Old 22nd March 2006, 03:53   #31
ard
ard's Avatar
Flame Suit On:
Any way to ACCELERATE the service indicator?
A
ard is offline
Old 22nd March 2006, 04:15   #32
Stevie
Stevie's Avatar
Garage: e34 540i, Orientblau
Originally Posted by Jim Dolan
I have noticed on this board that as the car age’s new owners are less likely to get proper service from a BMW trained tech.’s
Sorry, but neither my 911 (1991 C4) or 540i (1995 manual) sees the dealer for normal servicing. Simply because the dealers haven't got a clue about the older cars. When ordering parts I've been told several times manual e34 540i's don't exist.............
Replacement of an AC sensor on the 911? Dealer (PON Porsche, the official importer) quoted 6 HOURS of labor, an independant laughed at me in the face and swapped it in 5 minutes for a new one. Same partnumber .
Oil-pump bolts falling out on the BMW V8's? Dealer doesn't have a clue, thanked me in writing for the warning, and they're checking all high milieage V8s now. With a failure rate of about 90%......
Cam-tensioners swap on S14 and S38 for the later models? They didn't believe it was possible until I showed them the internet pages.
VW MAF swap on e39 M5? They don't have a clue......
Longlife oil in e39 M5? They'll chuck it in without thinking twice.....
Every car I've sent to BMW for new thrust-arm-bushes comes back shimmying worse. Why? Because they just swap them on a 2-post lift and tear up the bushing when lowering it. They simply don't have a clue........
When asking for diff-oil for an M5 they said it was the same as all other BMWs. And here's wise-*ss telling them LSD requires different lubricants..... I stopped working as a mechanic years ago, and the only reason I maintain my own cars because no-one else will do it properly.
Cars older then 5 years should never be maintained by dealers, only by specialists. Dealer exist for selling new cars and selling parts, thats it.
Stevie is offline
Old 22nd March 2006, 04:17   #33
KBK
KBK's Avatar
Garage: E39/Anthracite Metallic
Originally Posted by ard
Flame Suit On:
A
smartasse answer, the one you are expecting:
Drive the living snot out of the car.
KBK is offline
Old 4th January 2007, 16:44   #34
dcaron9999
dcaron9999's Avatar
Garage: Carbon Black 2002 E39/M5
Sorry for the old thread revival. If I execute the sequence in post #1, my display goes from SIA XXXX to END SIA immediately. I do not see the RESET indicator. What am I doing wrong? Could it be due to the latest DME recall done on my car in October 2007?
I did this easily on my E46/M3. What's different on my newly acquired 2002 E39/M5?
dcaron9999 is offline
Old 4th January 2007, 17:36   #35
badboypolar
badboypolar's Avatar
Garage: '02 M5 Carbon Schwarz Metallic
Send a message via AIM to badboypolar
I just did it on mine and I have the DME recall software done. You might be turning the key to far. Literally you have to turn it ever so gently until the dash lights come on then hold the key there. Do not turn it until the click or it will not work.
You can't not be home before you haven't left.
2002 M5
M5Board.com Stickers Now Available
Crackberry E39 M5 Theme Ver 1.0
badboypolar is offline
Old 4th January 2007, 17:56   #36
dcaron9999
dcaron9999's Avatar
Did it again for the tenth time, with barely the key turned 1/8 of a turn, I still go to SIA, and then directly to END SIA, regardless if I push/release/maintain the odometer button or not. No reset message questions appear or flash....
Old 2nd February 2007, 19:26   #37
E39 MFIVE
E39 MFIVE's Avatar
Garage: E39 M5, T78FD3S
Did you ever get it worked out???
Wonder if being a Canadian car has something to do with your issue..
Stock E39 M5
T78 FD3S
zoom zoom...
E39 MFIVE is offline
Old 7th March 2007, 20:15   #38
marcel
Guest
I tried same procedure as well, nothing happening, not even SIA. Also I live in the Netherlands so EU spec car, is that maybe why??
Old 7th February 2008, 00:48   #39
4racing
Garage: M5,GTI
I somehow managed to change my temperature readings to celsius instead of fareignheit, any idea how I didi this. Got service indicator cleared , but as soon as I turned car off the service light comes back on? Help
4racing is offline
Old 8th February 2008, 06:32   #40
jaj
jaj's Avatar
Garage: 2008 M3 Coupe Space Grey
Just go into the "Settings" menu on the Nav computer display and change your settings back to Fahrenheit. No biggie. The OBC can be a little finicky about losing its settings.
jaj is offline
Peter Pan BMW -- bad service, No 1200 mile oil change on 03 jdh E39 M5 and E52 Z8 Discussion 29 21st May 2004 17:49
Can an un-reset Service Indicator cause intermittent SES light? greg E39 M5 and E52 Z8 Discussion 15 8th May 2004 06:01
Resetting the service indicator light? atomic80 E39 M5 and E52 Z8 Discussion 2 14th November 2002 18:15
Tech - service inspection 1&2 Vince5 E39 M5 and E52 Z8 Discussion 2 23rd September 2002 18:18
Official BMW service, is it worth it ? jrturbo E34 M5 Discussion 2 2nd November 2000 11:24
Page generated in 0.15448 seconds with 11 queries
