Vibration at 70-80 mph?? Frustrated - BMW M5 Forum and M6 Forums
post #1 of 12 Old 8th February 2004, 08:40 PM Thread Starter
V-10 4 Me
V-10 4 Me's Avatar
Unhappy Vibration at 70-80 mph?? Frustrated
I might be a little premature in selling some of my new components, but I was a little frustrated. I am getting a slight vibration between 70- & 80 Mph. I can feel it in the steering wheel and even slightly in the seat, so it feels like its the entire car. One has to really pay attention to sense the vibration but it is in fact there
So, I had all 4 tires balanced on a Hunter balancer. Still have vibration. Put Rear wheels on the front and still have same vibration.
I thought it might be because of the Poly eurathane bushings or from going from a 40 mm tire to a 35 mm front tire. I thought it might have always been there but the above 2 mods might be sending the viration to where i can feel it now.
That's why I was thinking about going back to stock. If I couldn't figure it out the Dealer would say that its the large wheels or the sways dso i wanted to elimninate that response before i went to the Dealer. Could it be the Shocks or the front wheel bearings? Any guesses?
V-10 4 Me is offline
post #2 of 12 Old 8th February 2004, 09:05 PM
Butzy
Butzy's Avatar
Re: Vibration at 70-80 mph?? Frustrated
HI
I know this problem from other BMW's well. Befor you are changing the parts check the joints of the power train.
Over 55mph the vibrations are coming from the rearaxel.
Good luck
Butzy
Butzy is offline
post #3 of 12 Old 8th February 2004, 09:09 PM
gsfent
gsfent's Avatar
If you think it is a wheel/tire balance problem, try to get the tires statically balanced on the wheel first, then do an on car dynamic balance. That will take the entire wheel assembly into consideration. If there is another lister nearby, maybe you could swap your wheels and tires with his/hers, and then either eliminate or pinpoint the wheel tire combo as your problem. The fact that you have front and rear vibration would seem to indicate wheels and/or tires.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, Sachs high performance PP and CCC proprietary clutch disc, stock DMFW, open brake ducts, Hamann front splitters, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, 6k super white low beams, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge, Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup.......
gsfent is online now
post #4 of 12 Old 9th February 2004, 01:16 AM
jeeperjohn
Shave tires
Sam,
I would take the wheel and tires to a shop to have them balance and true the tread up by shaving before I would give up on your tires. If that does not cure your vibration, look at the driveshaft/u-joints, CV joints, and wheel bearings if you are hearing bearing noise. Best to take it to a knowledgeable shop that works on 5's (Dinan, etc).
Good luck, John
2002 M5 titanium silver
19701/2 Chevrolet Camaro SS396/375 HP
1973 Chevrolet Z-28
1986 Jeep CJ-7
1960 Willys CJ-5
1946 Willys CJ-2A
jeeperjohn is offline
post #5 of 12 Old 9th February 2004, 09:48 AM
greg
greg's Avatar
Can be a flat spot on a tire, or a bent driveshaft....
greg is offline
post #6 of 12 Old 9th February 2004, 12:47 PM
thompsw
thompsw's Avatar
I had a set of tires on a Honda Accord, many years ago, that were out of round -- no amount of balancing would get rid of the vibration -- went away with new tires.
thompsw is offline
post #7 of 12 Old 10th February 2004, 10:37 PM
Buzz
Buzz's Avatar
I get this too. Noticeable vibration between 70-80. Starts happening right at about 72mph, and it almost acts like a speed indicator for me since I can't see the gauges that well while the steering wheel is in a comfortable spot. The vibration does not happen at all if I am below 70 or above 80.
Buzz
00 Jet Black / Black All Leather - Sport Trim (Wrecked)
01 Audi S8 Black / Black and Charcoal (Sweet, but no substitute)
Buzz is offline
post #8 of 12 Old 11th February 2004, 12:24 AM
AJ
balance your rears on a hunter dsp9700. while at it- check the fronts too. but if you are feeling it in the seat it is the rears... or as somebody else mentioned your driveshaft might be imbalanced. the shaft is balanced with small weights glued to the shaft and sometimes they might fall off.
alex
02 gts
few other cars
AJ is offline
post #9 of 12 Old 11th February 2004, 12:37 AM
Serb
Serb's Avatar
On my old 97 M3, I had the exact problem. I was going to replace the tires because we looked at every option and couldn't find a solution UNTIL... we found out that there was a small bit of water that was in the tire. No joke! It caused the vibration. We took the tire off the wheels, remounted them, and bingo... no more vibration. I don't know if this is the case for you, but if it is, its a very simple solution to a complex and annoying problem.
Bojan
"I love its intake howl, exhaust burble, communicative steering, rock-solid chassis, and the way it pulls at my gut on a hard launch. It knows what it is, and it's damned good at being it."
Serb is offline
post #10 of 12 Old 11th February 2004, 06:39 PM
marinakorp
The E39's seem to be plagued with the shimmy at 55-80 mph
there is a host of things to check
1 - tire pressure
2 - balance
3 - alignment
4 - Thrust Arm bushings
The e38's also have this problem... #4 has fixed MOST of their and our problems
99 540iT
Powerchip Gold 93
M5 Rear Swaybars
Shadow Badging / Grill
marinakorp is offline
M5 vs the Audi RS's matthewpenn E39 M5 and E52 Z8 Discussion 32 25th January 2006 03:43 AM
Local Cops Got Laser! Lidatek Question. JFB E39 M5 and E52 Z8 Discussion 42 6th August 2005 08:17 PM
KirklandM5, when are you doing the Dinan LSD tests? kenneth E39 M5 and E52 Z8 Discussion 45 28th July 2001 08:57 PM
How fast does the M5 do the 1/8 mile in? EBMCS03 E39 M5 and E52 Z8 Discussion 17 18th July 2001 06:09 AM
Run in with a card board box at 70 MPH Tom M5 E39 M5 and E52 Z8 Discussion 2 28th October 2000 10:26 AM
