5th May 2004, 06:12
#1
Cyclical "clicking" on hard right-hand turns (on track)?
Has anyone else experienced this noise? It seems to be coming from the console area, but could actually be from anywhere. I don't hear it much on left hand corners, only on right corners. Could it be the brakes chattering? Or something else? I keep forgetting to pay more attention to it, and I have no clue what it could be. It doesn't seem to change based on speed, and occurs when I am taking a hard right corner (street tires squealing loudly).
28th April 2005, 05:43
#2
Re: Cyclical "clicking" on hard right-hand turns (on track)?
brian, did you ever find out a cause to this. My M5 does the exact same thing, right turns on the track, mostly noticable when i'm going along a wall for a hairpin etc. I'm thinking either a brake splash shield may be flexing and rubbing something or perhaps a wheel bearing getting old (darn clockwise roadcourses).
28th April 2005, 05:54
#3
The noise might be in the front flex joint of the driveshaft.
Joe
28th April 2005, 07:00
#4
Had that on my wife's old X5... in her case it was due to a bad control arm.
28th April 2005, 16:32
#5
2006 M5 - Silver Gray
When I saw the subject of this thread, I thought it was in reference to driving instructors. When I go for track days and we sit in class, they always talk about clicking - when you are going into a turn, go click, click, click when turning the wheel, don't just yank down on the steering wheel. Smooth input.
Are you sure you aren't clicking subconciously when turning or have an instructor sitting in the passenger seat? - check for the instructor first, they tend to make those noises a lot (along with others and sometimes leave finger sized dents in the dash) - once you find and remove the instructor you will find that you can handle the car better (lighter load) and there will be a lot less noise!
SCORPIO
2006 BMW E60 M5 - Active Autowerke's ECU upgrade; Charcoal Filters removed
-Silver Gray with Black perf. interior
-Rear side impact airbags
-comfort access
-front multi-function seats with active width adjustment
-wood trim, walnut
-power rear sunshade with rear manual side window shades
-front ventilated seats
-heads-up display
-3M Ultrashield clearbra
2008 Black BMW 135i Convertible
2008 Black Yukon Denali
2007 Saleen Mustang Parnelli Jones Limited Edition 1 of 500 - Sold
2006 Sterling Grey/Grey BMW X5 4.4i w/all available options - Sold
2004 Chevrolet Corvette Z06 (red) - Sold
2004 Quicksilver Cadillac Escalade ESV - Sold
2003 White Porsche GT3 Cup Race Car - HELL YES! - Pirelli Drivers Cup 2nd/3rd - 2010 Miller Motorsports Park
2003 Cold Stone Creamery #00 Mini Cooper S Challenge Series Race Car - NASA AZ Champion; NASA National Runner-up 2009/2010
2003 Sterling Grey/Black M5 - Sold
2000 White Chevrolet Silverado 2500 HD 4x4 SB Pick 'em up truck - Sold
1994 Yellow Land Rover Defender 90 - Sold
1980 Nissan 2WD pickup - Sold
1971 Fiat Spider - Sold
28th April 2005, 19:35
#6
I am an instructor! and this happens with those darn student passengers (don't think i ever go out alone)....
Glad to hear it's not only me though!
28th April 2005, 20:53
#7
I knew I would get a response out of you!
28th April 2005, 21:38
#8
2008 E92 M3 Jerez Black
It may be something very simple......
I had this last summer and finally tracked it down to a small stone caught between the disc shield and caliper. It only clicked when turning under load, never when in a straight line.
Drove me absolutely nuts for a couple of weeks, but it was simple in the end!
Best of luck Brian
Good fortune on the road ahead!
Martin.
28th April 2005, 23:06
#9
Best of luck Brian
don't think that's it, i've done the brakes a couple of times and it still occurs... even installed a big brake kit, didn't leave any rocks behind!
30th April 2005, 07:11
#10
Mine turned out to be periodic contact between the metal OEM dust shield and the StopTech rotor. Removed heat shield, problem solved.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
