Motor oil coating the air intake system! - Page 2 - BMW M5 Forum and M6 Forums
Old 19th May 2004, 08:16   #11
V-10 4 Me
V-10 4 Me's Avatar
Garage: Lambo
Re: Motor oil coating the air intake system!
That looks messy. i hope the dealer cleans up everything...
V-10 4 Me is offline   Reply With Quote
Old 19th May 2004, 08:59   #12
jeeperjohn
Garage: 2002 BMW M5 Titanium Silver
Dave,
I don't think it is a ring problem since the problem showed up suddenly, more likely the vents or seal issue that JJ mentioned. You can have the dealer check the crankcase pressure to see if the vents are plugged. Did you have oil leaking from the oil fill cap?
John
Originally Posted by DaveK
Thanks for clearing that up, John. It makes a lot more sense to me now.
Hopefully that's not it, bad rings would be a worse problem than the issue JJ had. I'll suggest that the dealer do a compression test. I'll let you all know what they find.
- Dave
2002 M5 titanium silver
19701/2 Chevrolet Camaro SS396/375 HP
1973 Chevrolet Z-28
1986 Jeep CJ-7
1960 Willys CJ-5
1946 Willys CJ-2A
jeeperjohn is offline   Reply With Quote
Old 19th May 2004, 10:31   #13
DaveK
DaveK's Avatar
Garage: Looking for a used M5
Originally Posted by jeeperjohn
Dave,
John
John,
That's reassuring. Hopefully you're right about it not being a ring problem.
One of the pictures I took shows the cap. It looks like some oil may have leaked, but it's not too bad. It's hard to tell if it leaked or if some was spilled when they filled it and didn't clean it up completely. I'd take a closer look but the way it's parked in the garage I'd have to pull it out and I'm too lazy to do it this late.
Ocean-Side,
If it has anything to do with overfilling or a warrantee issue I would hope that they would clean it up. They ought to replace at least the one filter it leaked on as well. It's a K&N though, and I doubt they would replace it with another K&N. I was contemplating putting stock air filters back on it anyway. And the MAFS will definitely need cleaning now.
- Dave
DaveK is offline   Reply With Quote
Old 20th May 2004, 05:54   #14
jaj
jaj's Avatar
Garage: 2008 M3 Coupe Space Grey
DaveK
My 2001 had 3,000km when I got it.
There was no damage at the time, and the MAF's never did fail, but later in life I had more codes and the VANOS actuator was replaced, and then I had more codes and a cam sensor was done. That's one reason I'm driving a brand-new (16 months ago) 2003.
The dealer master tech blamed the original O-ring problem on overheating of the cylinder head, but I don't know if that's credible. He did show me the O-rings and they were hard and cracked (as opposed to nice and soft), but I'm not sure that wouldn't be normal after use.
Cheers
JJ
Thanks, JJ. This sounds promising. Was there any damage? Did they replace the MAFS because of potential fouling, or anything else?
I got an SES light a few weeks ago and went to the dealer. They found that there were codes still there from when the car wasn't passing smog and the cats were replaced (the other dealer forgot to reset the codes), so they cleared them and said to come back if it came on again. That's when I had them change the oil. I think the SES was related to the emissions problems because the codes were for cats & exhaust sensors. The SES light hasn't come back on, but if this continued much longer and soaked the filters and MAFS more I bet it would.
- Dave
jaj is offline   Reply With Quote
Old 22nd May 2004, 02:12   #15
DaveK
DaveK's Avatar
Update
Thanks to everyone who responded. Here's an update:
I brought the car to the dealer on Wednesday afternoon, and they finally had a diagnosis today. It's the same problem JJ had, a failed O-ring on the VANOS system. They ordered the part and expect to have it Monday. They said they cleaned up the oil, but didn't indicate that any damage was done. They said they didn't think the oil got up into the sensors on MAFS, just in the bottom of the housing tube.
They also advised me to replace the K&N filters with stock ones or any future problems with the MAFS may not be covered under warrantee because of the known issues with K&N oil fouling them. I plan to get stock replacements when I pick up the car, and give the MAFS a good cleaning. Do the K&Ns really do much for performance on this car anyway, before they foul the MAFS that is? Are there any alternatives that flow better than stock ones but aren't oil coated?
- Dave
Old 22nd May 2004, 02:32   #16
V-10 4 Me
V-10 4 Me's Avatar
Garage: Lambo
Dave--->Maybe you could ask the tech why the O-Ring would fail and what are the likely causes...
I wonder if it's possible oil aditives or chemically caused, or because they were pinched during install or if they could have gotten weak over time?
Old 22nd May 2004, 03:01   #17
gra8fuldd ed
gra8fuldd ed's Avatar
Garage: 2003 M5 Carbon Black w/Imola Red
Re: Update
- Dave
Dave ...
To answer your question ... It is a 2-fold answer answer ... Yes the K&N filters add a little to performance IF for no other reason than they allow "More AirFlow" than the stock paper filters ... Thise are a complete waste.
IMHO ... The best all around is the Dinan CAI with the Larger Air Flow meters. My reasoning is primarily this ... WARRANTY is STILL VALID if the DINAN work is done at a BMW-Dinan Dealership. All of my Dinan work has been done at a BMW-Dinan Authorized Dealership and my BMW warranty is entact ... 100%!!
To me ... That right there is worth the price of admission!
No strange looks from leary Service Managers ... no "What the Hell is that?" type of discussions ... NO "Let's see what other mods this guy has" ... No Problems ... Just Yes Sir and Thank you very much for having your work done here. I just had BOTH CATS replaced under warranty. I suppose it's possible that the Tubi exhaust ... with less back-pressure ... helped the CATS gets mucked up and clogged ... BUT ... So far ... In 1.5 years of ownership ... Everything has been repaired under warranty.
gra8fuldd ed is offline   Reply With Quote
Old 22nd May 2004, 05:07   #18
DaveK
DaveK's Avatar
Re: Update
Originally Posted by gra8fuldd ed
Dave ...
Thanks for the advice.
Are you saying that K&Ns alone are a complete waste, or the stock paper filters are? It wasn't clear to me.
I already have the AA CAI kit, which came with the K&Ns (I think - the previous owner had it put on). I suppose I could add Dinan's larger MAFS to it, but I'd rather not spend the money on those since even in combination with Dinan's CAI kit and higer flow exhaust it only gives 6 more peak HP. Does the Dinan kit come with K&Ns? If so, are their MAFS made to handle the oil?
I also got both cats replaced under warrantee recently when it wouldn't pass smog. Luckily they didn't give me a problem with the AA CAI or K&Ns. Also, it was obvious that my current problem wasn't caused by those.
Ocean-Side: When I pick it up I'll ask them what they think caused the O-ring to fail.
- Dave
Old 27th May 2004, 21:13   #19
DaveK
DaveK's Avatar
Update
I finally got my car back from the dealer yesterday. They found internal leaks in both VANOS units, and pulled them apart. They put them back together with all new seals (gaskets, O-rings), and replaced the crankcase valves and one of the MAFS. I asked them what caused it and all they could say is that the seals went bad.
While I was picking the car up I bought stock air filters to replace the K&Ns. While putting them in I noticed that there was still some oil residue left in the intake, so I took it apart again and gave it a better cleaning, and cleaned the MAFS with soapy water, then isopropanol, then contact cleaner spray. That way I'll know for sure if the problem happens again. I took it for a spin and it runs fine. I checked the intake again and found no oil. I'll check it again in a few weeks, and hopefully the problem will not come back. Thank god for the CPO warrantee!
Thanks for all the replies.
- Dave
Old 17th December 2004, 02:27   #20
OldRanger
Garage: M5 Royal Red
Re: Motor Oil Coating Intakes
Dave, thanks for the detailed thread on this problem. I've called it back up because my dealer here in SC has informed me that oil residue in the intakes is normal , and does not plan to correct this condition on my engine. The amount of oil residue that I have is similar to that reflected in your pictures, and in my observations, it's more significant on the passenger side than the driver side.
I was wondering if anyone could confirm/deny this claim by my dealer's Master Tech. Do the rest of you have oil in your intakes? (I've got 55K miles on this engine)
That said, I recognized the "vents", or perhaps better defined "drain" holes on the bottom on the intake tube just before the connection to the OE air filter assembly. I speculated these might be for the purpose of draining oil if in fact it did coat the intakes (by design?!?!?)
Also, if any of you have had this "problem" corrected - what were the part numbers from the work order, and did the corrective action solve the problem.
Thanks!
OldRanger is offline   Reply With Quote
I NEED SOME HELP WITH AIR INTAKE SYSTEM Thunderbird E39 M5 and E52 Z8 Discussion 6 14th May 2004 23:42
Recycle air intake location ? ColinM E39 M5 and E52 Z8 Discussion 3 20th October 2003 07:10
cold air intake playboypureplay E39 M5 and E52 Z8 Discussion 3 15th May 2002 02:56
OT - Nissan's lane keeping system. The high tech march continues... blue max E39 M5 and E52 Z8 Discussion 8 9th December 2001 19:58
New RAM air induction system for E39 M5 :-) AndyMenard E39 M5 and E52 Z8 Discussion 10 20th April 2001 15:03
