Old 2nd May 2004, 16:10   #1
sforssell
sforssell's Avatar
Garage: BMW M5 Carbon Black
Problems with Autoenginuity Scan Tool
I recently bought the Autoenginuity ScanTool. However, I can't get it to connect to my 2000 M5. Has anyone had similar problems or is anyone using the tool successfully?
2000 M5 Carbon Black / Black
sforssell is offline
Old 2nd May 2004, 17:22   #2
ALEV8
ALEV8's Avatar
Garage: 2003 S500 AMG
Send a message via AIM to ALEV8
Re: Problems with Autoenginuity Scan Tool
I had difficulties until I changed the port I was connecting with per the instructions. Also, the tool would not work with my USB port laptop and an adapter. I had to use a native serial port laptop, and even then the tool would disconnect frequently.
ALEV8 is offline
Old 2nd May 2004, 17:33   #3
sforssell
sforssell's Avatar
I forgot to mention that I have the Palm version of the scantool.
There is a note on the following page which states that the tool is not compatible with the e39 M5:
However, I cannot find any reason for this.
Old 31st December 2006, 15:40   #4
sadil340
sadil340's Avatar
Garage: Jet Black 2001 M5
Check out the thread below for some useful info. In my case I can't get the Autoenginuity tool (PC version) to work with my M5 but it works OK with my other cars. They told me that it probably won't work with my car (although it appears that others get it to work) without the BMW enhanced interface package which is $229 on top of the base tool. I'm debating purchasing the package vs another tool to use just with the M5.
Which scan tool is the best?
sadil340 is offline
Old 31st December 2006, 21:59   #5
a_ok2me
a_ok2me's Avatar
Garage: M5
The windows PDA version did not work for me, so they gave me a PC version. They're still working on the PDA version to get it to work. I had problems with connectivity with the PC version, but finally got it to work by using a Belkin USB adapter => null cable => OBDII adapter. I tried every other cable options and they didn't work. Did you try using a null cable and the correct USB adapter? The null cable was the key.
Also, has anyone tried to return it? Mine seems to work so there's no reason to return it. However, I'd like to test it on a car with real problems to see if it really works.
Hopefully everyone else can get theirs to work as I'm curious to see everyone's results. Please save all the troubles by taking shortcuts with cables and just get a USB adapter that's known to work (IO Gear, Prolific, Belkin) + use a NULL cable. There's also an FAQ on IBM Thinkpad IrDA issues near the bottom here...http://www.autoenginuity.com/faqs.html
a_ok2me is offline
Old 1st January 2007, 00:09   #6
Yankee802
Yankee802's Avatar
Garage: 2001 BMW M5 - Silver
Send a message via AIM to Yankee802 Send a message via MSN to Yankee802 Send a message via Yahoo to Yankee802
I just purchased for $429.19 from beastpower.com:
AutoEnginuity Enhanced ScanTool Software for the BMW M5 (e39)
Hopefully I wont have any problems.
It states that it will work with other vehicals manufactured after '91 with OBD, and I'll be trying it on the M3 as well.
2001 Silver ///M5 (just like the icon, she's gone)
1995 White ///M3
1995 Green ///540ia M-Sport
1984 Silver & Blue Prevost Marathon
Yankee802 is offline
Old 1st January 2007, 00:13   #7
Yankee802
Yankee802's Avatar
You mean a null-modem, or crossover cable.?
Thankfully as a geek, I have a few of these in a varity of standards. (serial, parallel, ethernet) So if I have troubles with mine, this will be the first thing I try, thanks!
1995 White ///M3
Old 1st January 2007, 00:29   #8
a_ok2me
a_ok2me's Avatar
Garage: M5
Null modem. Great, I'm sure you'll get it to work and provide feedback on it.
a_ok2me is offline
Old 1st January 2007, 00:33   #9
Yankee802
Yankee802's Avatar
Yup, you bet! Once I get my carputer installed, and connect the Autoengineuity, I'll post pics and a write-up.
1995 White ///M3
Old 1st January 2007, 00:36   #10
Yankee802
Yankee802's Avatar
Quick question. Being that I want to semi-permently install my Autoenginuity with my carputer, will the OBD-II vehicle interface be in my way while driving? I believe the port is under the dashboard left of the driver's left leg, correct?
1995 White ///M3
DME fault code reader/reset tool for Euro M5? Gop-Dogg E34 M5 Discussion 1 23rd March 2004 09:20
jrturbo, Does this fiat tool do the valve job ??? klunk E34 M5 Discussion 3 7th June 2003 03:54
odbII scan tool MikeNJ E39 M5 and E52 Z8 Discussion 3 21st January 2003 10:30
Trip to Nordschleife/Brake problems solved johann E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 18 2nd August 2002 23:20
Is BMW loosing it? Severe technical problems w new 7! Black B10V8 E39 M5 and E52 Z8 Discussion 23 17th January 2002 09:48
Page generated in 0.15078 seconds with 11 queries
