Dinan Rear Sway Bar
I have one as part of the S2 that I did.
I can't tell you the difference the sway bar made by itself, but I can tell you that the Dinan Stage 2 suspension versus the stock suspension is like night and day. Almost no roll when making a hard lane change, and when I make a hard corner at a favorite spot of mine I find I can hit it at higher speeds than I did before the change.
Hope this helps.
Jeff
2003 M5 LeMans Blue/Caramel/Walnut
Dinan S3 Includes all Dinan S3 Mods With JRZ Sruts/Shocks, Oil Cooler, Monoball Links
StopTech 4 Wheel BBK With Red Calipers And Slotted Rotors
Axxis Ultimate Pads
M Enhanced Audio
Park Distance Sensors
Two Sets Of Dinan Lightweight Forged Wheels
Winter Tires - Michelin Pilot Sport A/S - 275/35ZR18(Y) (F); 285/35ZR18(Y) (R) (Not Sure If They'll Survive The S3)
Summer Tires - Toyo RA1s- 275/35ZR18(Y) (F); 275/35ZR18(Y) (R)
Dual, Front Mounted LE30's With Custom AIDesigns Kill Switch/LED Panel
Valentine V1 With Stealth One
UUC Short Shifter With DSSR
Oil - BMW/Castrol 5W30 Changed and tested every 3000 miles.
