Old 30th January 2004, 20:21   #1
Bigtime007
Bigtime007's Avatar
Garage: 2001 BMW M5 Velvet Blue
Send a message via AIM to Bigtime007
Check engine light will not go away
Has anyone here experienced this after installing any of the following:
1. Exhaust
2. Intake
3. Velocity stacks
My check engine light came on shortly after the v stacks were in place. The techs dont know that they are in there, but cannot figure out what the problem is.
Any insight appreciated.
2001 BMW M5 (Sold)
Velvet Blue Metallic/Silverstone Int.
OZ Superleggera 19x9 front, 19x10.5 rear. Dunlop 245/285 SP Sport 9000
6000k upgrade
Kellener Sport Exhaust
Kellener Sport Pedals
Euro Clear Headlights
Functional Brake Ducts
3M StoneGuard
Rogue Engineering Short Shift Kit with Weighted Selector rod
Hamann Black kidney grills
Ac Schnitzer Roof Spoiler
Home Depot Sweetheart Sink covers
Supersprint X-pipe
Fk Konigsport coilover suspension
Technik swaybars (front and rear)
Smoked hella tail lenses.
Brembo 380mm Front Kit
Brembo 345mm Rear Kit
Stainless Brake Lines
Gruppe M Carbon Kevlar Intake
2003 Mercedes CL600 Twin Turbo
493hp\590lb.ft.
Eisenmann Race quad tip exhaust
Renntech Monolicht Wheels 19x9 fr. 19x10 rr.
Good Year F1 Supercar tires 245/40/19fr 275/35/19 rr.
Renntech Rear lip spoiler
Renntech Ecu and lowering module to come
Bigtime007 is offline
Old 30th January 2004, 20:24   #2
Suretyagent
Suretyagent's Avatar
Garage: 2001 M5 Carbon Black
Re: Check engine light will not go away
Dear Bigtime:
Have you cleaned your MAFS lately? Just a thought.
Derek
Suretyagent is offline
Old 30th January 2004, 20:27   #3
Bigtime007
Bigtime007's Avatar
Originally Posted by Derek Sadowski
Dear Bigtime:
Derek
MAFS=mass air sensor?
Jeff
2001 BMW M5 (Sold)
6000k upgrade
3M StoneGuard
Supersprint X-pipe
493hp\590lb.ft.
Old 30th January 2004, 21:22   #4
Suretyagent
Sorry Bigtime:
Mass Air Flow Sensors. If you are using a new, free-flow air filter it may be getting oil on the MAFS causing the fault. I hope it's that simple.
Derek
Old 30th January 2004, 23:15   #5
foreman
Garage: M3
What fault comes up ???
Foreman.
foreman is offline
Old 30th January 2004, 23:17   #6
Bigtime007
Bigtime007's Avatar
Foreman.
WAS THE CAT THE FIRST TIME. THEY REPLACED IT. NOW THEY HAVE NO IDEA.
2001 BMW M5 (Sold)
6000k upgrade
3M StoneGuard
Supersprint X-pipe
493hp\590lb.ft.
Old 30th January 2004, 23:18   #7
Suretyagent
I don't know what fault code shows up for MAFS - never had it come up.
Old 30th January 2004, 23:25   #8
RRoberts
RRoberts's Avatar
Garage: 2001 M5 - Alpine White
This matches the experience of some others on the Board, if I recall correctly. First BMW replaced the catalysts w/o fixing the problem, then the MAF sensors which cleared up the problem - and made more power. You might find something with a search on MAF.
Regards, Dick Roberts
RRoberts is offline
Old 30th January 2004, 23:28   #9
Bigtime007
Bigtime007's Avatar
HOW DO I CHECK THE MAF? CAN I CLEAN IT MYSELF?
2001 BMW M5 (Sold)
6000k upgrade
3M StoneGuard
Supersprint X-pipe
493hp\590lb.ft.
Old 30th January 2004, 23:32   #10
foreman
Garage: M3
An actual fault code would help.
It is hard to guess.
could be a leak at the intake plenum or, or ,or.
Ask your service what the fault codes are...
foreman
foreman is offline
Nowack Tuning Report, The Truth (Long Version) CharlesW E39 M5 and E52 Z8 Discussion 61 7th January 2009 11:06
Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 05:49
pre-purchase inspection paolo E34 M5 Discussion 8 28th April 2002 23:46
SL 55 vs Z8 at the Nurburgring! mmunson E39 M5 and E52 Z8 Discussion 64 21st April 2002 02:42
Inspection I & II checklist please IvanDias E34 M5 Discussion 2 2nd November 2001 15:31
Page generated in 0.15566 seconds with 11 queries
