Wiper blade replacements, where to buy... - BMW M5 Forum and M6 Forums
Old 11th December 2003, 16:07   #1
adegiulio
Garage: 2001 M5 Jet Black
My blades are pretty much shot and need to be replaced. Should I buy replacements from BMW (which I expect to be expensive) or are there easy blade replacements that will fit, and can be purchased at most stores....
Thanks for the help
Ant
2006 M5 Sapphire Black Metallic
2001 M5 Jet Black----> bye bye
2005 Dodge Durango, silver
2003 John Deere 4310 Tractor with loader
2005 Mini Cooper S Convertible, red, wife's car
adegiulio is offline   Reply With Quote
Old 11th December 2003, 16:41   #2
Anita
Anita's Avatar
Garage: 02 M5 TiSi
I don't know you and your car's history or where you are time wise in Full Maintenence, but I regularly get mine blades replaced by my dealership. Here's a quote with some info form an earlier post of mine:
"Per the "Caring for Your Vehicle" book that came with my '02, you should have your wiper blades replaced twice a year. From page 8, under Window Care, I quote "The wiper blades should be replaced twice a year, before and after the cold season. This is especialy important for vehicles with a rain sensor." Last fall my dealership replaced them no problem--maybe it's worth asking when in for service if your dealerships will do it for you."
Otherwise, I might order them from one of the dealerships who discount BMW parts if you want BMW blades. Good luck!
Anita
Anita is offline   Reply With Quote
Old 11th December 2003, 18:52   #3
TCM
TCM's Avatar
Garage: 2001 BMW M5 Silverstone/Black luxury and 2001 M5 Jet Black/Black Luxury
I concur with Anita, the blades are replaced for free under the maintence plan until 3 years or 36000 miles. I have not seen a blade replacement available outside the dealers in my searches. The dealer allows you the option to buy a complete set of new blades altogether or a rubber insert replacement if you are out of warrenty. I suggest going for the complete blade replacement as the rubber one can be a real PITA to install and the metal strips that hold the rubber in place become weak after removing them to insert the new rubber.
T.C.
'01 Brushed Steel M5
front splitters
3.45 differential
'01 Silverstone M5- sold
SuperSprint:X-pipe
TCM is offline   Reply With Quote
Old 21st December 2003, 17:59   #4
Ken
Ken's Avatar
Garage: 2000 M5, Carbon Black
Do you feel it necessary to have the wiper blades replaced 2x per year? Just curious, because I would have though once per year or even 18 months would be often enough. I admit my car is a garage queen, but I just changed the wipers for the first time after 3+ years of ownership.
Ken is offline   Reply With Quote
Old 21st December 2003, 22:26   #5
Redshift
Redshift's Avatar
Garage: 01 M5 / 03 540iT / 10 K1300GT
Sales Feedback: (12)
Re: Wiper blade replacements, where to buy...
Actually my wife's 330Ci convertible needs wipers replaced much more frequently than my other cars that don't have auto-wipers. I think the automatic feature causes more wear and more frequent use than manual controls. Twice per year may be a bit much, though.
Brian
03 540iT Sapphire Black - 01 M5 LeMans Blue - 02 330Cic Orient Blue - 10 K1300GT Blue - 02 996 C2
*** Parting out entire 03 CB/Imola/Black M5 *** - TONS OF PARTS AVAILABLE
Redshift is offline   Reply With Quote
Old 22nd December 2003, 04:15   #6
Anita
Anita's Avatar
Garage: 02 M5 TiSi
Not to sound too sassy, but even if they are not obviously showing wear, why not have them replaced? It's free under full maintenence, recommended by BMW, and only takes a few minutes to do. I have it done when I'm having other things taken care of at my dealership. And mine do tend to start showing wear and tear pretty frequently anyway.
Anita
Old 22nd December 2003, 04:56   #7
Need4Spd
Need4Spd's Avatar
Personally, I would spring the extra $$ and get the BMW replacements. I've found that no aftermarket blades seem to work as well for so long.
Need4Spd
'01 M5 (now my brother's car) UUC SSK + Rogue WSR/RE Tranny Mounts+Royal Purple Synchromax/Axxis ULT Pads/StopTech SS Lines/TC Design from BeastPower Anti-roll Bar Brackets/Dinan LtWtFlywheel and Stage 3 suspension/4xOEM rear 275 Goodyear F1 Asymmetrics/Vines thrust arms/IATS relocation/10w-60 oil/hardwired Escort 9500i/Euro Armrest/TEC Cupholder/IceLink/PowerChip 91 Gold/TUBIs!/Strong Strut/BSW Stage 1/BT/Angel iBrights 3.0/space-saver spare by Bimmerzone
'11 Jaguar XFR, Quicksilver exhaust, Escort 9500ci
Unnamed weekend Italian 2 seater with DCT
Future - F10 M5 with manual transmission?
Need4Spd is online now   Reply With Quote
Old 22nd December 2003, 05:09   #8
Sharif
Sharif's Avatar
Garage: Interlagos Blue m3
The price for just the rubber inserts are $27. Maybe I am cheap but I think that price is crazy.
Sharif is offline   Reply With Quote
Old 23rd December 2003, 01:48   #9
intense321
intense321's Avatar
Garage: 2000 M5 Nachtblau
What about www.bmwpartstore.com? They seem to have the inserts for the M5 for $11? Are those the right sizes?
639x5.5 P7040-83918
or is it the
600x4.40
I'm totally confused. It sounds like they have the parts but I'm not sure exactly which ones to get.
intense321 is offline   Reply With Quote
Old 23rd December 2003, 03:08   #10
Tom M
Tom M's Avatar
Garage: 2000 M5 Anthracite/Caramel
I just bought the rubber inserts for about 12 bucks from a BMW dealer. $27 sounds more like the price for the full blades.
Tom
'00 Anthracite/Caramel/Burl Walnut
Tom M is offline   Reply With Quote
Should I buy repaired bent wheels??? VanM E39 M5 and E52 Z8 Discussion 6 14th June 2003 10:33
Wiper broke windscreen Simon E34 M5 Discussion 9 17th December 2002 01:46
Wiper blade part numbers? Azmir E34 M5 Discussion 5 5th November 2002 20:32
Wiper blade replacement interval Ashok Arora E39 M5 and E52 Z8 Discussion 5 25th February 2002 19:23
HIDS4LESS Group buy on Stage II and Angel eyes Bluewater M5 E39 M5 and E52 Z8 Discussion 7 18th January 2002 02:30
