26th November 2003, 21:16
#1
E39
Anyone polish headlight plastic covers??
Has anyone tried removing weathering/sandblasting damage from the factory headlight covers?
Does the common method used on plastic domestic headlight assemblies work? This involves wet sanding with 2000 grit followed by some aggressive rubbing compound, polishing compound and waxing.
Thanks for any replies.
26th November 2003, 22:05
#2
99 540iT Grey
Sounds reasonable to me... works wonders for Plastic rear windows... like on the corvette
99 540iT
Powerchip Gold 93
M5 Rear Swaybars
Shadow Badging / Grill
26th November 2003, 22:12
#3
I polish and wax all head lights almost every car I detail. While I have not sandblasted, the hand polish does remove the minor imperfections, so I would safely assume that a sandblast would have very good results.
T.C.
'01 Brushed Steel M5
front splitters
3.45 differential
'01 Silverstone M5- sold
SuperSprint:X-pipe
26th November 2003, 23:03
#4
i've used meguires plastic cleaner and polish. I believe it's made for convertible plastic rear windows. It worked ok, not like new, but quite a bit better. I've heard the 2k grit sanding and polishing produces marginal results as well.
I used the meguires product by hand, with a few applications of each product, cleaner and polish. Good enough for me!
27th November 2003, 00:53
#5
There are products made specifically for polishing out scratches and dullness in plastic that work quite well. I used them but don't remember the name. Do a search on the internet, check BMW, if they have something use it. Using the right product can reduce the time and elbow grease involved and make for a beautiful result.
I found it: Novus #1 polish for finish and #2 for removing scratches and dullness, and #3 for heavy scratches.
http://www.novuspolish.com/
This stuff works! I used it.
Jim
2006 Silver Gray Metallic over Black
The "Wolf in Sheeps Clothing" is back in the USA again
1971 2002 Colorado(Light Orange)
1976 2002 Inka(Red orange, a classic)
1982 528e Blue metallic
1984 533i Burgandy
1987 325i Alpine white
1988 535is Salmon silver
1993 525iT Calypso red
1999 528iT Titanium silver
2000 M5 Titanium silver
2006 M5 Silvergray Metallic
2011 Toy Land Cruiser Classic Silver
2013 BMW X3 2.8i Sparkling Bronze/Chestnut: Premium, Tech and Sat
#6
'03 M5 LMB/LMB&Al
When we figure it out, we need to print the instructions and place them under the wiper of every parked Dodge Neon we see.. What's up with those cars? They have the most aweful-looking headlight lenses!
27th November 2003, 00:57
#7
That's funny, you're correct. Isn't it awful. I've even seen some C Class Mercs with the same problem. Tailgating, sun and parking out doors is the culprit.
27th November 2003, 02:22
#8
'08 E92 Jerez M3
Originally posted by Jim Dolan
Tailgating........is the culprit.
Um, doesn't that cause the bumper covers to get dull instead?
Ray
'03 E53 X5 4.4i Topaz/Sand
'06 E90 330Xi 6MT Sparkling Graphite/Terra
'08 E92 M3 6MT Jerez/Speed Cloth/Carbon Leather <-- Evil Twin
27th November 2003, 04:36
#9
'01 540/6
I found by accident that automotive wax will clear some of the dullness. It is only temporary, so it has to redone once a month. It wont make them crystal clear, but it seems to help a lot. The 200 grit sand paper sounds reasonable, but be very very careful if you do that.
It's not just Neons that do it, but they do seem to be the worst offender. Pretty much most of the Dodge/Plymouth cars I see do it. E36's seem to be pretty bad too, for some reason.
Good luck finding a solution short of replacement.
-Brendan
'01 540/6
27th November 2003, 05:07
#10
E39
I think you'd better stick with 2000 grit, not 200 (lol).
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
