Old 19th April 2004, 21:56   #1
stanm5
stanm5's Avatar
Garage: 2000 e39 M5 avus blue/two tone grey
cam position sensor failure or maf?
Hi,
I'm wondering if anyone can describe the symptoms of cam position sensor failure and of fouled maf?
My car has developed a bit of hesitation at start and also when pulling through the power band. Additionally whe the car is first started in the morning it hesitates quite badly and will not rev past 3000. It clears up after a few minutes. The car stays in doors at night so it's not really cold when I start it up.
Cheers,
Stan
996 Cab
stanm5 is offline
Old 19th April 2004, 22:08   #2
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Re: cam position sensor failure or maf?
Originally Posted by stanm5
Hi,
Cheers,
I just had the intake cam position sensor replaced on one bank over the weekend. I did not have your symptoms, in fact I had virtually no symptoms. In retrospect, the car is now more eager to pull, and it needs less throttle opening. I would suspect other than the CPS if my experience is typical. BTW, I didn't have any codes until last week, yet this must have been going on for some time as the change is noticeable.
gsfent is offline
Old 19th April 2004, 22:27   #3
Synergy
Synergy's Avatar
Garage: 2000 M5 Anthacite
Hi,
Cheers,
What a coincidence... I was just about to post a similar question.
For a few weeks now, my car has idled rough on a cold start. I had to keep the RPMs above 1500 for a couple of minutes, or else she would die on me. After she warmed up, she would drive just fine. She set off a check engine light just a little before she did it and when I took her into the dealer, they said it was the pulse flow sensor. Well, a couple of hundred dollars later, I picked her up and she still had the same idle issue, but no SES light. I decided to live with it for a little bit since I don't have a ton of money to dump into wild goose chasing with the dealer at the moment.
A couple of days ago, she started having a lot of trouble with a warm start, and also threw another SES light. Cold starts still just have a rough idle until she warms up. But if I turn her off and then turn the engine back on after about 10 or 15 minutes, she has some real issues. Her idle is a slow loping. There is absolutely no power. Pressing the gas pedal doesn't really do anything. I have to let her just sit and idle for about 5 minutes.
Anyone have any ideas? I'm taking her in tomorrow, but figured I'd ask and see if anyone might have encountered this before.
Synergy is offline
Old 20th April 2004, 02:06   #4
Ahmed
Ahmed's Avatar
Garage: Sepang Bronze E60 M5
Sales Feedback: (3)
3 possibilities!
1. MAF's are defective
2. Spark plugs and cables are defective
3. ECU (cold Start) parameter fault!
I dont know about US spec M5's, but do you get a message in your test display that says "engine failsafe prog" ??? If so, then your engine goes into safe mode and thats why you run rough and get power loss!
2006 Sepang Bronze/Naturelle Brown E60 M5
Eisenmann Sport Mufflers
Miesterchaft Sections 1 & 2
Evosport Headers
Evosport Pulley
RPi RAM Scoops + Block Off Plates + BMC Filters
CA Auto/AL-Tuning Custom Stage 2 DME Upgrade
Eibach ProKit Springs
20" Breyton Race CS with Yokos
White Angel Eyes, 6000K HID's & LED Plate Lamps
ACS Roof Spoiler
Matte Black Kidney and Fender Grills
StopTech BBK 6 Piston Front & 4 Piston Rear
Ahmed is offline
Old 20th April 2004, 04:26   #5
stanm5
stanm5's Avatar
I just finished cleaning both MAF's using detailed instructions from the archives (what a great resource)!
I took it out for a drive and after lettign the engine get up to operating temp. I attempted to make it hesitate. I would say that it's 95% better than before. The real test will come tomorrow once I've been in traffic for a while and the engine is really hot.
More on this tomorrow.
Cheers,
stanm5 is offline
Old 21st April 2004, 14:48   #6
sforssell
sforssell's Avatar
Garage: BMW M5 Carbon Black
Has anyone tried to clean MAFs in a ultrasonic washer? The thing they use in laboratories to get equipment cleaned. It looks like a small bowl with water which vibrates ultrasonically.
2000 M5 Carbon Black / Black
sforssell is offline
Ditching the MAF Hollis E34 M5 Discussion 10 5th February 2005 23:57
KN filter and MAF....Lost power? Gaspasser E39 M5 and E52 Z8 Discussion 7 3rd September 2003 11:48
faulty cam sensor and NO warning . Van Volsem E39 M5 and E52 Z8 Discussion 0 13th July 2003 21:31
Metallic rattling from cam cover dronfieldm E34 M5 Discussion 8 23rd September 2002 16:51
TireRack Test of SO3, Pilot Sports, Pzero's steveB E39 M5 and E52 Z8 Discussion 1 12th June 2001 00:16
Page generated in 0.13797 seconds with 11 queries
