Brake discs replaced - BMW M5 Forum and M6 Forums
Old 4th September 2003, 13:50   #1
Gus
Gus's Avatar
Garage: M5 2006 Onyx Blue/Indi Red/Walnut
I've done almost 60k and the dealer is saying my front discs need replacing! Anyone else had this? (I've only had the pads changed once!)
Gus is offline   Reply With Quote
Old 4th September 2003, 16:02   #2
M5 XDW
M5 XDW's Avatar
Garage: Silverstone Blue M5
I had mine replaced at 43000,they was warped!!The rears are looking a bit worn now at 50000.
M5 XDW is offline   Reply With Quote
Old 4th September 2003, 17:29   #3
c4m5
Garage: 2000 Alpine White #2
My fronts were replaced @ 60k also (to thin), I had the Euro spec floating rotors installed.
RIP #1: 11/2010: 12/99 Build, 2000 Alpine White, Silverstone Sport Interior, 2001 Instrument Cluster, Dinan Short Shifter, Dinan 17mm Rear Anti Roll Bar, Floating Front Brake Rotor's, Open Brake Ducts, White Calipers, Michelin PS2's, MKIV Navigation, BMW Bluetooth HF VA Phone, No Exterior Badging, Valentine One, OEM 1st Aid Kit, Stealth Bulbs, Powerchip Software
#2: 12/99 Build 2000 Alpine White, Caramel Interior, Grey Instrument Cluster, Short Shifter, Hard wired Valentine One, MKIV Navigation, BMW Bluetooth
HF VA Phone, No Trunk Badge, Tinted Rear Windshield, Remus Sport Mufflers, Resonator Delete, X-Pipe, Open Brake Ducts, Michelin Pilot Super Sport Tires, X5 Thrust Bushings
c4m5 is offline   Reply With Quote
Old 4th September 2003, 18:35   #4
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II 93 M5 3.8 Sterling Silber
WOW, that seems pretty good to me
Based on my past experience with bmw (non m cars however) that sounds like pretty good rotor life! Most of the time, the rotors and pads tend to get replaced at the same time, as I've been told the rotors would be past their minimum thickness around the same time as the second set of pads are about half way worn down. Maybe the M5 rotors are beefier, and last longer, but 60k seems like pretty good life. I had usually gotten around 20-25k on a set of rotors and pads, with some track time (and track pads) on my 528 (with larger 540 brakes)...
60k certainly sounds reasonable to me...
00 M5 titan silver, imola/black sportiv
98 528i
03 LandCruiser
mottati is offline   Reply With Quote
Old 4th September 2003, 19:49   #5
kiwi M & M
kiwi M & M's Avatar
Garage: '01 ///M5 Silverston/ LeMans Interior
Re: WOW, that seems pretty good to me
98 528i
03 LandCruiser
Correct me if I'm wrong, but track pads do wear the rotors down a lot faster than stock pads. Having said that, my 95 M3 rotors were replaced twice during my 70k ownership with original bmw pads . Need stoptech rotors and pads...
-Jay
"You've gotta have a lot of balls to play golf like I do."
'01 / / / M5 Silverstone/LeMans/Titanium
'95 / / / M3 Cosmo Black/Black SOLD
kiwi M & M is offline   Reply With Quote
Old 4th September 2003, 20:51   #6
mottati
mottati's Avatar
you are correct, some track pads can eat up rotors, but even prior to using them, my rotors seemed to be pretty worn down, with a significant 'ridge' at the edge, after on set of stock bmw jurid or textar pads (usually around 25k, with maybe 2 or 3 weekends at the track).
Old 4th September 2003, 23:17   #7
BmwNut
Guest
I could be wrong, but i was under the assumption the BMW used fairly soft rotors, and that they didnt lead the longest life. My old E39 528 ate pads at 45k, with a recomended rotor replacement (I didnt track it, but ran it hard through the twisties every day). So, 60k for a beast sounds reasonable to me. My mothers e34 525 took rotors at 75k, but she drives like someone in their 90s, so they led an easy life
Enjoy the beast!
Old 5th September 2003, 07:56   #8
DZeckhausen
DZeckhausen's Avatar
Garage: 2012 328i 8-Speed, Mineral Grey Metallic
They don't use "soft" rotors. The metallurgy of rotors is very similar across the different car brands. Everyone uses grey iron for rotors with minor tweaks of the impurities to trade off different characterisitics, such as strength for susceptibility to pad deposition.
The BMW rotors have thinner friction plates than Mercedes and other brands. BMW allows 1.6mm of total rotor wear, whereas Mercedes allows 2.4mm. Thus, Mercedes rotors tend to last longer than BMW rotors. Nothing to do with the compostion of the iron. BMW trades off larger air gap (better cooling) for thinner friction plates (shorter life).
Dave Zeckhausen
Owner, Zeckhausen Racing
2001 540i 6-Speed (Sold)
M5 Front Swaybar
Dinan Stage 3 Suspension
Dinan Front Strut Tower Brace
European Dash Conversion
CDV Deleted (of course!)
Bluetooth, NAV-TV, DVD Player
2006 Chrysler 300C SRT8 w/StopTech ST-60 front/ST-40 rear BBK
2007 Corvette Z51 Coupe 6-Speed w/StopTech Trophy ST-60 front/ST-40 rear
2009 Honda Fit Sport w/NAV w/Acura Integra front calipers, StopTech floating rotors on order
2012 BMW 328i Luxury Line, 8-Speed
DZeckhausen is offline   Reply With Quote
Old 5th September 2003, 18:19   #9
Need4Spd
Need4Spd's Avatar
Does anyone make cross drilled rotors that are direct replacements for stock rotors for our cars? I know the cross-drilling is just to look cool, but... inquiring minds want to know! Zimmerman makes nice ones, but I don't think they have an application for the M5, or do they?
Need4Spd
'01 M5 (now my brother's car) UUC SSK + Rogue WSR/RE Tranny Mounts+Royal Purple Synchromax/Axxis ULT Pads/StopTech SS Lines/TC Design from BeastPower Anti-roll Bar Brackets/Dinan LtWtFlywheel and Stage 3 suspension/4xOEM rear 275 Goodyear F1 Asymmetrics/Vines thrust arms/IATS relocation/10w-60 oil/hardwired Escort 9500i/Euro Armrest/TEC Cupholder/IceLink/PowerChip 91 Gold/TUBIs!/Strong Strut/BSW Stage 1/BT/Angel iBrights 3.0/space-saver spare by Bimmerzone
'11 Jaguar XFR, Quicksilver exhaust, Escort 9500ci
Unnamed weekend Italian 2 seater with DCT
Future - F10 M5 with manual transmission?
Need4Spd is offline   Reply With Quote
Old 5th September 2003, 18:35   #10
ColinM
ColinM's Avatar
Garage: BMW E39 M5 Le Mans Blue
My discs cause vibration through the steering wheel under braking which I guess is caused by warping or pad material on the surface. The car has done 44000 miles.
Is it worth skimming the discs and then using new better pads instead of buying new discs ?
ColinM is offline   Reply With Quote
How to install LED brake lights atomic80 M5 E39 and E60 tips & tricks 4 27th November 2012 02:05
First pics of the E60 M5 front brake discs - sort of :) Tom_K E60 M5 and E61 M5 Touring Discussion 8 1st October 2003 23:06
Tarox Brake discs Ashok Arora E39 M5 and E52 Z8 Discussion 0 2nd October 2002 19:59
1995 M5 front brake discs john elmes E34 M5 Discussion 4 3rd July 2002 14:54
Corroded brake discs Ian E34 M5 Discussion 9 18th February 2002 12:15
