Old 3rd May 2004, 10:32   #1
BoringFamilySedan
BoringFamilySedan's Avatar
Garage: '01 M5 (Le mans blue on Le mans blue)
Send a message via ICQ to BoringFamilySedan
Suspension upgrade
I have the Dinan Stage3 suspension for now, but I prefer something firmer.
Suggestion?
I love to have DFC, but it's no longer available.
Dinan: Stg 3 Software, CAI with all updates, Flow meters, exhaust, 3.45 diff, Stg 3 Suspension, Front Strut Brace, Rear Shock Brace, Wheels (Tires: Front 265/Rear 275), Floor mats
Others: AC Schnitzer Front Spoiler, AC Schnitzer Foot Pedals, 6000K, Brake Ducts, M Audio woofers, UUC Flywheel+Clutch, UUC EVO3 SSK
BoringFamilySedan is offline
Old 3rd May 2004, 15:06   #2
Lscman
Garage: E39
Re: Suspension upgrade
The firm choice is Ground Control. If you consider your stage three just plain "too soft", you'd better be looking for rates in the 450 lb/in or higher range. The M3 community is choosing rates in the 500lb/in range for dual duty track and street use & realize that these cars weigh about 600 to 800 lbs less. "Make no mistake", such a setup rides HARD.
Lscman is offline
Old 4th May 2004, 21:39   #3
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
I spoke with a guy at a recent drivers school at buttonwillow who ditched the dinan stage 3 set up his car had when he purchased it for a set of KW coilovers and he couldn't be happier. He said the street ride was firm, but totally acceptable, and it was just transformed on track. I'm still on the fence about which suspension to go with myself.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 4th May 2004, 21:45   #4
Chuckc
Garage: 2001 Dinan 740i
Was his name Tim by any chance?
"The richest people in the world build networks. Everyone else is trained to look for work" - Robert Kiyosaki, Rich Dad Poor Dad
Chuckc is offline
Old 5th May 2004, 00:00   #5
BeastPower
Guest
This is also how I feel about the KW coilovers. They transform the handling with only a minor penalty in daily driving.
Cheers.
Old 5th May 2004, 00:16   #6
Teutonaddict
Teutonaddict's Avatar
Garage: '00 Carbon Black/Black All-Leather/Sportive
Mike-
I'm not a "my-way-or-the-highway" type, and happen to think the two systems are more alike than dissimilar. Here's a three-way comparison we did awhile back between a Stage III, kw and stock suspended beasts.
3 M5s spotted in Tucker today, anyone?
I had not added the Dinan rear swaybar at that time, and am still kicking around a set of adjustable front camber plates for that final "tweak."
Hope that helps!
-Dave
BOTH SOLD!!
#101421
Teutonaddict is offline
Old 5th May 2004, 00:50   #7
BoringFamilySedan
For the KW coilover, what is the difference between Variant 1 to Variant 3?
How do they compare to H&R's setup?
Thanks for your suggestion and opinion.
Old 5th May 2004, 00:57   #8
BeastPower
Guest
www.beastpower.com has the specs on the 3 KW variants.
Cheers.
Old 5th May 2004, 02:39   #9
mottati
mottati's Avatar
I think so, did he make his own MAFS? If so that's him....
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 5th May 2004, 02:43   #10
mottati
mottati's Avatar
Originally Posted by Teutonaddict
Mike-
Hope that helps!
-Dave
Thanks for the Link Dave. I have had dinan suspensions on past cars and have been pretty pleased with the overall compromise in street/track handling and ride. One thing that's holding me back with the coil overs (either kw, GC or the upcoming H&Rs) is using my rear 9.5" wheels on the front, without going with really thick spacers. I'm waiting to hear what 'redshift' on the board finds when he installs his GC kit. Additionally, i know i won't do any adjusting after they're set up, so why have all the adjustability of coilovers? I don't really want to go super low either, just a bit lower in the front, and more negative camber.
Thanks again,
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Nav Sw Ver 18 upgrade - FAQ 1C00lVC M5 E39 and E60 tips & tricks 0 12th March 2002 06:00
Suspension Upgrade Choices??? FAST4DR E39 M5 and E52 Z8 Discussion 6 26th July 2001 06:34
Why Dinan suspension upgrade but no one try other manufacture? JCM5 E39 M5 and E52 Z8 Discussion 2 19th January 2001 17:16
anyone done the Dinan suspension upgrade? AndyMenard E39 M5 and E52 Z8 Discussion 5 20th October 2000 14:50
Page generated in 0.16954 seconds with 11 queries
