Bill,
I tried to bite my tongue for as long as possible, but in the end I couldn't resist. So I have to add to what you said..... "Silly rabbit, Trix are for kids" And M5's are for slightly bigger kids. Like us!!!
And Lscman,
Thanks a lot!! Now you have me checking out every lavender car I see. Unfortunately there are still quite a few still around here. Ahhh, I can't ignore them! I owe you one!
Anita
"When will I know that I really can't go
To the well once more time to decide on
When it's killing me, when will I really see
All that I need to look inside
Come to believe that I better not leave
Before I get my chance to ride" RHCP "Snow"
Just to make it even more correct, here are a few things:
There is a major deifference between European M5s and US: The bloated US
dashboard panels.
There are at least two sighted touring M5s, one in Germany and one in the
US.
The trim panels are not Aluminium, those are Titanium.
The 18" wheel finish is called Shadow Chrome.
The wheel arches are wider than the standard E39.
The M5 is actually 2 mm taller than the standard E39, although the larger
wheels make it look as if it was lower. (The lowering of the suspension relative
to the body, is more than consumed by the increase in wheel diameter.)
ASC means Acceleration Stability Control.
From factory the cars were equipped with Michelin Pilot Sport I tyres, or
Dunlop Sport SP 8080 tyres.
There were important changes to the Vanos system:
Starting November 2000 the M5s got Vanos oil pressure accumulators
installed from factory.
Starting mid July 2000 (engine number 60232305) got Vanos spline-shafts
with improved tolerances.
Starting mid September 2001 (engine number 60572609) got new
stronger Vanos spring discs and thinner pressure plates.
The front seats have two additional heater elements on the sides of the
deeply contoured sports seat. (Those sport seats normally only have two
heater elements: back and seat. Them M5 has back, seat and sides.)
David
