I. History and Background
Most of you know I have just installed a Ground Control coilover kit optimized for mostly street but also some track days. The biggest benefits to me are a more "sure" feeling and much more even tire wear thanks to the front adjustable camber plates.
There are a few other threads here showing what my car looked like after installing the setup, and today I was able to fix the ride height (well, almost, see below) and get the car aligned for both street and track. Here they are:
Fun with coilovers (AKA "Slammaroni") - [PICS] - posted 10 June 2004
M5 Ground Control Kit (Slammaroni Part II) - posted 13 June 2004
II. Technical Details of the Kit
The GC setup consists of 350/315 Eibach springs, coilover sleeves with custom GC perches, Koni adjustable shocks (difficult for the rear, but easy for the front), GC custom rear shock mounts, and GC custom front camber plates. The plates allow you to get anywhere from -2.2 to -2.8 degrees of camber depending on several things, including factory tolerances and ride height. You can discuss your requirements with the GC crew and they may tweak the spring rates for you.
III. Details on My Installation
A. Ride Height Discussion
My final ride height, as measured from the center of the plastic "roundel" on each wheel to the bottom edge of the fender lip, is 13.5" on the front wheels and 13.0" on the rear wheels. This retains the stock "rake" of 0.5" higher in front. This was also recommended by GC. For reference, the stock ride height settings according to the alignment shop's information, as measured from the lower edge of the wheel lip to the bottom edge of the fender lip is 23.8" front and 22.8" rear.
I specified my GC setup to be stock ride height, but when I went to adjust the rear ride height, I was only able to get 13.0" as shown above. Jay at GC recommended that I check something out to see if they made an error of if they assembled my setup wrong as there should be a lot more adjustment left at this ride height, but on my car there is not - the sleeve is as far down as it will go and there are no more threads showing above the perch collar.
My concern lies mainly with track driving - with this setup I have I asked Jay at GC about possibly contacting the bump stops too frequently at the track and he stated that this ride height was perfectly fine and that while I may hit the bump stops in a few places at the track, it should be very few and not frequently. He says GC added more suspension travel than the stock suspension has, and that even the stock suspension will hit the bump stops (he says it was designed to do that from BMW) occasionally. As an aside, this ride height necessitates some preload on the springs even at full droop, but I was also told that this is normal.
Based on his recommendation I am going to leave the ride height as it is right now and take the car to the road course this weekend and drive it in the instructor group and see how it feels.
B. Alignment
The "before" numbers don't matter so much, because we just installed an entirely new suspension. With the current ride heights mentioned above, the current settings are as follows (we put weights equivalent to the average weight between me and my wife and one other passenger in the passenger seat up front and equivalent to 3/4 tank of gas in the rear):
FRONT, STREET
Camber, L: -1.5 deg
Camber, R: -1.6 deg
Caster, L: 6.2 deg
Caster, R: 6.4 deg
Toe, total: 0.14in
REAR, STREET
Camber, L: -1.7 deg
Camber, R: -1.9 deg
Toe, total: 0.07in
FRONT, TRACK
Camber, L: -2.2 deg
Camber, R: -2.2 deg
Caster: not recorded
Toe, total: -0.10in
REAR, TRACK
* Same as street settings *
NOTE: The settings for front toe are made on the tie rods which happen to be behind the axle, meaning that when you add additional negative camber by tilting the tops of the struts inward using the camber plates, you add even more positive toe out. To remedy this, I need to mark each tie rod and give it one full turn to pull the toe back to slightly negative for track use, then back again for the street.
C. Tire and Wheel Clearance
So far I have tested three different tire and wheel combinations on the front and here are the results of each:
1) BMW 8.5x18 M5 wheel with 245/35/18 Michelin Pilot Sport tire: plenty of tire to shock clearance. No fitment problems.
2) BMW 9.5x18 M5 wheel with 275/35/18 Toyo T1-S tire + 3mm spacer: 1-2mm of tire to shock clearance. Slight rubbing during some turning (seen on the shock but never felt or heard in the car). Main problem is that the T1-S has a thick protruding rim protection bead sticking out of the side, causing slight clearance issues.
3) BMW 9.5x18 M5 wheel with 275/35/18 Toyo RA-1 tire + 3mm spacer: 3-4mm of tire to shock clearance. Although the section width of this tire is wider than either a Michelin Pilot Sport or Toyo T1-S street tire, it has no rim protection bead, and thus ends up with more clearance than the street tire. I plan to check for rubbing soon, but did not feel or hear any during the 20+ mile drive home including some spirited driving.
So far I have tested two different tire and wheel combinations on the rear and here are the results of both:
1) BMW 9.5x18 M5 wheel with 275/35/18 Michelin Pilot Sport tire: plenty of tire to shock clearance. No fitment problems.
2) BMW 9.5x18 M5 wheel with 275/35/18 Toyo RA-1 tire: plenty of tire to shock clearance. No fitment problems.
IV. Driving Impressions
A. Street Driving Impressions
So far, I can say that there is much less body roll. The car feels more sure-footed on all types of pavement. Despite the loss of about 0.75-1.00" of ride height, the ride quality suffers very little. The trade-off of a bit of ride quality is well worth the improved feel and handling. The additional front camber brings the neutral feeling back to the car. The rebound over harsh road imperfections is stellar. There is no cyclical bouncing up and down after going over large bumps - the car just rebounds and "sticks" there. I feel even more confident pushing it into, through, and out of corners than before.
B. Track Driving Impressions
Coming 21 June 2004!
V. Pictures
Click each picture for a 1600x1200 view. Larger ones are available if you e-mail me. Pictures taken with track wheels/tires mounted (BMW 18x9.5 wheels all around with Toyo RA-1 in 275/35/18 size all around and +3mm spacers up front).
Side view, normal level:
Side view, ground level:
Rear quarter view, normal level:
Rear quarter view, ground level:
Driver's side "along the car" view, taken from rear:
Driver's side "along the car" view, taken from front:
