18 which is "mafs cyl 1-4". Now this is where the stock iats is located right? I'll go back and check my wiring connections, but could there be something else wrong with my work? If i was not getting a signal from the new iats, would the car be running ok?
Thanks for any tips.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 21st June 2004, 22:36   #2
Need4Spd
Need4Spd's Avatar
Re: IATS kit installed, now ses light!
Yet another reason why my procrastination is good! Sorry to hear about this, Mike. My IATS kit is still on a shelf in my garage, and now until I find out what happened to you, will stay that way for a while longer! Now that you've done the Dinan suspension with great results, however, I guess there's no reason to wait on that any longer (except convincing my wife). I figure if I can delay things long enough, your car/experiences can be my test mule!
Need4Spd
Need4Spd is offline
Old 21st June 2004, 22:45   #3
XrayMD
XrayMD's Avatar
Garage: LeMans Blue M5,Silver X5 & Dk. Silver Mini S
I'm guessing something was wired wrong or there's something that is wrong with the MAF (doubt it). I have not heard of anyone getting an SES light after installing the IATS relocation kit.
Steve
'02 M5 LeMans Blue:
Supersprint Headers and cats
Dinan Stage III suspension
BeastPower sway bar brackets
Dinan front strut tower brace
RMS short shifter
Llumar window tint (35%)
XrayMD is offline
Old 21st June 2004, 22:52   #4
2003 M5!!!
2003 M5!!!'s Avatar
Garage: 2003 Silver M5
I read this recently . . . .
khoality,
I did back to back dyno's with and without the IATS installed and did get good increase with it in the brake duct. My installer did say that when he did the install the instructions left out a ground to the ecm that caused a check engine light, Which the engine was running way to rich. He referenced a bmw manual that showed the ground needed to be connected witch was done to correct the problem. The tech did mention that there has been several revsion changes to that harness starting in 2001, I have a early 2002.
Just some food for thought
Silver 2003 M5
GC Coilovers by Shadowman
Supersrint Headers by Shadowman
Supersprint X-Pipe
Dinan Exhaust
Shadowman Software
IATS by Shadowman
AA Cold Air Intake
Dinan Rear Sway Bar
Dinan Front Strut Bar
B&M SSK
DSSR
Power Pulleys
SSR GT3s - 8.5 & 10 x 19 w/ SO3s & 285s in Back
View My Alien Technology Project!
2003 M5!!! is offline
Old 22nd June 2004, 00:16   #5
mottati
mottati's Avatar
I looked for the uf motorsport web site, i can't find a working link for them! I checked my connections, everything looks good. I reset the SES light so we'll see what happens. The install instructions are pretty straight forward, the wires in the dme were easy to find. One thing that did come up, the ufm instructions say there will be 3 connectors going into the dme, mine had five. After a search on this board, others have posted that they had 5 too, and used the third from the drivers side, which is also what the ufmotorsport instructions say. There it was, the blue/yellow wire in the correct pin # and the brown in it's correct pin number.
One question, would the car run normally if the iats was bad, lets say i got a bad sensor or something? I'll go drive the car a bit and see if that light comes back on. Again, it seems to run fine.
mottati is offline
Old 22nd June 2004, 02:08   #6
mottati
mottati's Avatar
khoality,
Thanks for the input 2003, i came across this too on a recent search to see if anyone has had problems like this before. I really don't see where this 'mystery ground' is, there are only 2 wires, and one is a ground (the brown wire, i believe). At any rate, i drove another 15 or so miles, no ses light, but my peak reader still refers me to table 18, code 19 which is airflow sensor, cyl 1-4. Interestingly, there is a different code for iats, which puzzles me a bit. I'd think i would get that code. I may try swapping the right and left mafs to see if the code goes to cyl 5-8, or stays at 1-4.
Still open to ideas though! I'm going to go recheck my wiring again.
mottati is offline
Old 22nd June 2004, 03:40   #7
bluemax
bluemax's Avatar
Garage: 2002 m5 lemans blue
mottati ,
I can give you the tech's name at north scottsdale bmw that figured out the ground problem with my car, He did mention the instructions were not that complete.
Robert
2002 Lemans Blue/Silverstone( SOLD )
B&B Tri-flows with SS X Pipe
Rogue Octane SSK & WSR
Royal Purple & Rogue Trans Mounts
Dinan Stage 2 Software
Dinan Stage 3 suspension
Dinan Front & Rear Strut Braces
Mintex Dustless Pad's
UFMotorsport IATS Relocation Kit
2004 SRT-10 Silver (R.I.P. 12/18/04)
96 Dodge Viper GTS
07 Mercedes E63 (R.I.P. 12/28/07)
bluemax is offline
Old 22nd June 2004, 04:00   #8
mottati
mottati's Avatar
Originally Posted by bluemax
mottati ,
Robert
I may take you up on this Robert, i just don't see why it hasn't been an issue with others before. I went back in and rechecked all of my connections. I checked with an ohmmeter for resistance from the correct (per instructions) pin #22 and 17 to the connector at the new iats. The connections all seem good. The one thing that just doesn't seem right to me is that i'm getting and "airflow sensor cyl 1-4" code, not an iats code. Just for fun, i swapped my right and left side mafs. It's a longshot that a mafs went bad, but i figure if i did something wrong with the wiring, i should still get the same code. If the mafs is bad, i should get the code for cyl 5-8, then it's just a simple matter of a new mafs. If all else fails, i'll put it back to stock. Does anyone know what the correct resistance is for the iats? Maybe the sensor i have is bad?
What i've learned.... 1. always check for codes before doing any dme related mod. 2. do one mod at a time. (i added some ducting from my airbox ducts to the foglights, making a pseudo ram air intake. Maybe i'm getting some funny airflow that's confusing the mafs. If i still get a code, i may pull this out tonight). At any rate, it is mildly fun to troubleshoot... i'm getting some quality garage time...
mottati is offline
Old 22nd June 2004, 04:44   #9
M5 Fever
Garage: 2003 M5 Le Mans Blue w/Caramel
For what it' worth, I installed mine per the UF instructions and have had no problems. I haven't seen posts of others with this relocation that have any problems either. My guess it's a coincidence and the SES code is generated from something else.
good luck getting to the bottom
al
M5 Fever is offline
Old 22nd June 2004, 06:25   #10
Need4Spd
Need4Spd's Avatar
BTW, where's the best place to get a Peake reader/reset tool? I think it's time to get one, esp. before messing with my IATS.
Need4Spd is offline
Can an un-reset Service Indicator cause intermittent SES light? greg E39 M5 and E52 Z8 Discussion 15 8th May 2004 06:01
Has anyone installed Brembo brake kit behind the Softlines? vinvin ALPINABoard.com | BMW Alpina Discussion 0 22nd April 2003 08:45
StopTech E39 4-Wheel brake kit details DZeckhausen E39 M5 and E52 Z8 Discussion 26 20th March 2003 07:11
Has anyone installed a Light Weight Flywheel? sgalaba E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 0 7th February 2002 17:24
Help: SES light on! jinferno E39 M5 and E52 Z8 Discussion 1 18th November 2001 10:03
Page generated in 0.15944 seconds with 11 queries
