Re: OEM M5 suspensions, will it fit other E39s?
You could certainly sell the swaybars. I've read posts on the roadfly e39 board that M5 springs end up making a 540 with a higher ride height than the stock 540 sport springs. You could probably make an off road capable 528 with them!
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
