Bob
I just did mine last week, although I have a slightly different kit. Ben, at my request, shortened the shifter 1 inch, so there is no other reduction in the linkage. I did the tranny mounts and RP. The overal throws are dramatically reduced. I find the shifting stiffer, mostly at lower rpms. However, when shifting around 3500 and above, it is very smooth. Not sure if that info helps.
