Old 11th March 2001, 02:38   #1
jlvink
jlvink's Avatar
Garage: 2000 M5 Titanium Silver
Post Clunking sound while turning??
While driving my car this morning I noticed that while turning and driving across a slightly uneven surface, a noticeable "clunk" sound emanates from the front of the car. Sort of a dull "pop".
Have any of you experienced this? What part of the suspension could be doing this? I have not had any unusual experiences or accidents that could explain this symptom.
John
jlvink is offline
Old 11th March 2001, 12:19   #2
alpywhite
alpywhite's Avatar
Garage: 2006 BMW M5, Silverstone
I get the same noise when winding down my underground parkade. Sounds like a suspension or drivetrain sound. It isn't driving me nuts yet.
alpywhite is offline
Old 12th March 2001, 04:37   #3
jlvink
jlvink's Avatar
Post
alpywhite,
At first the "clunk" sound happened very infrequently like yours. Went for a drive today and the sound was louder and it happened more often. I'm going to have to take it in to the dealer real soon to have it checked out.
John
jlvink is offline
Old 12th March 2001, 05:02   #4
ivory1
ivory1's Avatar
Post
John--
If it is a "popping" noise, can you feel an accompanying pulse through the steering wheel? If so, I would suspect a bad wheel bearing and/or incorrect hub torque situation.
Is the noise at the RPM of the tire rotation, like a brake pad rubbing a warped rotor? Such a sound wouldn't be as pronounced as a "popping" sound.
Originally posted by jlvink:
...I noticed that while turning and driving across a slightly uneven surface, a noticeable "clunk" sound emanates from the front of the car. Sort of a dull "pop"...
John
ivory1 is offline
Old 12th March 2001, 14:08   #5
jlvink
jlvink's Avatar
Post
ivory1,
The sound is not continuous - only once in a while during slight turning. An uneven surface will cause it to happen more often. Sounds like the front left side only.
John
jlvink is offline
Old 12th March 2001, 14:37   #6
daniel
Post
I've also got it, when descending down steep grades at a snail's pace. Sounds like something in the spring area.
daniel is offline
Old 21st January 2004, 02:28   #7
lwebb12
lwebb12's Avatar
Garage: Oxford Green Metallic 2000 M5
Send a message via AIM to lwebb12 Send a message via Yahoo to lwebb12
Re: Clunking sound while turning??
Sorry to resurface an old thread. I am wondering if anyone found a solution. I have about the same problem. Mine is only at slow speeds. 20 mph and less. When going faster or stopped it doesn not happen.
lwebb12 is offline
Old 21st January 2004, 02:50   #8
Serb
Serb's Avatar
Garage: '00 Alpine White M5
Send a message via AIM to Serb
I started a post on this topic awhile back in regards to my popping noise on my 00' M5. BMW ended up replacing my steering column hose (I could be way off, but it was a hose of some sort, I'll dig into the exact name later).
That seemed to have fixed the problem, but it is back again.
It seems to only happen when I leave my car outside in cold temperature. And it only last for 5 min or so until the car warms up. Really, really weird. I am going to take it in again on Thursday. I'll let you know.
"I love its intake howl, exhaust burble, communicative steering, rock-solid chassis, and the way it pulls at my gut on a hard launch. It knows what it is, and it's damned good at being it."
Serb is offline
Old 21st January 2004, 03:43   #9
Digi
Digi's Avatar
Garage: 2006 M5 Silverstone II
Sounds like bad control arms to me. This is a common problem on X5s. It starts just on turns or over bumps (My X5 started just when turning left at 8K miles). It then progresses to noise that sounds like a plastic straw going up and down through a plastic top on a plastic cup of Coke over every bump or turn.
Digi is offline
Old 21st January 2004, 03:48   #10
lwebb12
lwebb12's Avatar
Serb thanks for the reply. Thursday sounds cool. Can you ask the BMW dudes how intensive it is to replce said hose? I am a mechanic so I am capable.
Digi. Is it the control arms themselves or is it the bushings? I would think that control arms should not be going bad this early.
lwebb12 is offline
clunking sound under car another_lap E39 M5 and E52 Z8 Discussion 1 18th May 2003 11:53
Strange metallic sound... Fedde E39 M5 and E52 Z8 Discussion 10 4th September 2002 18:56
More engine sound at idle please Tom E39 M5 and E52 Z8 Discussion 11 22nd June 2000 06:02
Z8 sound Viken Bedrossian E39 M5 and E52 Z8 Discussion 1 5th April 2000 01:00
Page generated in 0.18783 seconds with 11 queries
