• Latest threads
    • Custom feed
      • Updates
        Old 9th October 2003, 05:18   #1 (permalink)
        M5XTRM
        M5XTRM's Avatar
        Engine trouble? Feels like running on 6 cyls
        Over the last couple of weeks- on and off, sometimes when driving and sometimes when starting the engine, immediately when the accelerator is pushed, the car feels like is running on 6 cylinders. The exhaust note changes almost to a Harley and it takes a full push of the accelerator all the way down until it stops to get the car moving.
        The performance is almost like when the redline is reached and the engine goes into safe mode. It does not help to stop and let the engine cool.
        In addition when starting the engine (cool or hot) the engine sounds like having trouble turning and it takes at lest two starting tries to get the engine going (battery is fully charged and charging well).
        Has anyone experienced this? What was the fix?
        I have a call into BMW and the dealer will take a look next Wednesday.
        Thank you.
        M5XTRM
        M5XTRM is offline
        Old 9th October 2003, 06:31   #2 (permalink)
        alexhp
        alexhp's Avatar
        couple of simple checks...
        I would guess it was a fouled/end of life spark plug or a blocked injector or two... Thats the first thing to check...it gets more expensive after that....
        alexhp is offline
        Old 9th October 2003, 16:02   #3 (permalink)
        M5XTRM
        M5XTRM's Avatar
        Alexhp,
        The spark plugs were changed 4 months ago. It is still possible, will check them before taking it in. The car has full warranty until 100 k - we will see.
        M5XTRM
        M5XTRM is offline
        Forum Jump
        Nowack Tuning Report, The Truth (Long Version) CharlesW E39 M5 and E52 Z8 Discussion 60 28th June 2006 21:46
        Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 05:49
        My thoughts and some dyno results OEM Vs Nowack...long version Apples Most Memorable Threads' 65 10th June 2002 10:54
        SL 55 vs Z8 at the Nurburgring! mmunson E39 M5 and E52 Z8 Discussion 64 21st April 2002 02:42
        Alpina 3.0 csi JetBoy ALPINABoard.com | BMW Alpina Discussion 53 13th October 2001 12:09
        Page generated in 0.20951 seconds with 11 queries
