Re: Need Help with DIY Inspection 1 on my beast..please help
Here's a site that lists Inspection I and II items. I don't know how up-to-date or accurate it is, or whether there are M5-specific things that are missing, but this should be a pretty good guide.
The microfilters are under the hood, just in front of the windshield. There are two of them. One each under those big rectangular boxes.
As I recall, you need 7 qts. of oil with filter change. Stop at 6 and check before adding the last quart. Be sure to perform check according to the instructions (run engine, wait 1 min., etc.). You probably know this already, but pre-fill the oil filter canister with some oil before tightening down the cover so the engine isn't as starved on initial startup from the oil change.
Need4Spd
