Fuel Pump Died Will 540 pump fit? - BMW M5 Forum and M6 Forums
Like Tree7Likes
Old 4th March 2014, 03:43   #1
manualshifter
manualshifter's Avatar
Garage: M5 E39 1/2000 Tiag
Died last nite no warning. Lift rear seat, put ear to pump area, wife toggled key to pos 2 and back, no noise at all from pump.
Fuse ok, AUS cars dont have the big relay in trunk. NO codes on Peake, I think pump? Car is 122k km or 80k miles, 1/2000.
New one 2 weeks from USA, so I picked up a used 540 pump this morn, will it work till new one gets here?
Pump part looks different, but yellow plug looks same.
Thoughts?
Allan
manualshifter is offline   Reply With Quote
Old 4th March 2014, 04:49   #2
68FB
Garage: 2001 M5 Ti Silver
You do have a relay. It's the green one in the boot shown below. It sounds like you have checked the main fuse F54. Did you check F31?
You can check which failed (relay or pump,) by putting a 14 gauge or heavier jumper wire across pins 6 and 2 in the relay connector. If the pump runs, it's the relay. If not, it's the pump.
And no, I don't think a 540 pump will work. The M5 has a higher pressure 5 bar pump.
Name:  Australian fuel pump and relay.JPG
Name:  Australian fuel pump and relay location.JPG
68FB is offline   Reply With Quote
Old 4th March 2014, 05:16   #3
manualshifter
Thank you 68 off to the carpark now check that relay
Old 4th March 2014, 06:03   #4
manualshifter
Attachment 383993
Attachment 384001
Went to trunk, pulled second relay from front, jumped pins 2 and 6 with paperclip.. little spark and hot paperclip but no pump sounds..
Yes I checked fuse 54 is ok, and just looked at 31, its in glovebox right? its good too..so fuel pump?
Old 4th March 2014, 06:12   #5
vantaam5
vantaam5's Avatar
Garage: 2003 M5 matte black
Forget the 540i pump!!!!
Runs on 3.5bar instead of 5bar
1992 Mercedes 500E Black/black
-under restoration
vantaam5 is offline   Reply With Quote
The Following User Says Thank You to vantaam5 For This Useful Post:
manualshifter (4th March 2014)
Old 4th March 2014, 06:30   #6
manualshifter
Only reason is:Another member down here told me he used a 523 pump to get going for a week or so till correct part arrived. and car drove ok.. its only one I could find from breakers in Brisbane
obviously pressure and flow wont be to spec, but if i am mobile at least I save tow fee home?
Old 4th March 2014, 07:47   #7
vantaam5
vantaam5's Avatar
Car will run somehow with it,but very quickly reach the 25% max addition.
Is ok to limp home,but not for extended driving.
Rather open the old fueöl pump(open the rolled edge) and solder in a set of generic brushes(as yours will have worn out brushes) that you shaped to profile or get another regular used E39 pump to use its brushes if you have to drive for a few weeks until replacement arrives.
Old 4th March 2014, 08:48   #8
StevieM400
StevieM400's Avatar
Garage: 2001 BMW M5 in Carbon Black
As previously mentioned the E39 fuel pump ( BMW Part # 16146752369 ) runs at 5 bar and is unique to the M5. Good luck.
StevieM400 is offline   Reply With Quote
Old 4th March 2014, 15:35   #9
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (4)
Aeromotive 340 lph pump should work if that is more available to the OP. It is almost a direct fit.
Old 4th March 2014, 23:50   #10
68FB
Did you check the wiring colours to the relay you pulled matched the wiring diagram above? I remember seeing past posts about some confusion about which relay was which.
If the fuel pump brushes and commutator are bad enough the pump doesn't run, I wouldn't have expected the paper clip to pass enough current to get hot.
DIY: Suddenly stranded? Testing your fuel tank levels, fuel pump relay, and fuel pump in 10 minutes with a piece of copper wire JoeFromPA E39 M5 and E52 Z8 Discussion 79 18th January 2014 21:33
Fuel pump died, now C9 peake code MA3HOK E39 M5 and E52 Z8 Discussion 20 10th September 2012 17:48
New pre cat 02 sensors, secondary air pump, mafs, fuel pump and filter = 1 happy S2!! madyspop E39 M5 and E52 Z8 Discussion 0 12th February 2011 04:37
Kenne-Bell Boost-A-Pump Install (AKA Dinan Fuel Pump Booster #D862-7320 havasusteve03Beast E39 M5 and E52 Z8 Discussion 2 11th November 2010 05:56
Fuel pump died... Nicolas E39 M5 and E52 Z8 Discussion 3 10th February 2007 01:30
