Old 14th July 2003, 03:41   #1
BKH
BKH's Avatar
Garage: 2000 BMW M5 Silverstone
Does the E39 M5 have an event data recorder?
As per the newspaper article quoted below, does anyone know whether the E39 M5 has an event data recorder?
"An estimated 25 million automobiles in the United States--almost every newer GM car--now have so-called event data recorders, a scaled-down version of the devices that monitor cockpit activity in airplanes. What the devices record increasingly finds its way into courtrooms, leading some privacy advocates to question how the recorders came to be installed so widely with so little public notice.
"It's like having a government agent driving around in the back seat of your car," said Bob Weiner, defense attorney and a former prosecutor. Most people apparently don't even know whether the vehicles they drive are equipped with event data recorders. Nearly two-thirds of people surveyed by an insurance industry group knew nothing about them.
Prosecutors, police and accident reconstructionists say the boxes yield information no different from what can be gleaned from crushed metal, skid marks and other evidence at the scene. Now, they say, calculations can be backed up.
"It's appearing in prosecutors' cases in support of the normal reconstruction," said W.R. "Rusty" Haight, director of the Collision Safety Institute."
BKH is offline
Old 14th July 2003, 03:46   #2
Digi
Digi's Avatar
Garage: 2006 M5 Silverstone II
I wondered the same when I read this story.
Digi is offline
Old 14th July 2003, 05:48   #3
greg
greg's Avatar
Garage: 2000 Anthracite
If it does, it would be the best kept secret in the world. We have so many members who've been through every part of the car, asking or telling "what's this" and "what's that". The known computers in the car, whether the engine management system the nav system, whatever - are all pretty well understood.
So the answer is - I sincerely doubt it.
greg is offline
Old 14th July 2003, 05:57   #4
Vadim-SoCal
Vadim-SoCal's Avatar
Garage: '02 C32 AMG Silver/'01 Black M5 incoming
E46M3s record number of parameters that dealer can access during warranty claim or service. There is a lot of info on this topic on www.roadfly.com.
I would imagine E39 has a similar feature.
I will ask Wayne at POWERCHIPS and see if he is aware of this.
Vadim-SoCal is offline
Old 14th July 2003, 08:27   #5
greg
greg's Avatar
Sure, the engine management computer probably remembers max RPM, probably temperature and other parameters the engine has seen. This can be used to prove that you hit 2nd instead of 4th on a downshift,, over-revved the engine and broke it. Of course, this WOULD be the only way to run the engine past watever redline your cihip has specificed, so you would in fact be at fault. i don't have a problem with that.
I still see ZERO EVIDENCE of anything remotely resembling the cockpit voice and data recorders (as alluded to in the first post of this thread), which record every word said in the cockpit (30 min max, I think), the position of every control input and the corresponding controlled items' response, and a host of other parameters.
Vadim - it would be helpful if you could point us to actual posts of verifiable fact, as opposed to a URL leading to thousands of pages about a boatload of cars. Can you be more specific?
greg is offline
Old 14th July 2003, 17:47   #6
Fast6
Garage: Red 1983 645
Here's a pretty good site:
Event Data Recorder
From what I read, the government has denied several petitions to force manufacturers to install EDRs on all cars. Looks like it's mostly Ford and GM that are using them. So Greg, you're probably right that BMW doesn't have them, but there are sections on that site that refer to Ford and GM being pretty hush-hush about them, so I wouldn't rule BMW out.
I read an article just a few days ago about a guy who was involved in an accident that killed two young girls. This guy's defense attorney claimed he was going 50 mph when they collided. However, the EDR recorded a speed of nearly 100 mph at the time of collision.
However, it looks like they're now mandatory on school buses. Here's an excerpt from one of the pages on the site above that describes what they record:
H-99-53 (NHTSA) Require that all school buses and motor coaches manufactured after January 1, 2003, be equipped with on-board recording systems that record vehicle parameters, including, at a minimum, lateral acceleration, longitudinal acceleration, vertical acceleration, heading, vehicle speed, engine speed, driver's seat belt status, braking input, steering input, gear selection, turn signal status (left/right), brake light status (on/off), Head/tail light status (on/off), passenger door status (open/closed), emergency door status (open/closed), hazard light status (on/off), brake system status (normal/warning), and flashing red light status (on/off) (school bus only). For those buses so equipped, the following should also be recorded: status of additional seat belts, airbag deployment criteria, airbag deployment time, and airbag deployment energy. The on-board recording system should record data at a sampling rate that is sufficient to define vehicle dynamics and should be capable of preserving data in the event of a vehicle crash or an electrical power loss. In addition, the on-board recording system should be mounted to the bus body, not the chassis, to ensure that the data necessary for defining bus body motion are recorded. (Source -- Special Investigation Report -- Bus Crashworthiness Issue, (NTSB/SIR-99/04).)
'06 M Coupe #308 - Silver Gray/Sepang Brown Dark
E36 M3 gone
E24 645 gone
Fast6 is offline
Old 15th July 2003, 02:44   #7
XrayMD
XrayMD's Avatar
Garage: LeMans Blue M5,Silver X5 & Dk. Silver Mini S
The stock ECU also has OBDII freeze frame capability so that if some type of system failure occurs, the ECU stores a freeze frame of all OBDII parameters.
This data can be read with a program such as Autotap or Auterra and includes numerous parameters including RPM, vehicle speed, etc.
This is not quite the EDR you're discussing, but it is interesting.
Steve
'02 M5 LeMans Blue:
Supersprint Headers and cats
Dinan Stage III suspension
BeastPower sway bar brackets
Dinan front strut tower brace
RMS short shifter
Llumar window tint (35%)
XrayMD is offline
Old 15th July 2003, 05:04   #8
BKH
BKH's Avatar
Assuming one doesn't want this device in their car (and I don't), the one thing in our favor is that it's so late in the product cycle it's hard to conceive of BMW adding one mid-stream rather than waiting for a clean-sheet design. In any case I wouldn't expect a manufacturer to be particularly forthcoming with any details or diagrams - why give anyone the ammo to defeat it?
BKH is offline
Old 16th July 2003, 10:26   #9
VanCooper
VanCooper's Avatar
Garage: 2007 VW GTI
Before I comment on this, I would like to know what are the advantage/disadvantage of having such a device on their car and secondly, why would someone want/not want an EDR on their personal car?
I had never heard of EDR on cars before so that's why I'm asking these questions. Thanks
P.S. The main disadvantage that I see would apply to me is that I wouldn't want anyone to know that I have a heavy foot and it could influence the authorities in case of an accident!
2006 Interlagos Blue M5 - My father's
2007 VW Golf GTI - My little rocket!
VanCooper is offline
Old 16th July 2003, 10:44   #10
striker79
Garage: not a beemer(yet)
This is kinda a tuff question to answer as since the intro of obd 2 there have been some form of edr on all cars sold in the usa.And i know that if your m5 roles into a shop with a blown engine claiming that it was not your fault bmwna can read the dme and it will tell them what you were doing when the engine went away.Now for the scary stuff soon we will have obd 3 and it will use cell phone towers to send a link to the goverment to tell them if you ses light is on and they will send you a letter saying get it fixed in 48 hours or pay a huge fine.Now one would think if they could tell that much why could they not tell your speed or track you scary for sure.
striker79 is offline
Wooo tfung gone off deep end... EBMCS03 Off Topic Forum 4494 Yesterday 18:20
Rumours about the E39 M5 pre 1998. Gustav F10 M5 Discussion 15 21st October 2009 01:11
Dinan Exhaust AlbertM E39 M5 and E52 Z8 Discussion 5 6th October 2000 19:11
Page generated in 0.26665 seconds with 11 queries
