Old 14th July 2003, 05:33   #1
Teutonaddict
Teutonaddict's Avatar
Garage: '00 Carbon Black/Black All-Leather/Sportive
TECH: minimum spec on rear rotors?
Just changed out my rear Mintex Red Box pads (at ~1mm friction material remaining) and replaced them with Axxis Deluxe Plus (thanks, DaveZ!). I could not find the minimum thickness spec stamped on the OE rear rotor. Anybody know what it is?
My micrometer says current thickness is .755", or 19.2mm.
TIA!
On a similar note: has anyone found a good source for OE rotor replacements? In the past, I've bought stock front rotors from the mailorder department at Pacific BMW. I'm not sure if there's another good resource for OE rotors.
I'm considering having them gas slotted to match my StopTech 355mm fronts.... any vendors to recommend?
-Dave
BOTH SOLD!!
#101421
Teutonaddict is offline
Old 14th July 2003, 12:23   #2
DavidS
DavidS's Avatar
Garage: 2000 M5 LeMans blue
Sales Feedback: (4)
Those are 20 mm when new. I think the minimum is 18.4 mm.
David
DavidS is offline
Old 14th July 2003, 14:08   #3
DavidS
DavidS's Avatar
Sales Feedback: (4)
Now I´ve checked it:
Front: 32 mm new / replace at 30.4 mm
Rear: 20 mm new / replace at 18.4 mm
David
http://www.m5board.com/vbulletin/showthread.php?t=54788
http://www.m5board.com/vbulletin/showthread.php?t=88323
DavidS is offline
Old 14th July 2003, 18:37   #4
Teutonaddict
Thanks for verifying, DavidS!
Now my second question is less significant: no need for new rear rotors when I'm only at 50% of allowable wear!
Monday morning's little victory: woo-hoo!
BTW, these things wear like iron (tee-hee)! I wore thru a set of OE pads (Jurid, I believe), then a set of Mintex Red Box, and now onto the Axxis replacements. That's 58K miles, of which ~3K was on a track!
BOTH SOLD!!
#101421
Old 14th July 2003, 20:04   #5
DavidS
DavidS's Avatar
Sales Feedback: (4)
You´re most welcome, Teuton!
David
DavidS is offline
Old 15th July 2003, 00:33   #6
Need4Spd
Need4Spd's Avatar
Uh, that's 'cuz they ARE iron. BTW, are Axxis Deluxe Plus pads off back-order yet? They've been out of stock so long I'm thinking of buying a spare set just to keep them in the garage!
Need4Spd
Need4Spd is offline
Old 15th July 2003, 04:24   #7
Teutonaddict
Need-
I recall the backorder discussion, but when I ordered mine (late May) the were drop-shipped directly from the distributor. No delays.
-Dave
BOTH SOLD!!
#101421
Old 20th July 2003, 01:49   #8
celler
celler's Avatar
Garage: 2002 E39 M5 Alpine White
In case you need this information again, all BMW rotors have the minimum thickness etched in the "hat" portion of the rotor. The figure is in millimeters. Look for what appears to be several connected dots and you will have found it.
Best wishes.
Craig.
celler is offline
Tech: ETK/TIS question: differential fluid spec? Teutonaddict E39 M5 and E52 Z8 Discussion 3 26th May 2003 20:23
TECH: has anyones rear sway bar bracket snapped? young-nyc E39 M5 and E52 Z8 Discussion 33 10th October 2002 10:30
TECH: Why aren't the OEM rotors cross-drilled? B-Pac E39 M5 and E52 Z8 Discussion 39 12th May 2002 23:50
Floating rotors - front and rear raland9 E39 M5 and E52 Z8 Discussion 1 24th April 2001 20:40
Page generated in 0.14529 seconds with 11 queries
