Old 24th March 2001, 03:08   #1
StuMcR
Ck Engine Light on
The Service Engine Soon Light came on in my '01 Beast tonight on the way home. Car seemed to lose some power and bucked at one stop-light rtake off. After about 14 minutes it went off again and car seemed to perform normally. Called dealer. He said probably emissions problem and to bring it in tomorrow.
Anybody else experience this? Car's about a 9/00 build, 12/00 delivery.
Appreciate any input.
Stu
'01 Silverstone
StuMcR is offline
Old 24th March 2001, 03:37   #2
bobafett
bobafett's Avatar
Send a message via ICQ to bobafett
Post
I just had a problem like that yesterday. I was at lunch and when I came out I noticed a stupid nail in the corner of my left rear sidewall. Got on the freeway, and no tire defect messages or anything, but I noticed that the "service engine soon" light was on and that the car was muffled and literally limped along, as if it had 1/8th of the power. Foot to the floor in 3rd gear, i could COUNT the time it took to get from 70 -> 75. Pulled off, turned car off then on, and it's been fine since.
Let me know what your dealer says.
--Dan
bobafett is offline
Old 24th March 2001, 06:27   #3
alpywhite
alpywhite's Avatar
Garage: 2003 BMW M5, Titanium
You guys are not alone. This same phenomenon has been discussed elsewhere on the board, but I can't find it.
alpywhite is offline
Old 24th March 2001, 06:39   #4
Need4Spd
Need4Spd's Avatar
Must be all the computers in the car. You know, system crashes or freezes; to fix, reboot!
Need4Spd is offline
Old 24th March 2001, 18:25   #5
StuMcR
Post
Thanks guys. Dropped my baby off at Prestige Motors in Santa Rosa this morning. Service mgr said they would try and see what's in the computer memory later today. Also have a front end vibration right at 70mph on a regular basis, so they will research that too!
I'll let you know what they find re the engine light.
Stu
'01 Silverstone
StuMcR is offline
Old 24th March 2001, 19:49   #6
racerX
racerX's Avatar
Garage: 2000 M5 Jet Black
Post
Funny, I had the same thing happen to me last week. Driving along, Service Engine light came on, lost power, after about 10 minutes, power came back and light went off. I immediately dropped it off at the dealer. They read the diagnostic log and found a misfire on cylinder 1 and 8 (fault codes 212, 205, 196). According to my tech, this is a known software bug. BMW is working on a solution, but none is currently available.
racerX is offline
Old 24th March 2001, 20:56   #7
Anzir
Anzir's Avatar
Garage: Silverstone 2000 M5
Post
Same thing happened to me two weeks ago. I was in 6th doing around 85-90 and the light came on, the engine went a little slow, and I could hear the engine sounded a little different. I took an exit and when I slowed down to around 40 mph, the light went off. I took it to the dealer and they said that one of the catalytic converters had failed, and this was a common occurence on the V8 cars. It appears to be true because my 97 740iL had to have both of its original cats replaced as well. Anyways, after they changed it, it has been running fine since. I'll wait and see how it goes.
Anzir is offline
Old 25th March 2001, 00:55   #8
Guest
Post
My light has been on also. they said it was a purge valve. will replace as soon as it comes in.
Old 28th March 2001, 07:26   #9
StuMcR
Post
Guys, Got my beast back last night. Re Service Engine Light- the dealer found a fault code- #2 cylinder misfired, one time event". They cound not repeat it and the car ran fine for them. Said it might have been a slug of water in fuel and/or piece of sediment stuck in the injector. Problem is the event and poor power/bucking on take off lasted about 15 minutes.
They said just drive it and see what happens! Guess it's another one of life's mysteries. Time will tell.
Still have front end vibration at h'way speeds, even after dealer re-balanced front tires. Another mystery.
StuMcR is offline
Old 28th March 2001, 15:26   #10
ijam
ijam's Avatar
Garage: 2001 Silverstone/Silverstone
Post
vibration at highway speeds can also be caused by warped/worn brake discs (rotors) - probably other things too
I had the same problem on an old car of mine (shudder at about 60-65mph) and wheel balancing didn't help. I got them to first skim the brake discs (better but not cured) and then replace them.
ciao
Ian
ijam is offline
Nowack Tuning Report, The Truth (Long Version) CharlesW E39 M5 and E52 Z8 Discussion 61 7th January 2009 11:06
Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 05:49
SL 55 vs Z8 at the Nurburgring! mmunson E39 M5 and E52 Z8 Discussion 64 21st April 2002 02:42
614 miles w/ Check engine light on and steering squeak. Stereo problem too. Turbo323i E39 M5 and E52 Z8 Discussion 1 18th March 2002 08:09
Reason for 'service engine soon' light BostonRocket E39 M5 and E52 Z8 Discussion 6 9th November 2001 06:13
Page generated in 0.14923 seconds with 11 queries
