Old 9th March 2004, 04:09   #1
MT JTN
MT JTN's Avatar
Garage: 2002 Carbon Black BMW M5
Tech. theory: Engine Power vs. Fuel Consumption
With all the talk of the new E60 M5 as of late, I've been finding myself thinking... okay, for a moment, let's put aside the looks and think of the goods - at least 500 horsepower and probably 100 more lb/ft of torque than our current cars make... ten cylinders, 8500 RPM redline... what about fuel economy??
With our cars currently rated at 13/21, I can't imagine that another 100 HP and another 1500 usable RPMs would be able to match current consumption and I got to thinking...
Is engine power always inversely proportionate to fuel consumption?
-- I simply can't imagine getting 10 miles to the gallon in the new car and with prices of crude supposedly sky-rocketing this summer, returning even less fuel economy than I do now is not something I'd enjoy. --
It's generally true that two engines of the same specifications except a difference in displacement, one displacing more than the other, will not return equal fuel economy. More displacement, less fuel economy.
Will there ever be a time when an engine receives a power upgrade but without a sacrifice in fuel economy? (IMO, the 3.0 liter, and even the 2.5 liter I-sixes could use a little bump...just look at the engine output in the competing G35!)
A Dinan S2 certainly uses more fuel than a stock car, right?
Then I thought... well perhaps an engine just needs to improve its efficiency in order to make more power given an equal fuel economy. How would one go about making an engine more fuel efficient? How could our cars be made to be more fuel efficient and keep output the same? Perhaps it's not possible.
Blah blah, so those are my thoughts for today. I wonder what the fuel economy of the new 10-cylinder will be like and I wonder if in general, more power equals less fuel economy.
I hope some of you thought that was interesting enough to respond to.
-Matthew
'02 M5 -- Carbon Black/Imola
____Supersprint X-Pipe & mufflers
____Dinan short-shift kit
'03 MINI Cooper -- Pure Silver/Black
MT JTN is offline
Old 9th March 2004, 04:23   #2
schnelleM5
schnelleM5's Avatar
Garage: 2003 M5
Re: Tech. theory: Engine Power vs. Fuel Consumption
One need only to look at what BMW did with the brilliant Valvetronic N62 powerplant, which has increased power and torque output as well as improved fuel efficiency compared with the previous M60 motor to realize that sometimes technical innovation and mechanical efficiency can offset the penalty in fuel consumption that is normally associated with boosting output. It is definitely not a linear relationship.
Al
2003 M5 CB/Silverstone (all options except spoiler deletion), HOME AT LAST!
2008 X5 4.8i Sport Space Gray/Tobacco/Bamboo
2002 540ia Sapphire Black
2004 FX35
1999 MB ML430 (3rd row seats)
1992 Jeep Grand Cherokee
1981 320i 5-speed Henna Red
schnelleM5 is offline
Old 9th March 2004, 06:35   #3
Richard in NC
Richard in NC's Avatar
Garage: 2008 BMW 550i
Another thing often added to the performance/economy balance is gear ratios. Often, as is the case of the 325/330, the bigger engined car has a taller (lower numerically) diff. ratio. This reduces the power gained but increases the economy. The V10 M5 may have so much more low end torque, that the 7th gear reduces crusing RPMs and increases economy. The extra gear may also allow closer ratios which can keep the engine at more efficient RPMs for moderate acceleration which also increases fuel economy.
Richard
NEW 2008 550i Space Gray, Creme Biege/Black/Dk Poplar : Sport Package, Cold Weather, Sport Auto, Nav, HUD, CA, Logic 7, iPod/USB, SAT, HD Radio, Lane departure warning
'06 X3 Black Sapphire/Tan PP, Steptronic, Xexons, Heated seats, Privacy glass, UGDO, Compass, bike rack, iPod adapter
Sold '06 650i Black Sapphire/Cream Beige sport package, 6 speed
'02 M5 Titanium Silver/Black Luxury/Burl
Richard in NC is offline
Old 9th March 2004, 12:58   #4
Lscman
Garage: E39
I think the E39 leaves lots of room for improvement in the fuel economy area, thru the use of better gearing, fuel management and variable cam technology. More low end torque and better A/F mgmt at part throttle could significantly improve fuel economy posted by the EPA and the steady-state RPM at highway cruise is too high for efficiency.
The advertized ratings of 13MPG city & 21MPG highway are not impressive. A Corvette with the same cg and 20% less weight gets about 30% better economy. BMW did not sharpened their pencil on the 4.4/5.0L engine design, with respect to economy. BMW V8 5 series customers dishing out $55K or more were not exactly looking for economy .
Lscman is offline
Old 9th March 2004, 14:18   #5
CSBM5
CSBM5's Avatar
Garage: 2001 M5 LeMans Blue
I averaged 21.5mpg running a constant 85mph across Kansas a couple of weeks ago which I found respectable. BTW, the Vette may have a similar Cd, but it's frontal area is much smaller I would think = less drag.
Current stable:
Ground Control camber plates
Stoptech front brake kit
Brake ducts opened
TC Design brackets
1996 Volvo 850R wagon
CSBM5 is offline
Old 10th March 2004, 08:09   #6
greg
greg's Avatar
Garage: 2000 Anthracite
An engine is at its most efficient when it is at full throttle - and at its torque peak, somewhere below redline. The more "excess capacity" you have, the more all that is associated with it becomes a big boat anchor of drag that doesn't need to be there. I don't know what the figure is for an E39, but I remember an article about an RX-7 I once owned said it required only 15hp to maintain 55mph.
Although it strikes some people as completely counter-intuitive, it is a fact then that to get the best mileage, when you accelerate from speed X to speed Y, you should use a lot of your engine's power for a shorter period of time, rather than "drive like there is an egg under your foot." Floor it, short-shift a bit, get up to speed in a hurry, and immediately lift to cruise power, upshifting to the highest possible gear.
SO - more power almost always means lousier mileage - because most of the time you're just dragging it around using significantly less. Lighter weight, lower aero drag, lower rolling resistance tires - can all help. We already have very efficiently managed engines as far as ECU control - I don't see that getting a lot better.
greg is offline
M5 E39 Body Style S62 engine FACTS...Long V-10 4 Me E39 M5 and E52 Z8 Discussion 53 22nd March 2009 16:12
TECH: We don't tune-up a modern M5's engine till 100k, right? Think again. MAVERICK E39 M5 and E52 Z8 Discussion 0 29th September 2002 04:36
Need advice on Dinan Differential ? Fury E39 M5 and E52 Z8 Discussion 61 23rd June 2001 09:01
Break In period Joe Lapicki E39 M5 and E52 Z8 Discussion 21 29th March 2001 22:23
2000 vs 2001 engine power. madmmt E39 M5 and E52 Z8 Discussion 1 28th January 2001 17:37
Page generated in 0.14786 seconds with 11 queries
