Old 9th December 2003, 23:52   #31
Need4Spd
Need4Spd's Avatar
213s or 215s? I thought our speakers are 5.25, so wouldn't the correct ones be QM215.61Q? Aren't the 213s 6.5 in. mid/woofer drivers?
Need4Spd
Need4Spd is offline
Old 10th December 2003, 01:00   #32
gra8fuldd ed
gra8fuldd ed's Avatar
Garage: 2003 M5 Carbon Black w/Imola Red
The QSD-216 are 6.5" and QSD-213 are the 5.25" component Top of the Line Q-Series speakers offered by MB Quart.
The PCE-216 are also 6.5" component set and cost roughly HALF of the QSD 216 in the Q-Series Line.
The speaker model numbers beginning with PCE ifollowed by numbers is the MB Quarts "Premium Line" of speakers.
gra8fuldd ed is offline
Old 24th June 2004, 23:28   #33
PAN5R
Garage: M5 LE Orinocco Green, M5 LE Rosso Red, M635csi Dolphin Grey
Re: Just had my DSP stereo upgraded! One word.... NICE!
i have a july 2002 model M%, with the comms pack but without the DSP option. Can i upgrade the std stereo to incorporate the DSP amp?
i dont have an issue changing the speakers but is all the wiring already there for the amp?
Thanks in advance
PAN5R is offline
Old 25th June 2004, 00:05   #34
m5am
m5am's Avatar
Garage: n/a
If you are just going to be changing your speakers, not subs, but just the 5 and a quater inch speakers then it is almost a plug and play deal. Just remove the old speakers and mount in the new ones hooking up the speakers with the exsisting wires. I dont think there would be a need to go to larger gauge wire since you are still going to be running the same power into the new speakers. The only issue you may come across when searching for new speakers is their depth. Also I know a few people that buy speakers based on other peoples oppinions but YOU really need to hear the different companys. Each speaker usually has its own characteristics, MB Quart usually being bright sounding(really brass like and metallic) Where as Diamonds are a little softer(depending on the tweeter) with a little less mid bass. Then there are companys such as Focal and CDT who make some great and IMO best sounding speakers. I personally would reccomend CDT eurosports to anyone looking for a high end speaker to purchase.
-Sam
m5am is offline
Old 25th June 2004, 01:11   #35
M5Kid
Garage: N/A
I absolutely agree with Sams statement, everybodys ears are different. MB Quarts might sound great to one person, and to sharp for another. So Sam, you preach that you must hear speakers before you buy them and not take other peoples suggestions, but isn't this what you just did with the CDT's?
Travis
M5Kid is offline
Old 25th June 2004, 02:52   #36
PAN5R
but what about hooking up a dsp amp as per the original option on the M5 to my system.
Is there any wiring for that??
PAN5R is offline
Old 25th June 2004, 04:17   #37
m5am
m5am's Avatar
Garage: n/a
Yeah Ill admit it, I made a hypocritical statement but I have heard every other speaker and they sounded good but not great so I dont think I have audiophile ears. PAN5R, sorry I misread your original post, I think that installing a dsp amp would be just as hard as installing an aftermarket and I would assume it would be cheaper and better to get an after market amp. I suggest you look into the diamond D5 and D7 series amps. I dont think you could just plug in the amp, it would take a fair amount of wiring
-Sam
m5am is offline
Old 25th June 2004, 07:26   #38
M5Kid
Garage: N/A
You will get better audio results by ditch the DSP system and idea. I regular high quality amp/speaker/sub setup will sound great, and it is quite simple. Great audio results in the M5, or any car for that matter can be had for around 2,000 dollars. You just need to do your research, and shop around for the best prices.
Travis
M5Kid is offline
Old 25th June 2004, 10:49   #39
rogbacon
Garage: Carbon Black E39 M5
I went a lot further on my upgrade.........
Top Audio Install - M5
Roger
rogbacon is offline
Old 26th June 2004, 02:33   #40
PAN5R
Roger
Very nice, but i want to srick to something less extravagant. Some that would slot in the holes already there, and then add an amp, but still use the existing hed unit if poss.
PAN5R is offline
Anyone *successfully* upgraded stereo? beanboy E39 M5 and E52 Z8 Discussion 8 8th March 2003 01:05
Interminent problem with DSP DDL E39 M5 and E52 Z8 Discussion 10 13th March 2002 07:18
Finally upgraded my stereo AlbertM E39 M5 and E52 Z8 Discussion 16 24th January 2002 01:07
DSP Settings 1C00lVC M5 E39 and E60 tips & tricks 0 15th July 2001 02:25
Page generated in 0.19269 seconds with 11 queries
