I think I fixed my sticking CD changer - BMW M5 Forum and M6 Forums
Old 20th December 2014, 17:16   #1
drfeelgood
drfeelgood's Avatar
Garage: 2002 BMW M5 Black
I am 4th owner of a 2002 M5. I've owned it for a few years and the audio is still the stock M audio with 6 disc Alpine changer. Being a bit "old school", I have tons of CDs and still listen to them at home and in most of my vehicles.
Like many on here, I have experienced periodic jamming of the disc changer. Usually, a good swat on the changer would get it working again, but it would always jam again. Even had a to stick a small screwdriver down in changer a couple times to loosen a stuck CD and tray.(I know, probably not smart). This last time, nothing was working, so.......
I pulled out the changer and disassembled it, taking off case(small Phillips head screws and some finagling). I couldn't see anything in the mechanism obviously broken or out of place. I was able to push the tray and stuck CD back into the cartridge and noted that small amounts of what looked like lithium grease were used at some friction points. There are numerous sliding friction points, pivots and gears in the mechanism,incliuding slots in the inner metal case, so I lubed them all with fresh lithium grease.
So far, so good, with no malfunctions. Maybe the various friction points get dry and stick, causing malfunctions?
Just a thought. Will let you know if it recurs.
drfeelgood is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to drfeelgood For This Useful Post:
monsstr (22nd December 2014)
Old 21st December 2014, 07:57   #2
blbainb
Garage: M5 Black
Good information (and I have a bunch of old CDs as well). I have a 2002 M5 and had the same problem happen once. I was able to get it loosened up (but didn't relubricate everything) and now I make a habit of cycling through different CDs when I drive. No recurrence so far but I'll probably have to follow your lead if it happens again.
blbainb is offline   Reply With Quote Quick reply to this message
Old 22nd December 2014, 14:43   #3
monsstr
monsstr's Avatar
Garage: 2000 M5 silverstone
Its funny as I take everything else apart on my car, you would think that I would have thought of this by now. LOL
Thanks for sharing...yet another winter project.
monsstr is offline   Reply With Quote Quick reply to this message
Old 23rd December 2014, 05:26   #4
skulls7474
Garage: 2000 BMW M5
Great Idea
Not sure why I never thought to do this..mine worked fine for first two years..then recently started acting up and not reading. So I did the same removed unit and cleaned and regreased lubed. So far o.k. Hopefully it lasts for a bit.
skulls7474 is offline   Reply With Quote Quick reply to this message
Sticking Thermostat.. rennteknik E39 M5 and E52 Z8 Discussion 21 26th June 2012 22:32
Odd Tube Sticking Out M-att E60 M5 and E61 M5 Touring Discussion 4 25th November 2008 20:58
Fixed my CD changer...............for now M5at E39 M5 and E52 Z8 Discussion 3 12th November 2007 06:00
rear brake sticking doc_76544 E34 M5 Discussion 4 11th April 2006 08:10
Sticking throttle? Jim Lamb E39 M5 and E52 Z8 Discussion 6 22nd February 2002 07:52
