What is the best Bang for Buck mods for E39 M5 - BMW M5 Forum and M6 Forums
Like Tree1Likes
Old 17th April 2004, 12:09   #1
seanv
seanv's Avatar
Garage: 2003 BMW M5 Imola Red
I have a 2003 M5,
I have done the following,
Tubi Exhaust,
Reflective material under plenum
I would like to do:
ram air
headers either supersprint or dinan (sugestions?)
chip
larger homemade intake runners, dinan style (sugestions?)
rear end final drive gear
thanks,
Sean
seanv is offline   Reply With Quote
Old 17th April 2004, 13:29   #2
ELEVENS
Garage: '03 M5 LMB/LMB&Al
Re: What is the best Bang for Buck mods for E39 M5
Until I read that you have a tubi, I was going to suggest that the x-pipe is the most bang for the buck - relatively inexpensive to buy and install, add horsepower, reduces weight (~30 pounds?) and sounds good.
Other efficient uses of mod money are a short shifter, brake cooling ducts (under $50) dustless brake pads, and a home-made cold air intake. The dual intake setup on the M5 flows very well, it just needs a cold air source IMO.
Maybe most important, a Valentine 1 to avoid losing your license!
ELEVENS is offline   Reply With Quote
Old 17th April 2004, 14:26   #3
MEnthusiast
Moderator Emeritus
MEnthusiast's Avatar
Garage: 03 M5
Aside from all the mechanical things, if you havent done a driving school- Id recommend it. You can really improve yourself- which is the one part of the vehicle which can continually improve.
All the best,
MEnthusiast is offline   Reply With Quote
Old 17th April 2004, 16:38   #4
M5manny
M5manny's Avatar
Garage: e38, E39. F10 M5 (soon)
The Evosport Diff and the Powerchip are the best mods for the money.
And a Drivers School
BMW Ninja
twitter.com/m5manny
M5manny is offline   Reply With Quote
Old 17th April 2004, 16:48   #5
BeastPower
Guest
Changing the suspension by adding larger diameter anti-roll bars (especially the rear), and going to a coilover suspension will transform the handling, and make the beast more fun to drive every time you turn a corner.
Cheers.
Old 17th April 2004, 17:47   #6
seanv
seanv's Avatar
is that diff the same ratio final drive as Dinan?
how much?
where can i get it
Old 17th April 2004, 17:51   #7
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II 93 M5 3.8 Sterling Silber
best mod for acceleration is the diff. you can get the 3.45 diff from dinan, which i believe is 2495 (there was a 1995 group buy, which is over) or from evosport. I think evosport is around 1900 or so as well, for the ring and pinion change, but they can also modify the lsd lockup, if you're planning on drag racing. Otherwise, i'd go along with the driving school suggestions, if you've never been on the track. For about $500, you have more fun than anything, and pick up some good skills that you can use everyday.
mottati is offline   Reply With Quote
Old 17th April 2004, 17:56   #8
seanv
seanv's Avatar
Between the Dinan Chip or Superchip?
I dont want to lose too much torque to sacrifice for horsepower
Old 17th April 2004, 18:02   #9
BostonRocket
BostonRocket's Avatar
Bang for the buck: short shifter kit. I don't think the future mods listed are really a bang for the buck. Either for cost reasons or no-perfomance gain.
'Rocket
BostonRocket is offline   Reply With Quote
Old 17th April 2004, 18:12   #10
mottati
mottati's Avatar
I don't know anything about superchip, but i do know dinan's stage 1 software offers zero power gains. it 'may' improve drivability, but it basically just remaps throttle input and removes the speed limiter. Many people here like the powerchip, but even then, you're talking 8-900 for a few hp. Not much bang for the buck, imho... You haven't mentioned what you're goal is, what kind of performance do you want? Acceleration? Handling? braking?
530 + (M5 front bumper * M5 wheels) = M530? RAREM5 E39 5 series Forum 32 17th April 2007 22:54
00 E39 M5 V12 LMR Conversion in IL? SC E38 M7 Off Topic Forum 14 24th June 2003 23:52
Driving a Z8 vs. an M5... ME? TheM5Kid E39 M5 and E52 Z8 Discussion 10 29th May 2002 14:50
Interesting Write up on M5 chunpng E39 M5 and E52 Z8 Discussion 11 27th March 2002 19:40
Your thoughts on the Z8 NO-MERCY E39 M5 and E52 Z8 Discussion 6 16th November 2001 05:26
