Old 12th November 2003, 05:39   #1
BeastPower
Guest
Interesting Article about Power Pulleys written by Steve Dinan
I just saw an article on Dinan's website called "The Danger of Power Pulleys & Understanding the Harmonic Damper." This is the first I have read about the potential problems with power pulleys. The article by Steve Dinan is well written and has a lot of supporting data. Here is a direct link:
http://www.dinancars.com/html/danger...er_pulleys.htm
Are there any techies here who would care to comment?
Old 12th November 2003, 07:06   #2
ernie
ernie's Avatar
Garage: e39 m5
daniel,
i believe steve dinan wrote this white paper quite a while ago. all the science seems sound. i checked and evosports power pullies do not modify the harmonic dampener (or the crankshaft pulley, i think?) so they should be safe.
ernie
ernie is offline
Old 12th November 2003, 07:39   #3
Vadim-SoCal
Vadim-SoCal's Avatar
Garage: '02 C32 AMG Silver/'01 Black M5 incoming
Sorry Daniel, but this is old news. Steve has been trying to discredit UD pulleys for years.
BTW, the failures of the crankshafts on ERT pulleys were caused by crankshaft pulley being too shallow. It allowed crankshaft bolt to bottom out in the threads. As a result, the snout of the crankshaft would crack from TQ being applied to it by air gun when the bolt bottomed out, leading to eventual crank failure.
It had nothing to do with lack of damper. The damper is actually meant to dampen accessories belt noise, not crank vibrations.
Our UD pulleys replace Water Pump, Power Steering, Crankshaft and Alternator pulleys.
S62 actually has a real damper (Item 1) that is behind crankshaft pulley:
Here are dyno results:
Vadim-SoCal is offline
Old 12th November 2003, 08:56   #4
V-10 4 Me
V-10 4 Me's Avatar
Garage: 2001 530i Black
m I think it sounds resonable. I'm not sure I ever thought that changing pulleys was suitable to my type of mods..
I like sexy mods... Thow a couple of babes on the packaging, and I'll buy anything...
AS CAI ~ Lo Jack
3 ~ 1/60 ~ M Audio
Do Not Enter---------->///M5---------------------------X
V-10 4 Me is offline
Old 12th November 2003, 10:28   #5
BeastPower
Guest
The dyno results and customer feedback have clearly shown that the UD pulleys are a good mod. I don't like that the cabin lights dim here and there, but that is a relatively minor annoyance.
It is just interesting to read what a major BMW tuner, such as Dinan, has to say about this type of modification.
Old 12th November 2003, 21:03   #6
Mach430
Garage: 01 CLK43k & 03 M5 Sterling Grey
Send a message via AIM to Mach430
There are 2 customers experiencing minor dimming of their interior lights. This is due to faulty alternators, which are producing less power than normal. The UD pulleys are simply making these issues known. We have several M5 pulley owners, with various years of production, all having no issues.
It is just interesting to read what a major BMW tuner, such as Dinan, has to say about this type of modification..
In all actuality, Dinan has said nothing about any of our pulley kits as they all leave the harmonic dampener untouched.
Thanks,
Ben
Mach430 is offline
Old 12th November 2003, 22:13   #7
Lincoln
Lincoln's Avatar
Garage: '02 M5 Silver/Black/Lux Trim
I didn't read Dinan's paper on this, but I can add that UD pulleys and certain other mods used together will cause catastophic failures. For example: on an E36 M3 (not sure about other models) if you run UD pulleys and a light flywheel you will be replacing your engine after a few thousand miles. Didn't happen on mine, but I'm friends with two guys who had this problem on E36 M3s.
'02 M5 TiS/Black Lux-Ext Leather
Homemade Adjustable Clutch Stop, Ultimate Cup Holder, Dynashield Headlight Film, 20% non-metallic tint, Venture Clear Bra, Autosolutions SSK, Trunk bin, ashtray bin
Lincoln is offline
Old 12th November 2003, 22:24   #8
Vadim-SoCal
Flywheel has nothing to do with this. This is a very common "urban myth" story among BMW enthusiasts.
Old 12th November 2003, 23:09   #9
brad @ evosport
brad @ evosport's Avatar
Garage: e46 M3 CSL Cab, e46 M3 Racer, e30 M3 Racer, VF S/C MZ3, X5
This is only half the story. This is the case with kits on the 6cyl BMW's using a LTW flywheel and a CRANK pulley. This motor is susceptable due to the length of the block and the fact that it is an in-line motors. "V" motors do not have this issue. Also, even on the M50/52 motors, we chose not to use the crank pulley, but I know many people that both have and have nto had problems. It is not a given, but a possibility. We chose not to even have a possible problem and not make the crank pulley.
Brad
Brad Otoupalik | evosport
brad@evosport.com
www.evosport.com
phone 714.901.3100, ext. 15
order 888.520.9971, ext. 10
fax 888.520.9972
[evolutionizing your driving experience]
brad @ evosport is offline
How many of you guys, read GUSTAV's article on his DINAN visit/tour............ FAST 5 E39 M5 and E52 Z8 Discussion 21 16th June 2008 18:40
ATTN: SUPER-BIG News.... Dinan improves & simplifies the Group Buy procedure....... FAST 5 M5 E39 Group Buy Forum and Sponsor Discussion and Offerings 38 17th February 2004 10:20
Adding MODS to your car and warranty being possibly affected................ FAST 5 E39 M5 and E52 Z8 Discussion 1 6th November 2003 22:44
Page generated in 0.17311 seconds with 11 queries
