DYNO results from today - BMW M5 Forum and M6 Forums
Old 3rd April 2004, 20:15   #1
540-aiite
540-aiite's Avatar
Garage: '03 M5-Carbon Black
Hey everyone,
I got a chance to Dyno my car today at Mustang Magic in LI. They were using Dynojet and ran my car on 4th gear. Since my car was a 2003 model I disabled the DSC like how it was posted on this board. Funny, the sports button couldn't be turned on when I completely shut off the DSC. Well here are the results:
DYNORUN #1 Max POWER= 345.2 Max TORQUE= 303.1 (????)
DYNORUN #2 Max POWER= 354.9 Max TORQUE= 310.2 (????)
I'm going back in two weeks and seeing if changing out the velocity stacks will make a difference. My torque curve was all over the place. When I get the chance I'll scan the paper.
-John
Question...are you suppose to run it with sports mode on and are you suppose to run it on 4th gear?
540-aiite is offline   Reply With Quote
Old 3rd April 2004, 20:40   #2
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II 93 M5 3.8 Sterling Silber
Re: DYNO results from today
i would think you'd run in 5th gear, since that's 1:1 ratio, right? I don't think sport mode would make a difference in the numbers.
mike
mottati is offline   Reply With Quote
Old 3rd April 2004, 21:59   #3
ELEVENS
Garage: '03 M5 LMB/LMB&Al
Just curious about what performance mods you have, and what happened between test 1 and 2 to make the difference?
ELEVENS is offline   Reply With Quote
Old 4th April 2004, 01:34   #4
540-aiite
540-aiite's Avatar
Here are the list of mods starting from the intake out:
GruppeM intake
Dinan Air Flow Meter
Rennsport Velocity Stacks
Supersprint headers
Supersprint cats
3.45 differential
Kelleners Exhaust
I think the difference between the 1st run and the 2nd was the engine was cooler on the 2nd run. I do have the temperature relocation but the guy there said it was better due to a cooler engine. I think he also took it the second time to 7500 rpm.
My next DYNO will substitute the Rennsport Velocity Stacks with either the OEM parts or the Dinan Throttle Bodies and Stacks. I will also be taking out the cats. They are driving me crazy as in the amount of noise.
This was my first DYNO run so I don't know what gear I'm suppose to be in. Anyone else confirm 5th gear is the gear to use?
-John
Old 4th April 2004, 09:27   #5
BeastPower
Guest
Here is my dyno chart for comparison (see my sig for mods):
Cheers.
Old 4th April 2004, 14:14   #6
ELEVENS
Originally Posted by 540-aiite
Here are the list of mods...I think he also took it the second time to 7500 rpm...
What software do you have allowing 7500rpm?
Old 4th April 2004, 15:34   #7
540-aiite
540-aiite's Avatar
Thanks for your DYNO post. I just realise there is something really wrong with my torque. It's shape like a upside-down bell from 3500 to 5000rpm.
I have Powerchip in my car.
Old 4th April 2004, 20:14   #8
M5 Fever
Garage: 2003 M5 Le Mans Blue w/Caramel
pardon my skepticism but I have seen some stock dyno pulls on this board where 340 rwhp was achieved. I realize that all cars are different, but are you happy with your numbers with all of your mods (especially the headers). Seems to me your numbers should be higher...
Just my thoughts
regards,
al
M5 Fever is offline   Reply With Quote
Old 5th April 2004, 00:46   #9
540-aiite
540-aiite's Avatar
I'm not a happy camper, if that's what you wanted to know. I'm just trying to change my setup now for a better improvement on the next DYNO.
-John
Old 5th April 2004, 05:07   #10
XrayMD
XrayMD's Avatar
Garage: LeMans Blue M5,Silver X5 & Dk. Silver Mini S
John...somethings really wrong if you've got headers and cats and are getting those numbers. I got 338 before the headers. Do you have the Powerchip ECU/DME programming? If not, you're running a mixture that's too lean and I suppose that could be a factor. Also, I believe that 4th is the correct gear.
Steve
'02 M5 LeMans Blue:
Supersprint Headers and cats
Dinan Stage III suspension
BeastPower sway bar brackets
Dinan front strut tower brace
RMS short shifter
Llumar window tint (35%)
XrayMD is offline   Reply With Quote
Questions about Dyno results (writeup) atomic80 E39 M5 and E52 Z8 Discussion 13 20th May 2005 14:34
Dyno results BretCro E39 M5 and E52 Z8 Discussion 11 31st March 2004 04:49
Hamann mods..dyno results..help clauswagner E39 M5 and E52 Z8 Discussion 27 4th September 2002 02:33
My thoughts and some dyno results OEM Vs Nowack...long version Apples E39 M5 and E52 Z8 Discussion 65 10th June 2002 09:54
Disappointed with dyno results Ghost E34 M5 Discussion 25 21st March 2002 19:43
