Old 12th January 2004, 10:32   #1
skstx
Garage: 2001 M5 Silverstone
M5 VANOS pack problems?
Took the car to the dealer this weekend because of a check engine light...the computer reported "89 trips or code violations" due to the Rt. Bank VANOS pack. The dealer plans to replace both VANOS packs. Is this o.k.? What's the history on these "packs"? The dealer said he had done quite a few M5's, especially the early 2001 models (which mine is a very early 01). Is this a simple fix, or is something else about to go wrong? Thanks.
Steven
skscott@msn.com
skstx is offline
Old 12th January 2004, 10:50   #2
JJJ
Garage: E39 M5 Anthracite / Silverstone
Re: M5 VANOS pack problems?
If your dealer is replacing both then lucky you.
No problems here as long as it's a warranty job. I've had both banks changed, but you may find that there are a few other faults that need other items replaced....just let your dealer deal with it.
Ex E39 M5 owner
JJJ is offline
Old 12th January 2004, 17:51   #3
TCM
TCM's Avatar
Yes, this is very common on all early model M5s. As long as it is under warranty there are no problems. If it is not, the cost would be extrememly high as the parts are expensive and the labor is intensive. You will notive a drastic reduction in regards to the dieseling noise that is found in the M5 also.
T.C.
'01 Silverstone M5
SuperSprint:X-pipe
TCM is offline
Old 12th January 2004, 20:00   #4
DavidS
DavidS's Avatar
Garage: 2000 M5 LeMans blue
Sales Feedback: (4)
Steven
skscott@msn.com
If they replace both Vanos units under warranty, be happy, and when they are done give your SA something nice!
David
DavidS is offline
Old 12th January 2004, 21:05   #5
skstx
Thanks for the information. I have noticed an unusual sound at idle and its gotten worse over the last week and the car seemed to have hesitation at idle too....sounds like this will fix it. He is planning on replacing both of them, so it sounds like I'll be set!
skstx is offline
Old 15th January 2004, 01:40   #6
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
interestingly, my car makes more dieseling type noise at idle with a new vanos, than with the old. Maybe my other one is going out.....
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 15th January 2004, 04:11   #7
skstx
I just got the car back today and all is great! What a difference. The car does run much smoother...even sounds different. Shifts seem smoother too....not sure why....maybe psychological!
Steven
skstx is offline
Old 15th January 2004, 07:18   #8
TCM
TCM's Avatar
Steven:
Glad to see you are happy with the outcome. My car did not feel any different after the VANOS upgrade, just quieter. I no longer sound like a truck stacking on a cold day at a stop light.
T.C.
'01 Silverstone M5
SuperSprint:X-pipe
TCM is offline
Wooo tfung gone off deep end... EBMCS03 Off Topic Forum 4496 Yesterday 09:15
Rumours about the E39 M5 pre 1998. Gustav F10 M5 Discussion 15 21st October 2009 01:11
German AMS magazine tests M5 suspension kits lofstrom E39 M5 and E52 Z8 Discussion 25 11th April 2008 13:24
Page generated in 0.13408 seconds with 11 queries
