Old 21st April 2004, 23:21   #1
madyspop
Garage: 01 Imola red M5
Send a message via AIM to madyspop Send a message via Yahoo to madyspop
Anyone ever loose oil pressure from an oil change?
As some of you know I bought a 2000 M5 last week but I still haven't gone out to pick it up yet. Anyway, I had the original owner take it in for an oil change and final look over before I hand over the check. He called me back after the oil change, the mechanic changed the oil and when he finished the car wasn't getting any oil pressure and the car through a code and wouldn't start. So they flatbedded the car to the dealership and I still haven't heard anything about whats going on. These are the only details I have so far, I was just wondering if this has ever happened to anyone before or if anyone knows what would cause this?
madyspop is offline
Old 22nd April 2004, 00:29   #2
x703jko
x703jko's Avatar
Garage: 2003 Dinan S3 M5, LeMans Blue/Caramel
Re: Anyone ever loose oil pressure from an oil change?
Originally Posted by madyspop
As some of you know I bought a 2000 M5 last week but I still haven't gone out to pick it up yet. Anyway, I had the original owner take it in for an oil change and final look over before I hand over the check. he called me back after the oil change and the mechanic changed the oil and when he finished the car wasn't getting any oilo pressure and the car through a code and wouldn't start. So they flatbedded the car to the dealership and I still haven't heard anything about whats going on. these are the only details I have so far, I was just wondering if this has ever happened to anyone before or if nayone knows what would cause this?
Did they put 7 quarts of oil in or 8? The E39 M5 takes 7 quarts. It is possible, and I'm just speculating here, that if they put it 8 quarts (which is what most of the other current BMW engines need, the excess oil has blown a seal somewhere.
Just a guess...
Jeff
2003 M5 LeMans Blue/Caramel/Walnut
Dinan S3 Includes all Dinan S3 Mods With JRZ Sruts/Shocks, Oil Cooler, Monoball Links
StopTech 4 Wheel BBK With Red Calipers And Slotted Rotors
Axxis Ultimate Pads
M Enhanced Audio
Park Distance Sensors
Two Sets Of Dinan Lightweight Forged Wheels
Winter Tires - Michelin Pilot Sport A/S - 275/35ZR18(Y) (F); 285/35ZR18(Y) (R) (Not Sure If They'll Survive The S3)
Summer Tires - Toyo RA1s- 275/35ZR18(Y) (F); 275/35ZR18(Y) (R)
Dual, Front Mounted LE30's With Custom AIDesigns Kill Switch/LED Panel
Valentine V1 With Stealth One
UUC Short Shifter With DSSR
Oil - BMW/Castrol 5W30 Changed and tested every 3000 miles.
x703jko is offline
Old 22nd April 2004, 00:35   #3
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
Although i'm not sure what the owners manual says (thought it said 6.9L), on my 00 M5, i need 7.5 Liters of the 10.60 to get up to the full mark on the dipstick, with the oil temp warm, after sitting for several minutes, when i change my own oil. This seems consistant with my dealer charging for 8 liters of the same stuff when it's in for the same. I suppose it depends on how long you let the oil drain, it can trickle out for nearly 45 minutes if you let it go until it stops completely.
mike
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 22nd April 2004, 01:35   #4
x703jko
x703jko's Avatar
Originally Posted by mottati
Although i'm not sure what the owners manual says (thought it said 6.9L)...
Yes, the manual states 6.9 liters (which is 7.29 quarts) for an oil change with new filter.
Jeff
x703jko is offline
Old 22nd April 2004, 02:20   #5
madyspop
Jeff
So lets say they just over filled the oil and it blew a seal, how serious is that and how much would it cost to repair it?
madyspop is offline
Old 22nd April 2004, 02:41   #6
mottati
mottati's Avatar
I don't think overfilling the crankcase slightly would cause something like this, personally. I wonder if the 'mechanic' forgot to put oil in? That's mess up the vanos and cause the codes.
mottati is offline
Old 22nd April 2004, 02:50   #7
x703jko
x703jko's Avatar
Not sure...and I'm not even sure it's a plausible explanation for your problem. I was only guessing about what could happen during an oil change that could cause a problem.
I would imagine that if you did blow a seal, you would have other probs also.
It's also possible that the sensor is bad. At any rate, have BMW scope it out for you.
Jeff
x703jko is offline
Old 22nd April 2004, 02:52   #8
x703jko
x703jko's Avatar
Another possibility, and again, I can't say for sure, but did they use the right filter? Seems unlikely to me.
Jeff
x703jko is offline
Old 22nd April 2004, 06:08   #9
TCM
TCM's Avatar
It is very hard to screw up with regards to the filter as well since most of the BMWs use the same filter. Please keep us updated on what the culprit was.
T.C.
'01 Silverstone M5
SuperSprint:X-pipe
TCM is offline
Old 22nd April 2004, 10:46   #10
madyspop
Thanks for the input guys and I will update you as soon as I find something out. This is killing me Because I don't know how major or minor this is.
madyspop is offline
1200 mi. oil change denied for '03 pwilliams E39 M5 and E52 Z8 Discussion 40 10th July 2003 01:27
my dealer "gave" me 2 quarts of oil Jacob Lee E39 M5 and E52 Z8 Discussion 5 7th April 2001 22:09
Q: Is oil temp change normail after service? M5_Surge E39 M5 and E52 Z8 Discussion 12 8th February 2001 12:52
"check oil pressure" warning on skidpad shore E39 M5 and E52 Z8 Discussion 1 8th June 2000 07:16
My 1200 mi service - no oil change greg E39 M5 and E52 Z8 Discussion 6 24th April 2000 04:12
Page generated in 0.15360 seconds with 11 queries
