Old 13th January 2004, 22:39   #1
Redshift
Redshift's Avatar
Garage: 01 M5 / 02 330Cic / 03 540iT / 94 M3
Sales Feedback: (11)
How to tell if wheels are legit OEM?
Found a local guy selling a full set of four OEM M5 wheels (or so he thinks) with tires. When I go to check them out, how can I tell if they are legit or some knock-off wheels? Don't want to pay for them if they are not OEM.
Thanks.
Brian - CCA #273611
Tarheel BMW CCA Street Survival Chief Instructor
03 540iT Sapphire Black - 01 M5 LeMans Blue - 02 330Cic Orient Blue - 94 M3 w/S50B32 Imola Red 08 F800ST Blue
*** Parting out entire 03 CB/Imola/Black M5 *** - TONS OF PARTS AVAILABLE
Redshift is offline
Old 13th January 2004, 22:50   #2
DrewT
Garage: 01 M5 jet black caramel interior
Re: How to tell if wheels are legit OEM?
sounds suspicious, where did he get the wheels? who makes oem bmw wheels? it used to be bbs but I am not sure anymore, call tirerack and ask.
DrewT is offline
Old 13th January 2004, 22:52   #3
Redshift
Redshift's Avatar
From a friend who owned an M5 and bought aftermarket wheels, then was involved in an accident. That's what he said anyway. What makes me suspicious is that he's asking $1000 for all four wheels with tires that have "less than 10,000 miles on them".
Brian - CCA #273611
Redshift is offline
Old 13th January 2004, 23:47   #4
GreekM5
GreekM5's Avatar
Garage: 2002 M5
Send a message via AIM to GreekM5
Compared to photos that I have seen, the OEMs have the little "///M" emblem on the rim, whereas the knock offs usually don't. That is not a fool-proof method, but just one to add to the list.
There must be a part number listed somewhere. Call BMW and find out.
-Keith
2002 M5 Titanium silver/Luxury black/Burr walnut
GreekM5 is offline
Old 14th January 2004, 00:30   #5
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
i think the better 'replica' m5 wheels also have the little indentation for the "//M" emblem. I do not think they are the same width however. I thought the replicas were non-staggered..., maybe compare the finish to your wheels, i'd bet it's slightly different than bmw's method of painting the wheels.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 14th January 2004, 00:49   #6
tsaros
Guest
tsaros's Avatar
Garage: 540i6 -99 , Cosmossblack
Im guessing that the weight of the rims would differ as well.
Most likley the OEM rims would be the lighter ones.
tsaros is offline
Old 14th January 2004, 00:50   #7
LSU1981
LSU1981's Avatar
Garage: 2000 M5 Avus Blue
Send a message via AIM to LSU1981
I'd guess that the knockoffs are significantly heavier so in addition to the other suggestions - I guess you could weigh one of your cars's front and rear wheels with tire; then weigh the suspect wheel/tire combos. If the weight is significantly different .....
2000 M5 Avus Blue / LeMans Sport. (sold to MPRESIV, 9/04)
2002 M3 Carbon Black/black
2004 Sierra Denali
2008 335xi - on order
Gone - Shelby Cobra Roadster, 01 Carrera C2 Coupe, 00 M5
LSU1981 is offline
Old 14th January 2004, 00:52   #8
Redshift
Redshift's Avatar
All good suggestions, however I don't really have a way to bring a scale with me to the inspection point (a parking lot at a mall).
I was hoping for some markings that I could look for on the back of the wheel perhaps.
If these end up being legit and I buy them, I'll put the fronts (and my fronts) up for sale as a full set or as two sets of two.
Brian - CCA #273611
Redshift is offline
Old 14th January 2004, 01:35   #9
Jim Dolan
Jim Dolan's Avatar
Garage: 2006 M5 Silver Grey Metallic
Checked out your touring. We owned the same car until a year ago. Great photos of a great car.
Jim
2006 Silver Gray Metallic over Black
The "Wolf in Sheeps Clothing" is back in the USA again
1971 2002 Colorado(Light Orange)
1976 2002 Inka(Red orange, a classic)
1982 528e Blue metallic
1984 533i Burgandy
1987 325i Alpine white
1988 535is Salmon silver
1993 525iT Calypso red
1999 528iT Titanium silver
2000 M5 Titanium silver
2006 M5 Silvergray
Jim Dolan is offline
Old 14th January 2004, 02:18   #10
RRoberts
RRoberts's Avatar
Garage: 2001 M5 - Alpine White
OEM Wheels have numbers cast/stamped into the inside of the center section. These may be the same as the BMW part numbers, which you can get from the dealer or possibly online (you may want the German part numbers, usually different from the U.S. part numbers). A 3 year old Bekkers catalog shows 368018 as the part number for the original 8 x 18 front wheel, and 369518 as the part number for the original 9.5 x 18 rear wheel. At best, these are partial BMW part numbers. Bekkers might be able to give you the full part numbers, and/or the identifying marks on the inside of the wheel if they are in a good mood. I'd offer to pull off the wheels and check, but it's really cold outside.
Note that some of the "Chinese copies" of the OEM wheels are made in different dimensions - such as 8.5 in. width or even different diameter - so make sure that you check the dimensions. The presence of OEM tires (Dunlop 8080E or Michelin Pilot Sport) in the correct sizes would be a positive indication.
Beware that you are not dealing with the Midnight Auto Supply boys.
Regards, Dick Roberts
RRoberts is offline
getting new wheels, selling OEM M5 wheels... VicM5 For Sale or Wanted 11 3rd October 2002 07:21
OEM wheels vs. SSR GT weight and performance? rebel1 E39 M5 and E52 Z8 Discussion 0 18th July 2002 02:44
2001 BMW M5 E39 OEM Wheels and Tires Jeff_Rodgers For Sale or Wanted 4 16th July 2002 23:51
Who makes the OEM wheels for BMW? Who makes the best aftermarket wheels? Magna E39 M5 and E52 Z8 Discussion 2 4th March 2002 06:18
Who makes the OEM wheels for BMW? Ronal? And what are some good aftermarket brands? Magna E39 M5 and E52 Z8 Discussion 11 1st January 2002 01:37
Page generated in 0.17154 seconds with 11 queries
