Old 14th October 2003, 22:53   #11
MEnthusiast
MEnthusiast's Avatar
Garage: 03 M5
Robert,
thanks. Im waiting to do this work- but one day I will do it.
All the best,
MEnthusiast is offline
Old 14th October 2003, 23:03   #12
Kevmmm
Kevmmm's Avatar
Garage: 2008 Z4 M Coupe - Black Sapphire - Black Nappa - Aluminium Trim
It appears that you have a nice updgrade to your soundsystem. I would be interested in seeing pictures of the the sub woofers and amp. Does your car still maintain room in the trunk for "stuff"?
Thanks.
Kevmmm
2008 E86 Z4 M Coupe
Black Sapphire Metallic / Black Nappa Leather / Aluminum Trim
Previously owned M's:
'02 E39 M5 Carbon Black Metallic/Black All Leather Nappa Heritage/Dark Burr Walnut trim
'99 E36 M3 Coupe, Titanium Silver Metallic/Two-tone Grey Leather,Dinan chip,cold air intake,strut bars
'96 E36 M3 Coupe, Estoril Blue Metallic/Black Leather, Dinan Chip
Kevmmm is offline
Old 14th October 2003, 23:19   #13
FAST 5
FAST 5's Avatar
KEV...............
There is no loss of trunk space, since the replacement woofers are mounted/located in the same area of the stock DSP woofer system and the amp that powers the two woofers is mounted in the cubby hole section of the truck, which is located on the right side of the trunk. t actually an access panel/door. You know what I mean, right?
Robert
FAST 5 is offline
Old 14th October 2003, 23:32   #14
ernie
ernie's Avatar
Garage: e39 m5
robert,
thanks for all of your help! If you wouldnt mind answering just several more questions...
1) do the door panels have to be removed?
2) where are the crossovers mounted?
once again robert, i really appreciate the helpful answers.
ernie
ernie is offline
Old 14th October 2003, 23:59   #15
FAST 5
FAST 5's Avatar
more answers............
yes, the doors panls have to be removed, inorder to access the speakers. No other way to get to them.
Regarding the crossovers, you will not be using the MB QUART crossovers, since your pluging the MB QUART speakers into the factory amp, which has its own crossover. The facory crossovers are built into the factory amp. You can't see them or access the crossovers. so, the MBQUART crossovers go unused. The Quarts sound fine with the use of the factory amp and its bult in crossovers.
Robert
FAST 5 is offline
Old 15th October 2003, 00:27   #16
ernie
ernie's Avatar
Garage: e39 m5
robert,
you have convinced me to go ahead with this project. i will most likely be using the same MB Quart PCE213's, front and back. However, for the subs, I think I will be using the A/D/S a10 free air sub. this should just drop right in and i will see how it goes powering them with the stock amp. if i can just get a tad more bass ill be satisfied. thanks for the inspiration robert!
ernie
ernie is offline
Old 15th October 2003, 05:47   #17
sean_w_smith
Garage: 00 Alpine White M5
Send a message via AIM to sean_w_smith Send a message via MSN to sean_w_smith Send a message via Yahoo to sean_w_smith
Related Question: So I have a 00 M5 which doesn't come with the M audio option. What size holes are currently in the rear deck. Is there a 10" hole like the newer cars or some 6x9 POS...
Sean
sean_w_smith is offline
Old 15th October 2003, 08:10   #18
V-10 4 Me
V-10 4 Me's Avatar
Garage: 2001 530i Black
Sean
Sean does POS mean---------------> Possitively Outstanding Speaker?
AS CAI ~ Lo Jack
3 ~ 1/60 ~ M Audio
Do Not Enter---------->///M5---------------------------X
V-10 4 Me is offline
Old 15th October 2003, 09:22   #19
warhaven
warhaven's Avatar
Garage: 2002 M5 Jet Black
Sweet setup.....
Quick question for the group though... I fI were unfortuneate enough not to have gotten the DSp version of the 5 Series factory stereo, is it still possible to upgrade to it?
Warhaven's 2002 Dinan S2 M5
11/22/04 Dyno: 336.2RHP/329.2T (Exhaust only)
03/15/05 Dyno: 334.38HP/326.24T (+CAI)
06/22/06 Dyno: 348.76HP/331.33T (+ MAF)
Jet Black/Black
Super Sprint X-pipe
AA Front Grill
TC Racing Pedals
TCD Sway bar brackets
MK4 V28.1 NAV upgrade
Zenon 8000K Stage II upgrade
warhaven is offline
Old 15th October 2003, 14:38   #20
Mako5
Mako5's Avatar
Garage: 2002 BMW M5 Sterling Grey
Send a message via Yahoo to Mako5
Fast5, I wasn't clear or maybe Imissed it. Did you just have the DSP Stereo or did you have the M-audio option?
///Mako5
2002 Sterling Grey, Heritage Black
Rogue Engineering Octane SS w/WSR,
Rogue Engineering Transmission mounts
19" BBS LM w/ Michelin PS2
Tubi Exhaust
Strong Strut Brace
Valentine 1/StealthOne
Bluetooth OEM Retrofit
MKIV DVD Navigation
Euro Armrest
Mako5 is offline
Anyone *successfully* upgraded stereo? beanboy E39 M5 and E52 Z8 Discussion 8 8th March 2003 01:05
Interminent problem with DSP DDL E39 M5 and E52 Z8 Discussion 10 13th March 2002 07:18
Finally upgraded my stereo AlbertM E39 M5 and E52 Z8 Discussion 16 24th January 2002 01:07
DSP Settings 1C00lVC M5 E39 and E60 tips & tricks 0 15th July 2001 02:25
Page generated in 0.18936 seconds with 11 queries
