2nd August 2003, 23:30
#11
Avus M5
Thanks dude for the cliff notes version of the results  i'm too lazy to read all of the threads
how much does it cost? this will probably be one of my first mods.
3rd August 2003, 00:00
#12
The cost of the Air Temp Sensor is $100 plus shipping from Dan at UFMotorSports.
The labor is on you! ...
OR ...
you'll have to find a M-Technic mechanic that will do it for you.
A BMW dealership will NOT do it.
At least they wouldn't do it for me!! They said that they will have "No Part" in helping me void my new car warranty.
3rd August 2003, 02:15
#13
Avus M5
OR ...
how the hell does that void new car warranty? thats the dumbest thing i've heard, some bmw dealers can be real pricks. well since its DIY install im definately capable of doing it.
$100 doesn't seem like a bad price for well done kit that will help power loss. thanks agian
3rd August 2003, 03:26
#14
Moderator Emeritus
where exactly does the temp sensor relocate to? The stock one is on the passenger side under the bumper right?
US Spec 2001 E39 M5 - LHD
AC Schnitzer
Dinan
3.45 differential
Others
Euro Spec 1999 E39 M5 - RHD
2007 Mercedes E63
2007 Corvette Z06
2008 Nissan GTR
2011 Ferrari 458
3rd August 2003, 03:33
#15
Hey T,
I believe the Stock sensor is near the drivers side MAF. We are talking about Air Intake Temp Sensor. Not the temp sensor that tells you how hot it is outside and gives you a reading on the dash.
The one in question tells the Engine the temp of air it is getting. When the sensor gets Heat soaked (Hot from the engine) it gives the engine false readings.
If we move the sensor away from the Hot motor, the sensor wont be hot, and therefore can give accurate readings.
You don't warm up a thermometer before you take your own temp do you? Same deal. The stock location starts to read engine temp instead of Air intake temp, thus a falsly high reading.
Hope this mad a little more sense.
///Mark 03 E39 M5 He's in Apples hands now. MIB
3rd August 2003, 03:38
#16
Moderator Emeritus
oh ok... was thinking the wrong thing...
so if the air intake temp sensor is inside the MAFS, then what about with the Dinan MAFS? The Dinan ones are much more insulated than the stock ones... is it possible to relocate it for that? or is it even necessary at all?
3rd August 2003, 06:27
#17
TFung...check out the link I posted to UFMotorsport. Don says that you can't insulate them well enough. I believe the Dinan MAF's also incorporate the air intake temp sensor into one of them, but the new upgrade to the Dinan CAI will move them temp sensor down by the front bumper, near where the outside/ambient temp sensor is.
Believe me, it makes a considerable difference on the hot days!
Steve
'02 M5 LeMans Blue:
Supersprint Headers and cats
Dinan Stage III suspension
BeastPower sway bar brackets
Dinan front strut tower brace
RMS short shifter
Llumar window tint (35%)
3rd August 2003, 06:35
#18
Moderator Emeritus
The Dinan CAI has ANOTHER upgrade?
the last upgrade I did to the CAI added some heat shields near the filter area, and I was told that a temperature sensor was moved... maybe that was it.... wonder if that would be the same as the UFMotorsport kit....
3rd August 2003, 06:48
#19
Le Mans Blue M5
I am just wondering where is UFMotorsports located at? Also, is there a phone number I can call them at? I can't seem to find a phone number at their website. Thanks guys.
01 Le Mans Blue M5
TUBI Exhaust, ACS Front Splitters, ACS Pedals, KW Coilovers, ACS FR Sway Bars, UUC Short Shift, Evosport UD pullies, GruppeM Intake, Ignition Solutions Plasma Coils, Rennsport Velocity Stacks, Rennsport Headers, Supersprint Cats
03 Alpine White Z4 (Wife's car)
19'' Hartge Classics, Toyo T1S 235/265, Hartge Pedals, ACS Suspension Kit, Ignition Solutions Plasma Coils
03 Sapphire Black 760Li (Parent's Car) with too many bells and whistles on it.
3rd August 2003, 07:55
#20
M5 Extraordinare!
Hey guys,
Since it was me that first introduced the relocated sensor to XrayMD I felt that I should talk a bit about my own experiences with this upgrade.
Don himself helped install the temperature sensor in my M5. It was scary seeing my car without the bumper in place. I managed to take a few pictures although in a lapse of judgment I happened to forget about taking a picture of where the sensor actually goes. I can tell you that it goes inside the front bumper directly behind the lower center grille. Before you ask about whether the airflow affects the sensor reading, nope, it's behind the plastic deflector behind the grille so the readings that the new sensor gets is fairly accurate. Looking at the layout I can definitely verify this. And the results were definitely noticable as XrayMD confirmed.
As for the website, it's ufmotorsport.com and Don can be reached via email at sales@ufmotorsport.com. I don't think he'd appreciate me posting his phone number on here.
Don is a friend of mine who happily agreed to perform the mod for free and I couldn't be happier about the end results!
Jason
'00 Chinook Baja w/mods
'05 Range Rover w/mods
'05 K1200S w/mods
'07 997TT w/mods
'08 Audi A3 w/mods
'09 Ferrari Scuderia w/mods
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
