17th May 2004, 06:26
#1 (permalink)
Survey: Braking in Gear or Neutral?
Folks,
I tried to search the board but could not find anything on this. Here is the situation:
I used to always downshift and brake at the same time due to better braking power, less brake pad wear and the coolness of the engine sound. But I was told that you either wear your clutch or your brake pad of which the clutch is more expensive than brake pads. So I started to brake in neutral. But recently I found out this article on Men's Health Magazine May 2004 under Crankshaft Don's column.
Q: Why do people say it's bad to coast in neutral?
A: Because it costs money. Coasting in neutral, whether the car has a stick shift or is automatic, improves gas mileage by a hair. But it also levies a heavier burden on your brakes, leading to premature (and expensive) maintenance. Constantly reengaging an automatic transmission at speed also causes gear wear. So let your transmission provide engine braking as the engineers intended.
What are your thoughts? Did the engineers really intended braking in gear? Do you brake in neutral going from 60-0 MPH or do you downshift while braking from 60-0 MPH? I know the heal-toe technique but sometimes, I'm just lazy. Any feedback would be greatly appreciated!
Khoa
Khoa as in "Qua" - Lity
`01 M5 Imola Red / Black
Interior MODS:
3M Ceramic Tint
Valentine 1 Hardwired
Jaric StealthOne V1 Display
Kenwood Sirius Satelite Radio
Blitzsafe M5 Integration Adapter for Stereo Input
Alpine 6 Disc DVD/CD Changer
NAV-TV with Stereo
Arista 4x1 Autoselect Audio Switch
BMW Titanium Pedals
BMP Titanium Heal/Toe Plate
BMW All Weather Floor Mats
Weathertech Trunk Mats
BMW Trunk Storage Bin
BMW Umbrella Mount
BMW Headrest Coat Hanger
Exterior Mods:
Painted Side Moldings
Stage II HID Fog Lamps
6000K HID Low Beam Bulbs
Xenon Bulb High Beam upgrade
Tubi 80MM Cat Back Exhaust
Bavarian Autosports Cross Drilled Rotors
Super Blue Brake Fluid
Brembo Front Brake Calipers (Black)
Brembo Rear Cross Drilled Brake Rotors
Stainless Steel Braided Brake Lines
BMW Brake Duct Kit
UF Motorsports IATS
Dinan 3.45 Limited Slip Differentials
Dinan Software
Dinan Front Strut Tower Brace
Dinan Rear Strut Tower Brace
Dinan Rear Sway Bar
BeastPower Rear Sway Bar Brackets
Rogue Engineering Tranny Mounts
UUC Motorwerks Clutch and Lightweight Flywheel
UUC Short Shift Kit
17th May 2004, 06:55
#2 (permalink)
Re: Survey: Braking in Gear or Neutral?
When I am driving I will not put the car in neutral, but I put the clutch in to brake if I am under 2k rpms.
-Sam
17th May 2004, 07:16
#3 (permalink)
It depends on what you are talking about. For maximum braking, clutch goes in. But if you are driving around town, leave the clutch out when you brake. Not only does this save you the need to reengauge the gear if you need to start going again, it can also get you out of an emergency if you need to pin the throttle for any reason.
When I slow down, I heel and toe down to the best gear for the speed, or as speed permits the gear that will give me best power on corner exit.
The way I teach people is keep the car in gear until you are ready to stop. Slowing down and grabbing lower gears without heel and toeing is hard on the clutch (relative to leaving it in gear, clutch out), and limits what you can do in a pinch. If you dont need a lower gear after slowing down, just leave it in gear till you almost stop. If you need the lower gear, heel and toe.
-Brendan
'01 540/6
17th May 2004, 08:01
#4 (permalink)
Khoa,
A few thoughts.
When in gear, no matter what gear you are in, a manual car will always give you a little engine-braking (more if you are in lower gear), so it is always more gentle on your brakes to brake while in gear. Braking in neutral offers NO engine braking whatsoever.
Some people down shift, and rely solely on engine braking to slow down. This saves some brakes but puts more wear on the clutch and engine, and brakes are definitely cheaper than clutch and engine.
If you need to slow from 60 mph (6th gear) down to 20 mph, you'll definitely need to down- shift at the end. You can do one of the following:
(1) Brake in 6th until 20 mph, then shift into second and then gas up.
(2) shift into neutral, brake till 20, shift into 2nd, then gas up.
(3) Do a series of down shifts to secomd gear (if you have enough time/distance), until car slows to 20, then gas up.
I used to do (3). Now I do mostly one. I NEVER do (2) as I want to be in gear at all times in case of emergency.
CP
CP
CP
00 Titanium Silver: 6/00-1/05 RIP
95 Black Metallic RUF BTR-2
07 Meteor Grey Cayman
17th May 2004, 08:37
#5 (permalink)
Around town, I'll leave the clutch out while braking and not downshift. If I'm on a faster road and in 5th, I may downshift to 3rd as I get < 1500 rpm. If I am on the highway, I'll drop from 6th to 4th on the offramp and bring the car the rest of the way to the stop in gear. I'll touch the gas during the downshift but alow the engine braking to help slow the car. Good or bad, it has yet to wear out anything prematurely in the 5 manual trans cars I've owned.
Richard
NEW 2008 550i Space Gray, Creme Biege/Black/Dk Poplar : Sport Package, Cold Weather, Sport Auto, Nav, HUD, CA, Logic 7, iPod/USB, SAT, HD Radio, Lane departure warning
'06 X3 Black Sapphire/Tan PP, Steptronic, Xexons, Heated seats, Privacy glass, UGDO, Compass, bike rack, iPod adapter
Sold '06 650i Black Sapphire/Cream Beige sport package, 6 speed
'02 M5 Titanium Silver/Black Luxury/Burl
17th May 2004, 13:44
#6 (permalink)
I usually leave the clutch engaged until rpms hit somewhere around 1k and then I disengage. So I coast the last little bit. This is for stopping. For slowing down it all depends. If its clear I will need some good acceleration after braking, I will downshift first. FWIW, the guys at the DE told us we don't need engine braking with modern cars since brakes are now so good and we can save wear and tear on the drive train.
All the best,
#7 (permalink)
By the way, regarding saving fuel, ever since Motronic hit BMWs (  ...guess this means since 1983 in the 5 and 7 series, dang, time flies!!), when the throttle is closed and the engine rpm is above about 1200, there is NO fuel flowing into the engine. It is totally shut off. So you will save a lot more fuel if you don't slow down in neutral. On cars with the MPG guage, you can clearly see this in action including resumption of fuel consumption around 1200-1400 rpm area as the car slows down.
Current stable:
Ground Control camber plates
Stoptech front brake kit
Brake ducts opened
TC Design brackets
OE 9.5" rear wheels all around & 275/35-18 PS2s street
275/35-18 Nitto NT-01 R-comps track
1996 Volvo 850R wagon
18th May 2004, 00:37
#8 (permalink)
Thanks guys for all your help! You all have been very helpful. This board and it's members are such a valuable asset. If you are ever in houston, let me know. I'll buy a round of drinks and show you how I downshift.
Khoa
Interior MODS:
3M Ceramic Tint
NAV-TV with Stereo
BMW Titanium Pedals
BMW Umbrella Mount
Exterior Mods:
BMW Brake Duct Kit
UF Motorsports IATS
Dinan Software
Dinan Rear Sway Bar
UUC Short Shift Kit
18th May 2004, 00:46
#9 (permalink)
I went to a Porsche Advanced Drivers School a few years back and one of the first things they talked about in the class room was that brakes were cheaper to replace than the clutch/engine so use them.
Terk.
Tony
07 997TT Basalt Black/ Natural Grey
05 X5 4.8is LeMans Blue/Black Nappa
05 X5 4.4i Titanium Silver/Black
69 Firebird Carousel Red/Black
03 ///M5 LeMans Blue/LeMans Blue (sold )
18th May 2004, 01:22
#10 (permalink)
Hopefully not in that order...  Dont worry, all advice is free. Well, almost free. Pictures work as payment options.
-Brendan
'01 540/6
18th May 2004, 02:23
#11 (permalink)
