MAF meter cleaning - BMW M5 Forum and M6 Forums
post #1 of 19 Old 17th February 2004, 05:24 PM Thread Starter
pvapour
MAF meter cleaning
Hi all
Think I might have a problem with my MAFs, done a search and read most posts but can't find anything relating to which part you actually clean, is it the: flat metal plate, the wire loop with a diode in the middle or the three little wires atatched to the metal plate?
Am I also right in thinking that the meters work by getting hot, then when the cool air flows over, they measure the amount of cooling and hence amount of air flow? as my car does seem to have more power when I first set out but as the engine warms the power slowly tails off, is this consitant with MAF sensor failure?
Cheers in advance for any help, waiting by.....
Nik
pvapour is offline
post #2 of 19 Old 17th February 2004, 06:27 PM
TCM
TCM's Avatar
Re: MAF meter cleaning
To clean the MAFS, you need to remove the sensor section (whole black unit) from the cylinder and then stick it in a cup of diluted Simple green and water. Leave it there for about 10 minutes and then try to clean off the wire with a soft brush or something similiar. Hope this helps.
T.C.
'01 Brushed Steel M5
front splitters
3.45 differential
'01 Silverstone M5- sold
SuperSprint:X-pipe
TCM is offline
post #3 of 19 Old 17th February 2004, 11:15 PM Thread Starter
pvapour
thanks TCM, will get onto it, have seen the pictorial step by step guide aswell now.
What about the symptoms I mention, is that consistant with MAF failure? is there a way of measuring if they're working correctly? by a main dealer or yourself?
Cheers, Nik
pvapour is offline
post #4 of 19 Old 17th February 2004, 11:23 PM
marinakorp
Not so sure how the simple Green will affect the MAF... since the SG is a cleaner/degreaser, there might be a residue issue to contend with. I have seen (at Autozone, etc) sensor/ electronics cleaner... this might be closer to what you are looking for...
.02
99 540iT
Powerchip Gold 93
M5 Rear Swaybars
Shadow Badging / Grill
marinakorp is offline
post #5 of 19 Old 18th February 2004, 01:09 AM
XrayMD
XrayMD's Avatar
I have used the Simple Green but would advise against it or at least, make sure you rinse it off completely...it can be corrosive from what I hear. I think that the spray electronics cleaner is a better solution. Just make sure that the one you get does not have any lubricant in it so there isn't any residue.
Steve
'02 M5 LeMans Blue:
Supersprint Headers and cats
Dinan Stage III suspension
BeastPower sway bar brackets
Dinan front strut tower brace
RMS short shifter
Llumar window tint (35%)
XrayMD is offline
post #6 of 19 Old 18th February 2004, 01:17 AM
Tin
Tin's Avatar
Here's a very good guide!
MAF Cleaning.. DIY way
Cheers
Tin
Kelleners ECU remap, Kelleners uprated Sport Camshafts, Kelleners Custom 3.45 Rear Diff, ACS DFC Suspension, 19" ACS TypeIII's, Brembo GT Kit (F:8pot/380mm front,R:4pot/345mm), Supersprint RHD headers,100cel sport cats,x-pipe and 90mm backboxes, ACS Rear Diffuser, Evosport lightweight pullies, Dinan Front & Rear Strut Bars, Dinan Rear SwayBar,ACS pedals & handbrake, GruppeM induction kit, AA CAI,IgnitionSolution PlasmaCoils, Rouge SSK with weighted rod, BeastPower brackets, NAV-Tv, MKIV Widescreen retrofit,2x10" M-Audio Subs, Hardwired V1,Xenon interior lights
Tin is offline
post #7 of 19 Old 18th February 2004, 02:06 AM
Need4Spd
Need4Spd's Avatar
Good instructions but I suggest (1) using a non-residue electronics cleaner instead of Simple Green; and (2) using gummi phlege instead of Vaseline on the gaskets. Finally, recommend installing your IATS in the airbox while you have it out of the car!
Need4Spd
'01 M5 (now my brother's car) UUC SSK + Rogue WSR/RE Tranny Mounts+Royal Purple Synchromax/Axxis ULT Pads/StopTech SS Lines/TC Design from BeastPower Anti-roll Bar Brackets/Dinan LtWtFlywheel and Stage 3 suspension/4xOEM rear 275 Goodyear F1 Asymmetrics/Vines thrust arms/IATS relocation/10w-60 oil/hardwired Escort 9500i/Euro Armrest/TEC Cupholder/IceLink/PowerChip 91 Gold/TUBIs!/Strong Strut/BSW Stage 1/BT/Angel iBrights 3.0/space-saver spare by Bimmerzone
'11 Jaguar XFR, Quicksilver exhaust, Escort 9500ci
Unnamed weekend Italian 2 seater with DCT
Future - F10 M5 with manual transmission?
Need4Spd is offline
post #8 of 19 Old 18th February 2004, 03:17 AM
robertdn
robertdn's Avatar
I've experienced the same problems as some folks here in various degrees the last months, during the last couple of days it completely stopped revving above ~4000rpm's. Luckily for me, some brilliant and informative minds on this forum had been creative, tested and described this solution in such a good way that i was able to both recognize and fix the problem.
BTW: When they run a diagnose thru OBDII on the car, it showed faulty lambda readings and a loong list of other problems. (with occurency over 160 times on some of them!)
So a HUUUUUGE thanks to those of you that saved me a lot off ($$$)!!
The work took me about 20min to complete, and the car works perfectly now, didn't even know the M5 could be as fast as my car is now....
If all car problems could be as easy as this.... !!
Again, THANKS!
Robert DN
'99 Carbon Black M5.
-19" BBS LM -Kelleners Exhaust -Custom chip. -2001 facelift. -2005 engine -H&R Coilover -Sachs Race Engineering clutch -Modified flywheel -Vorsteiner CF hood
-16:9 display/MKIV Nav, BM54 radio, changer with mp3/wma support.
robertdn is offline
post #9 of 19 Old 18th February 2004, 04:19 AM
louv
louv's Avatar
Two suggestions,
1) Use Electronics "Contact Cleaner" instead of Simple Green. I'll update the webpage someday. If you do use Simple green, dilute it and then be sure to clean/rinse with 99% alcohol. Simple Green is very alkaline, so don't use it on aluminum or it will etch.
2) If that doesn't fix it, try replacing your "Pre-Cat" O2 sensors before buying new MAFs. Much cheaper, and in my experience, more likely to be the problem.
'01 Tundra, '15 X6M, '15 i8, '15 Miata
'09 R1200GS-Adv, '10 G450X
louv is offline
post #10 of 19 Old 18th February 2004, 09:12 AM Thread Starter
pvapour
Unhappy Re: MAF meter cleaning
Thanks for the replies guys,
I have had the MAFs off the car now and cleaned them with a non lube contact cleaner only, just to be safe, to be honest they were not really that dirty but the surface area of the metal plate is quite pitted and not bright and shinny as some have said theirs are, these are the original MAFs on the 75k mile car (european). The car is still behaving the same, down on power when the engine is cold but even more down on power when the engine is hot?
Before changing the MAFs I shall look at the 'pre cat' O2 sensors (thanks Louv), but unsure where these are located for one, and two, is there a definitive test for these sensors to see if they're faulty, this question also applies to the MAFs, would a dealer be able to test the MAFs directly?
Cheers for all the information guys, much more help than I'm getting from anyone this side of the pond
Nik
pvapour is offline
KN filter and MAF....Lost power? Gaspasser E39 M5 and E52 Z8 Discussion 11 18th January 2015 04:22 PM
TECH: Clean your MAF, don't replace! louv E39 M5 and E52 Z8 Discussion 42 12th November 2010 01:45 PM
Spring cleaning DINGOLFING E39 M5 and E52 Z8 Discussion 2 4th February 2004 05:38 PM
Easy incar MAF testing: measurements wanted DavidS E39 M5 and E52 Z8 Discussion 5 31st October 2003 11:47 AM
Guys that experienced problems with their MAF.................... FAST 5 E39 M5 and E52 Z8 Discussion 16 28th October 2003 09:52 PM
