Old 10th March 2004, 01:31   #1
JEM
JEM's Avatar
Garage: Silverstone MY2000 E39 M5
Unlucky S-03s
Since I swapped to S-03s on the M5, I've had two rears damaged beyond repair by punctures at the shoulder, then one rear experienced belt separation bad enough to cause a vibration, now the right front picked up a screw and, upon closer examination, the tire's experienced enough belt separation to cause noticeable deformation in the tread and there's a small, oddly-shaped crack or tear inside at the shoulder (does not appear to be the result of underinflation - the tire was not visibly low when the screw was found and the tire-defect warning had not fired.)
So whether they're just crap or whether I'm just unlucky with them, I'm giving up on the S-03s and going to Pilot Sports.
I've gotten reasonable life out of the S-03s, and they're not quite gone, but close enough that I don't mind tossing 'em at this point.
I'd thought about trying the Goodyear GS-D3s, or the PZero Neros (I've had exceptionally good luck with PZeros on one of our other cars) but I'm not in the experimenting mood right now.
JEM is offline
S 03's and track time Martin A. E39 M5 and E52 Z8 Discussion 14 2nd May 2003 21:30
'02s and '03s running rough when cold? schnelleM5 E39 M5 and E52 Z8 Discussion 18 22nd April 2003 22:34
Page generated in 0.08127 seconds with 11 queries
