S62 running too rich - BMW M5 Forum and M6 Forums
Like Tree7Likes
Old 21st February 2014, 19:34   #1
JUNGLISTluder
JUNGLISTluder's Avatar
Garage: BMW e39 M5, e30, e28 and Ferrari F355
So my M5 has been running progressively more rich over the past year and now it is pretty obvious that something is wrong. There is no SES light and the engine runs smooth but read below and let me know what you think.
Engine Mods:
  • PowerChip ECU Tune (Matt did it a couple years ago)
  • Tubi midpipe and muffler deletes
Symptoms:
  • Used to get 280-300 miles per tank with normal mixed driving; now I get 220-250 miles per tank with the same driving style
  • My exhaust tips are always black and sooty; even after washing they will be black in a couple days
  • The car briefly hiccups/stumbles when pressing the accelerator before taking off
  • Doesn't quite feel like the engine is making full power
In an effort to fix the problem I have done the following:
  • New OEM M5 MAF sensors
  • New precat 02 sensors
  • New fuel filter
  • New spark plugs
  • New air filters
  • Cleaned oil seperators
  • Fuel pressure test (high 60s at idle; low 70s when revving)
  • New thermostat
  • New ECU and sender temp sensors
  • Fuel pump relay
  • ECU reset via OBD2 scanner and battery disconnect
  • New rear tires
  • 4-wheel alignment (within spec)
  • Techron concentrate treatment
Here are the things I have not replaced but could potentially have an impact:
  • Cam Position Sensors (CPSs)
  • Fuel pump
  • Vanos seals
What am I missing? What would affect the A/F ratio and cause the engine to run rich but not trigger the SES light? Is it my PC tune? Would the vanos cause this? I don't think it's my fuel pump because I have solid fuel pressure. Is it the difference between summer/winter fuel blends? Am I just crazy? Thoughts???
BMW e39 M5
BMW e30 318is
BMW e28 528is
Ferrari F355 GTB
JUNGLISTluder is offline   Reply With Quote Quick reply to this message
Old 21st February 2014, 20:11   #2
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (4)
Engine Mods:
Symptoms:
  • New fuel filter
  • New spark plugs
  • New air filters
  • New thermostat
  • Fuel pump relay
  • New rear tires
  • Fuel pump
  • Vanos seals
Surprised the new rear tires didn't help!!! (j/k).
After changing parts, like spark plugs, pre cat O2's, any improvement? If you are running rich, it is not the fuel pump.
Assuming tune is good, (did you have the issue before the tune????) I would think there is an unmetered air leak after the MAF's. So the car sees more air than it is getting, hence running rich. Can Matt return the tune to stock temporarily to eliminate that issue?
You might check the two pipes going into the front of the plenum, there is a small rubber gasket on each side that is easy to mangle (ask me how I know!!).
Why not do some dyno pulls and get your AFR's and the AFR curve? Might be helpful.
gsfent is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to gsfent For This Useful Post:
6SpeedDave (22nd February 2014)
Old 21st February 2014, 20:17   #3
ard
Super Moderator
ard's Avatar
Surprised you dont have fuel trim numbers... diagnosing based on soot and miles per tank isnt optimal.
See this:
Failed emissions...with a twist?
Stop replacing parts, do some diagnosing.....
IMO
ard is offline   Reply With Quote Quick reply to this message
Old 22nd February 2014, 04:17   #4
TheProPilot
TheProPilot's Avatar
Garage: E39 M5 Silver on Black+97 Supra=1400bhp
Im averaging about 24mpg at 65mpg, 21mpg at 85mph, 23mpg 45mph city. Sound about right? I've watched my fuel trims and they're normaly almost zero. That sounds right to me. My car does have a very.. hard to explain... digital stepper motor feeling throttle. Very small movements yield abrupt response but only at lower rpms.
Rao?
"With great power comes great responsibility."
03 E39 M5 Silver/Full Black/Alcanterra/M Audio
361RWHP/340ft-lb from 2500 to nearly redline
Brembo BBK 4 piston F355mm, R345mm
SSR GT03 Werfen R19x10.5
Tubi exhaust/K&N filters
Performance Gearing 2.65 gears and upgraded LSD <<-- fast as crap now!
Rogue SSK
VXX AEs, 55w-6000k Fogs & low beams
Slimmbones Folding Euro Armrest
Motul RBF600/RedLine MTL 75w-80 Getrag fluid/RedLine 80w-140 <DO NOT USE ROYAL PURPLE IN THE DIFFERENTIAL! >
Miccus auto pairing Bluetooth hardwired, BMW aux retrofit
**31MPG/500 miles per tank plus reserve**
97 Supra 808RWHP/29psi/E85 - SOLD
Originally Posted by Dave Ramsey
"Discover" "Freedom" from bondage. "Chase" what matters: live free by living debt free. Being broke is normal. Be weird.
Originally Posted by TheProPilot
If you don't have the time (or money) to do it right the first time you don't have the time to do it twice.
TheProPilot is online now   Reply With Quote Quick reply to this message
Old 22nd February 2014, 05:06   #5
bimmerule
bimmerule's Avatar
Garage: Carbon Black E39 M5
Sales Feedback: (9)
Did your car come with the tune? I'd start there.
bimmerule is online now   Reply With Quote Quick reply to this message
Old 22nd February 2014, 05:26   #6
bcampbe7
bcampbe7's Avatar
Garage: 2000 TiAg M5
Sales Feedback: (8)
Speaking of running rich!
Changed my pre-Cat O2 sensors tonight.
2000 M5 - Evolve Alpha-N tune; ST coilovers; Updated headlights with angel eyes; 16:9 screen with MKIII; K&N drop-ins; First aide kit; Diny's stainless radio knobs; Slimmbones Euro sliding/tilting armrest; Slimmbones XL Fog light covers; Rear Style 65 on all 4 corners; Daily driver
bcampbe7 is offline   Reply With Quote Quick reply to this message
Old 22nd February 2014, 05:43   #7
grant318is
grant318is's Avatar
Garage: 2000 Silverstone M5
Try the CPS sensors. Rock auto sells the Intermotor brand. I have been using them for years with no issues. My exhaust ones actually had the BMW stamp. Go for new O2 sensors as well. I bought Denso ones. They're a good OEM.
grant318is is offline   Reply With Quote Quick reply to this message
Old 22nd February 2014, 05:50   #8
TheProPilot
Wow, were you getting an SES light at all? I found the Bosch sensors on eBay from reputable sellers for $50 shipped each. Not bad. Bosch 13477 I believe it is. Theyre not knockoffs either. $100 isnt a bad investment.
Other than the seller telling you it has a tune, how would I know? Throwing it on a dyno isn't very precise for knowing if it has a tune - before someone suggests that lol. I'll happily throw it on the dyno though for fun
Old 22nd February 2014, 06:20   #9
TheProPilot
And before I go any further: how far and what kind of mileage are you guys getting in those conditions? Granted I have 19" wheels amd BBK F&R and that affects everything so that's why I'm wondering about where everyone else is. I brake early for traffic lights to avoid stop starts in traffic and I se cruise control on the freeway when traffic permits and my heart isn't feeling the need for speed.
Old 22nd February 2014, 18:02   #10
6SpeedDave
6SpeedDave's Avatar
Garage: 2002 M5 - Sterling Grey - Black/Red
Sales Feedback: (11)
Would also be interested in seeing how you solve this. I feel like my car is the same way at low rpm. I have no lights and the car runs like a champ so its not something I want to dump money into.
Jerry you have a good point. The two rubber gaskets on the inlets to the plenum are a huge source for added air post-MAF. I have replaced the 2 on the MAF's, just need to do the plenum ones now.
Sterling Gray '02 M5
Imola Sport Interior
6SpeedDave is offline   Reply With Quote Quick reply to this message
poor running / running rich throttle bodies? skeggy E39 M5 and E52 Z8 Discussion 0 20th September 2010 18:02
Running rich with no codes Valkman E39 M5 and E52 Z8 Discussion 24 10th April 2009 18:12
Rich running... Miksta E34 M5 Discussion 12 4th October 2006 14:23
? Running rich BenS E34 M5 Discussion 4 11th April 2006 20:05
Running rich Demonbiker E34 M5 Discussion 8 25th February 2006 23:46
