Cheap Track Tires - Page 3 - BMW M5 Forum and M6 Forums
Old 27th February 2004, 03:41   #21
Teutonaddict
Teutonaddict's Avatar
Garage: '00 Carbon Black/Black All-Leather/Sportive
Re: Cheap Track Tires
Originally Posted by Richard in NC
Correct, you don't need R compound track tires and they are not needed/recommended for beginners.....A set of tires for the track avoids killing the far more expensive street tires.
That was my reason for making the jump. I discovered a nail in my street tires the night before one of my first events, so I mounted up a brand-new tread up front. After my very first weekend at Sebring, it looked like I'd traveled 30K hard miles! Of course, Sebring is like a cheese grater on tires, but keep in mind I was a real novice running at relatively low speeds.
Having dedicated tires for each purpose has extended the lives of both: I've surpassed 28K miles on my Pilot Sports, after getting 22K on my OE Dunlops.
BOTH SOLD!!
#101421
Teutonaddict is offline   Reply With Quote
Old 27th February 2004, 03:45   #22
Teutonaddict
Originally Posted by CSBM5
Are the Type E's available in a wider width than 8"? I assume that you must run at least 9's on the rear?
Correct. I believe they're 9.5" I've never seen the wider widths in their ads or on their website. For the last couple of years, I've been dealing with Luke at the Tire Rack.
FWIW, I did run 245/45-18s all the way around on my '98 540i/6 (before BMW was equipping the sport package E39s with staggered widths). However, with all that torque on tap, you'll want and appreciate the 275s.
-Dave
Old 27th February 2004, 04:33   #23
rebel1
rebel1's Avatar
Garage: that way
Originally Posted by TexasM5
By the way, I'm thinking about entering several track events a year and I already have the BBK, so I might end up with a new suspension setup (haven't decided which yet). If so, getting some track wheels and tires might be my first step. Any recommendations for a high quality track wheel with the understanding that cost is more important than appearance? I don't know that I need $2,400.00 worth of SSRs.
Thanks again,
TexasM5
What type BBK kit do you have? Check with Dave Zeckhausen on fitment of wheels with your brakes. His site has some wheel options that fir Stoptech and Brembo.
I have SSR comps with pilot cups, Brembos and dinan stage three with strut braces. It is an outstanding track set up, yet civilized enough for the street.
Hope this helps
rebel1 is offline   Reply With Quote
Old 27th February 2004, 06:14   #24
Redshift
Redshift's Avatar
Garage: 01 M5 / 03 540iT / 10 K1300GT
Sales Feedback: (12)
My skills are rusty after lack of use for so long, plus the M5 is vastly more powerful than the old Bavaria. The Bav could hold its own against the E28 M5 however. Anyway, I will need some ramp up time for sure. I'm sure you can clean my clock at VIR
I'll have to check out the next monthly dinner -- let me know if you plan on going.
Here's the link to Ray's open house They always have decent door prizes and good food. I've know Ray for 23 years now...we took my Bavaria to Mid-Ohio back in 1981 and Ray proceeded to clean up in the Instructor's sessions against 911SC's and such. I dominated the A sessions as there weren't too many triple-Weber Korman engine/trick suspension cars back then...just a bunch of 528i's and 320i's. He's a great story teller and just a fine person. I think you would enjoy the event. I would love to drive the M5 to it, but I have to take the 540i to hopefully interest a buyer for it.
I'm sure this qualifies me for old fart status, but attached is a shot of the Bav in turn 3 at Summit Point circa 1987.
So far looks good for both events. Need to see if I can cajole the wife into attending the open house
Brian
03 540iT Sapphire Black - 01 M5 LeMans Blue - 02 330Cic Orient Blue - 10 K1300GT Blue - 02 996 C2
*** Parting out entire 03 CB/Imola/Black M5 *** - TONS OF PARTS AVAILABLE
Redshift is offline   Reply With Quote
Old 27th February 2004, 06:37   #25
TexasM5
TexasM5's Avatar
Garage: TiSi 2000 M5
I have the front StopTechs from Dave. I emailed him and am waiting to hear back since I know that at the very least I am going to need to switch brake pads. I'm going to price out some of the wheel/tire combos I've heard about here and talk with my Dinan dealer about suspension possibilities.
Thanks,
TexasM5
TexasM5 is offline   Reply With Quote
Old 27th February 2004, 15:22   #26
Teutonaddict
TexasM5-
FWIW, I run the StopTech 355mm front kit and have no clearance issues with the 17" Borbets. Dave Z recommended Performance Friction 01s for the track, and I found them to be superb. For the very first time, I experienced ZERO fade.
BTW, I still run my street pads (Axxis Deluxe Plus, also from Dave) on the rears. Even with different pads, the balance was not adversely affected, and my rotor and caliper temps still were much lower in the rears than the fronts (per my laser temp probe).
FWIW(2): I tracked for three full seasons before upgrading to the StopTechs. Previously, I ran the opened M-Technic euro brake ducts, high-T fluid, and intermediate track pads (Mintex C-Tech 1144 compound). That worked reasonably well (still had to manage fade) as my lap times decreased.
I can't tell you how liberating it was to do an entire track weekend without once considering brake fade! Whereas I used to lift before the end of the long straights, I now accelerate right up to the brake zone. Woo-hoo!
-Dave
Old 27th February 2004, 20:30   #27
M5ROKIT
M5ROKIT's Avatar
Garage: BMW M5 Le Mans Blue
According to the Tirerack the Michelin Pilot Sport Cup does not fit the stock M5 wheel. What wheel dimensions would be optimal if going with that tire? I'm not sure what sizes they come in as I'm off the site now. I sent an email to the corporate office asking when, or if, the cup will come in stock wheel sizes.
Le Mans Blue with blue panels
Brake ducting
Stoptech big brake kit (black)
Slotted front/rear Aero Rotors
stainless steel front and rear brake lines
Dinan CAI w/stage 2 software
Dinan Stage III suspension w/JRZ
Dinan Front Strut Brace
275 fronts/rears
Nitto NT01 Track tire
Beast Power Rear Sway Bar Brackets
Powerflex Poly Bushings
Hawk HT-10 (for track, Axis Ultimates (street)
Eisenmann race exhaust 80mm
TEC cupholder
Euro arm rest
Autosolutions 25% short shift kit
Valentine One radar detector
AJ-USA Alluminum pedal set
Shroth harnesses (track)
<embed src="http://videos.streetfire.net/vidiac.swf" FlashVars="video=2bc84021-a84b-4ea5-9ac6-61c725f72e93" quality="high" bgcolor="#ffffff" width="428" height="352" name="ePlayer" align="middle" allowScriptAccess="sameDomain" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer"></embed>
Jaguar E-Type V12 1973
M5ROKIT is offline   Reply With Quote
Old 27th February 2004, 20:32   #28
M5ROKIT
M5ROKIT's Avatar
Correction: According to [B]Michelin [/b] website the tire does not come in the stock wheel sizes.
Old 28th February 2004, 00:59   #29
Richard in NC
Richard in NC's Avatar
Garage: 2008 BMW 550i
Originally Posted by M5ROKIT
Correction: According to Michelin website the tire does not come in the stock wheel sizes.
M5ROKIT;
That is why I ended up with Kuhmos and ATS Type 10 wheels.
BTW; I believe the wheels are 17x8 front and 17x9 rear.
Teutonaddict;
I went with the Axxis Deluxe Plus pads hoping to have street pads good enough for occasional track use. Unfortunately, they weren't bedded in properly and with the rain during the whole weekend at the track, I ruined all 4 rotors. After shelling out the bucks to replace the rotors (with factory units since it is a leased vehicle) I am afraid to put non-stock pads on it again. I'll have brake ducts and fresh high-temp fluid hoping that is enough for my experience level.
Richard
NEW 2008 550i Space Gray, Creme Biege/Black/Dk Poplar : Sport Package, Cold Weather, Sport Auto, Nav, HUD, CA, Logic 7, iPod/USB, SAT, HD Radio, Lane departure warning
'06 X3 Black Sapphire/Tan PP, Steptronic, Xexons, Heated seats, Privacy glass, UGDO, Compass, bike rack, iPod adapter
Sold '06 650i Black Sapphire/Cream Beige sport package, 6 speed
'02 M5 Titanium Silver/Black Luxury/Burl
Richard in NC is offline   Reply With Quote
Front Big Brake Kits ... Are they truly better?? gra8fuldd ed E39 M5 and E52 Z8 Discussion 38 30th December 2003 13:16
I ordered new tires and am selling 4 stock wheels with track Kumho tires BeastPower Parts / Other For Sale or Wanted 3 10th January 2003 16:19
Tire decision time - track tires or not? Richard in NC E39 M5 and E52 Z8 Discussion 4 7th January 2003 04:44
Our first track day(long) Adam E39 M5 and E52 Z8 Discussion 7 20th August 2001 23:52
track rims and tires, need input Jeff L E39 M5 and E52 Z8 Discussion 0 25th June 2000 19:47
