Old 5th May 2001, 00:21   #1
stever
Post 996 turbo spacesaver spare
I finally found the measurements I took from Greg's spare last November. It looks like it will work but it's not entirely simple.
The Turbo has about the same weight on the rear as the M5 on the front and the inside diameter of the Turbo spare wheel is about the same as the inside of the M5 wheel (although the Turbo spare is a 165/70-16, the wheel doesn't have a drop center) so brake clearance is fine.
But of course the bolt circle is different (Porsche 130mm, BMW 120mm) so a wheel adapter is required. The adapter is a little over 1 inch thick which is okay since the BMW front tire is 1.62 wider on each side than the Turbo spare (which also has less positive offset than the M5, .40in.vs .78in.). Clearance is okay, but with the spacer the Turbo spare on the front will have a .6 NEGATIVE offset which will affect steering --- but having a space saver on one side will anyhow and we're talking 50mph max for 50 miles as I recall (Greg, is that right?)
The one dimesion I don't have is the overall diameter as stored deflated (I think it's about nineteen inches -- Greg, could you check this also). The width is 6.2 inches for a volume of .8 cubic feet -- this is less tnan 1/3 the volume of the BMW front wheel/tire assembly.
Now the bad part. Porsche wants $565 for the wheel and tire assembly P/N 99636205000 (Wheel Enchancement in LA will knock 10% off this).
The spacer is $65 (+8% CA tax in CA) +$25 shipping prepaid by check or money order to
Design Deluxe Mfg.
21300 Deering St.
Canoga Park, CA
91304
To mount the spare, you bolt the spacer on with the M5 wheel bolts, then put the spare on with lug nuts (the lug nuts are supposed to fit the BMW lug wrench, but I can't swear to it --the spacer has studs on the Porsche pattern) --and you blow up the spare with you handy M5 pump. Of course you need a jack (which will fit inside the Porsche wheel) and a lug wrench.
Does anybody have a better idea before I spend $600+?
I tried the M5 front wheel as a spare and it really does chew up the trunk room. Driving without a spare is nervous making in areas many miles from service with no cell coverage.
stever is offline
Old 5th May 2001, 02:25   #2
greg
greg's Avatar
Garage: 2000 Anthracite
Post
Steve - I just went outside and measured it. The outside diameter of the collapsed Porsche spare is about 20 1/8"
/Greg
greg is offline
Old 5th May 2001, 18:08   #3
stever
Post
Thanks, that makes the volume about 1.13 cu ft, saving 1.3 cu ft over the M5 front wheel and tire. That's a pretty expensive 1.3 cu ft.
stever is offline
Old 10th April 2008, 01:31   #4
Panos
Panos's Avatar
Garage: 1999 540i 6-speed Biarritz Blue/Sand Beige
Is there a cheaper solution that this for a space saver spare tire?
Panos
1999 540i.6 Biarritz Blue/Sand-Beige
M5 Grills, 17" Staggered Radial Spoke Style 32 Wheels, M5 Rear Stabilizer Bar, Rogue Transmission Mounts, Rogue Short Shifter & Wieghted Selector Rod, CDV Deleted, Stop Tech Stainless Steel Lines, Dinan Engine Software, Bluetooth Telephone, Valentine One Radar/Laser Detector, StealthOne Interface, Debadged.
R. I. P.
2002 M5 Carbon Black/Caramel
Retired: 1997 540iA, 1994 540iA
Panos is offline
Old 10th April 2008, 16:09   #5
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Try ebay, I paid a LOT less than $600....
gsfent is offline
Old 10th April 2008, 19:26   #6
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
i'm not sure if the above from 2001 was ever proven to work? Most of us use an old front wheel and tire. Alternatively, you could find a bmw style 66 wheel which is 17", so a bit smaller and potentially cheaper. A few other 17" wheels can fit as well.
I only use mine when i'm taking a trip, otherwise it sits in my garage.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 10th April 2008, 21:08   #7
Panos
Panos's Avatar
Was hoping for a space saver to.... save trunk space. i dont really want a full size in the trunk, since there is not a wheel well for it.
Panos
R. I. P.
Panos is offline
Old 10th April 2008, 21:19   #8
Jack Fishman
Jack Fishman's Avatar
Garage: 2003 Alpine M5 & 1972 2002 Tii Inka
I had Art Spence of Motorsport Technology - 714-553-3910 make me a custom spacer to go along with a Mercedes donut spare tire he supplied. It is considerably less than $600. I use elastic tiedowns in the trunk to hold it in place.
DINAN Stage 1 suspension, Intake, Exhaust, MAFS, Stage 3 software and Short Shift.
UMNITZA headlights, HID fogs and backup lights
AGLA steering wheel and arm rest
KENWOOD DNX 7100 &
assorted European goodies and a SPARE tire
Jack Fishman is offline
Old 10th April 2008, 21:42   #9
gsfent
gsfent's Avatar
Alternatively, you could find a bmw style 66 wheel which is 17", so a bit smaller and potentially cheaper. .
Hmm, assuming you don't change the rolling diameter, wouldn't the overall package size be the same? Smaller wheel, but slightly taller tire to stay around 25.7 inch rolling diameter. I guess the package could be narrower.....
gsfent is offline
Old 11th April 2008, 00:03   #10
Panos
Panos's Avatar
Thats what I am thinking. Keeping it narrow, would be nice so you still have trunk space.
Panos
R. I. P.
Panos is offline
HELP: Which turbo to buy? 996 TT? X50? GT2? Cerberus Porsche 911 Turbo and Porsche Panamera Forum | panameraboard.com 23 29th April 2004 16:59
Old Porsche (993 C4) vs New Porsche (996 Turbo) Porsche 911 Turbo and Porsche Panamera Forum | panameraboard.com 8 8th March 2003 13:09
97 993 Turbo vs 2002 996 Turbo pdiack Porsche 911 Turbo and Porsche Panamera Forum | panameraboard.com 5 3rd March 2002 23:13
Page generated in 0.15311 seconds with 11 queries
