Old 10th November 2003, 07:31   #1
V-10 4 Me
V-10 4 Me's Avatar
Garage: 2001 530i Black
Help Squeaky Front Sway Bar
I have the Technik/ Eibach sways with poly eurathane bushings.
It came with grease but the grease looks like its dry? Is there a way to install a nipple grease fitting to apply grease without a removing sway bar brackets?
We need BeastPower EZ Grease Front Poly Sway bar Brackets...
What type of grease should be used on them poly bushings N
E Way?
AS CAI ~ Lo Jack
3 ~ 1/60 ~ M Audio
Do Not Enter---------->///M5---------------------------X
V-10 4 Me is offline
Old 10th November 2003, 10:48   #2
MIB
MIB's Avatar
Garage: 03 M5 Steel Grey/Petrol-LMB/Ti
Send a message via Skype™ to MIB
Hey Sam,
When BMW installed my ACS Sways, the bushings are RED and it had some sought of White Grease. It looks a little like tooth paste.
I didn't touch it. I didn't want to get my hands dirty.
If you really need to know I guess I could get one of my children to crawl under the car and touch some. I'm kidding.
Sorry I couldn't be of more help. But it is White, if that helps. No Squeaks here.
MIB is offline
Old 11th November 2003, 01:07   #3
V-10 4 Me
V-10 4 Me's Avatar
yep i have the same stuff. I think I'll go under there and squeeze some more in there
Take care
AS CAI ~ Lo Jack
3 ~ 1/60 ~ M Audio
Old 11th November 2003, 06:17   #4
GregC
GregC's Avatar
Garage: 2003 M5 Jet Blk/Silverstone/Blk Anthracite
White lead maybe ??
MISC PICS
2003 M5 - Jet Blk/Silverstone/Black Birch Anthracite,35% Window tinting, CPT8000, Valentine 1, Royal Purple,Rogue SS,Rogue WSR,Rogue Tranny Mounts,3m Stoneguard,Powerchip,AA CAI, IATS Relocate,Stealth-One,Lidatek LE-30
GregC is offline
Old 11th November 2003, 19:52   #5
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
Hey Sam,
I had some UUC swaybars on a past e46 323 which used poly bushings. From past experience with polyurethane, i was ready for squeeking as the lube wore away, so i drilled a hole, can't remember the exact size thru the bushing and the bracket. I then threaded a 'zerk' fitting into the bracket so i could use a grease gun and pump some grease in every so often. The bushings were grooved, so they would hold a little grease, and the grease could theoretically be pumped in and spread around.
It seemed like a good idea to me, i wasn't sure why it didn't come this way in the first place.
I ended up getting rid of the car a couple months later, so can't say if it worked or not...
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Check your sway bar brackets! Need4Spd E39 M5 and E52 Z8 Discussion 27 7th July 2003 18:59
Just installed the Rogue Tranny mounts and the sway bar brackets TriflowM5+M3 E39 M5 and E52 Z8 Discussion 10 15th May 2003 18:24
Fixed R sway bar bracket but it still makes noise TriflowM5+M3 E39 M5 and E52 Z8 Discussion 2 28th October 2002 21:31
Installed Dinan rear sway bar on stock suspension BostonRocket E39 M5 and E52 Z8 Discussion 6 9th January 2002 18:28
Page generated in 0.11769 seconds with 11 queries
