Old 10th March 2004, 17:12   #1
Lscman
Garage: E39
Looking for Track Brake pad options for factory brakes
I'm looking for feedback on this somewhat "rare" OEM brake topic.
I realize most M5 track enthusiasts switch to big brakes, but hey, I'm...different. I occasionally run my cars in SCCA Stock Class Solo events & I don't want to get bumped up.
For background, the E39 M5 front pads are shared with '95-'02 540i, '02 530i and '95 (and up) 740i and 740iL.
These are the "genuine track pads" I've found that fit the stock E39 M5 front brakes (FMSI#D681, sometimes known as pad type 7560):
Porterfield R4 (non-S)
Hawk HT10
Pagid Orange and Yellow
Ferrodo
Any other ideas or options for track pads are appreciated.
Lscman is offline
Old 10th March 2004, 17:25   #2
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Re: Looking for Track Brake pad options for factory brakes
Lscman
I can't speak from experience on tracking the M5, but I have had my Audi Q on the track, only about 200 lbs lighter, and inferior front to rear weight balance. I have used Hawk Blues (I think HT-10 is new) and one step below, Hawk HP PLus and both have worked fine (and I run instructor group). The blues are a little more aggresive, and in the M5 I would sugges Motul 600 fluid and open brake ducts. No personal experience with the other pads. Have fun!!
gsfent is offline
Old 10th March 2004, 18:17   #3
CSBM5
CSBM5's Avatar
Garage: 2001 M5 LeMans Blue
I have no experience with these, but Carbotech has a number of different compound pads available for the M5 from all-out race to street. Perhaps some others on the board have used one or more of these compounds?
Current stable:
Ground Control camber plates
Stoptech front brake kit
Brake ducts opened
TC Design brackets
1996 Volvo 850R wagon
CSBM5 is offline
Old 10th March 2004, 18:28   #4
stever
Hawk Blues are not a good idea -- they will chew up the rotors rapidly with only a small amount of street driving and generally don't have very good life on the track.
I found Pagid Oranges to be inadequate on tracks that are hard on brakes and ended up with pad transfer.
Pagid Blacks certainly work, but i had trouble bedding them properly (and found that you cannot bed them over Oranges -- unless all the material is off the rotor -- and how do you know it's all off?). In theory, Pagid yellows should work, but don't have any experience.
I'm running PF97s on the front now for track with Stoptechs and they seem to do the job. if they don't make a front pad for the M5, you should be able to send them a set of plates and get them to make up the pads.
with proper pads, OEM brakes should work, it's just a nuisance to change pads -- and because of the bedding issues you really need to change rotors with pads
stever is offline
Old 10th March 2004, 18:31   #5
Lscman
Garage: E39
gsfent,
Perhaps the Hawk Blue would be a good rear pad with HT10 fronts, since they won't see so much heat. From reading, it appears HT10 offers bene's over the older Hawk "color coded" pads. Sincere thanks for the first-hand track assessment.
CSB,
Good catch on the Carbotech pads for D681. I forgot about those.
I hear the P+ are good for severe duty track & the brand new XP might be better.
Stever,
Excellent info. The the new Yellow Pagids look interesting...sounds like the older Orange is marginal for high heat. Your comments mirror Pagid comments. There's lots of great pads out there...that don't fit the D681 app
Lscman is offline
Old 10th March 2004, 18:43   #6
stever
i'm running axxis ultimates on OEM rears street and track with no problems - and i really didn't have problems running OEM pads on the rear for the track either -- you can't really get the rear brakes hot enough to bed a track pad (i've used temp paint to check)
stever is offline
Old 10th March 2004, 18:50   #7
Lscman
Garage: E39
Well.....that answers another question.
If you aren't overheating Axis Ultimate with stock rear disks mated with big StopTech in front, I'm not going to use a race pad in the rear (either). Sounds like Zeckhausen's recommendations were on the mark (again).
Lscman is offline
Old 10th March 2004, 18:50   #8
foxyboym5
foxyboym5's Avatar
Garage: BMW E30 M3 1987 & 996 TT 2002
Send a message via MSN to foxyboym5
Tracked the beast last weekend, and although i think my discs were warped when i bought the car a few months ago, they definitely were after the weekend! I was coming from 80-40mph with bad vibration through the steering. Definitely couldnt use all the beasts power, but it was quite a tight track so that may have had an influence.
Anyway, good advice guys cheers
foxyboym5 is offline
Old 10th March 2004, 19:48   #9
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
[quote=Lscman]I'm looking for feedback on this somewhat "rare" OEM brake topic.
[quote]
Lscman,
I have used the ht10's on my 528 (with 540 brakes) at the track on a couple occasions, using R tires. They worked very well. Since i have my M5 (with stoptechs) i obviously no longer use the 528 on the track. I'll check and see if i still have the ht10s, if so you can have them, if you like. PM me (so i remember) and i'll look in my shed this weekend.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 10th March 2004, 19:48   #10
Lscman
Garage: E39
foxy,
My track experience has shown heavy vibration in the steering wheel is usually due to: 1) cracked rotors or 2) cracked pads or 3) a buildup of pad carbon deposits on the swept area that results when temps exceed the pad compound's operating range. If you noticed the vibration before track time, I'd suspect overheated rotors with cracks. They tend to open and close with temps, causing intermittent vibrations on the street. I've seen them a couple times.
I have yet to see a warped rotor cause such vibration and I've gone thru at least 40 rotors on various track cars.
It may be worth a look.
Lscman is offline
QUESTION: Does anyone have the DINAN BRAKES and if so......... FAST 5 E39 M5 and E52 Z8 Discussion 19 26th April 2006 21:11
Front Big Brake Kits ... Are they truly better?? gra8fuldd ed E39 M5 and E52 Z8 Discussion 38 30th December 2003 14:16
Brake Rotor Issue Joe Lapicki E39 M5 and E52 Z8 Discussion 29 26th December 2002 16:42
Brakes Fading ...feel mushy when hot? Parkerfe E39 M5 and E52 Z8 Discussion 32 17th November 2000 12:17
Page generated in 0.16287 seconds with 11 queries
