Pics: of Random Metal cats(and resonators,not random)
I took some shots of Randoms cats to show,also are some resonators that are going on since the header install has made the B&B's VERY loud.
The resonators will be put on with v-band clamps so if need be I can swap from straight pipe(like it is now with the S/S xpipe) or for the quieter days undo the pipes and put the resonators in place.If it's confusing I'll post pics after it's done to clarify.
I had to slightly turn the cats for the pics because to much sun was comeing straight thru and makeing quite a glare,pretty much like looking directly at the sun.
As for the res. I don't know how much they are going to quiet it down they seem pretty straight through, internal dia. is just a smiget under 2.5".
SOLD! [color=Navy]Power Parts:
Powerchips Gold/93 , RDSport Comp. headers(coated) , Dinan CAI,
Ign. Solutions coils , Evosport pulleys , UFM IATS kit
Tubi catback & Random Tech metal cats
Heat barrier on lower plenum , UUC clutch&flyweel kit
Evosport 3.45 diff.(static&dynamic changed) , Schrick cams
Susp.& Brakes:
BBS LM'S (19x9-19x10)(255-285's)
FK Koenigsport coilovers , H/Depot mod w/ euroducts
Eibach/Technik swaybars w/ B/Power brackets
Wiechers Strutbrace , Axxis Ultimates f/r
Exterior:
E6 CSL splitter & rear diffuser trim , E6 carbon hood ,E6 carbon eyelids
M motorsport door emblems
Tecknic carbon door pillars
Hamann Rear Diffuser
Interior:
UUC SSK , Euro dash conversion & center armrest,
Alcantara steering wheel & shift/e-brake boots, TEC cup holder
Misc.../In the works../Considering todo..:
[size=1]Rennsport/Tecknic v/stacks (uninstalled)
Plenum Spacer DONE! but not tested (4-5-04)
Extra set of stock t/boddies (bored to 54mm)
