m5board.com Advertisers are: Download GTBoard.com Supercar Shootout 1 + 2 in HD 1920x1080 360 Forged 503 Motoring (OR) Angel iBright ASR Engineering Bavarian Soundwerks Bimmer Performance Store BMS BMW service CA Automotive CNS RacingDinan Cars EisenmannNA ESS Tuning Eurosport Design Evosport GTboard.com < "Supercar Shooutout II: 40+ car in action incl. BMW M3 E92" Hartge (Member discount) HRE Wheels Kreissieg Medford Tools (OR) Meist GT modbargains.com Neez Powerchip Group Race Precision Revozport Supreme Power (CA) TireRack BMW M5 Upgrade Garage for wheels, tyres and suspension Tubi Style North America Turner Motorsport Umnitza UUC Motorwerks Zeckhausen Racing BLACK LIST OF NON-APPROPRIATE VENDORS Be an m5board.com Advertiser!
Old 29th May 2003, 01:19   #1 (permalink)
VanM
VanM's Avatar
View my Le Mans Blue M5
Tire Pressure
Hi all,
I am just wondering what is the proper tire pressure for our cars. I have the Dunlops on. I know that the tag on the driver's side door sill tells me but it only lists the fully loaded pressure. My car hardly ever has more than two people in it. Any answer will be great. Thanks.
01 Le Mans Blue M5
TUBI Exhaust, ACS Front Splitters, ACS Pedals, KW Coilovers, ACS FR Sway Bars, UUC Short Shift, Evosport UD pullies, GruppeM Intake, Ignition Solutions Plasma Coils, Rennsport Velocity Stacks, Rennsport Headers, Supersprint Cats
03 Alpine White Z4 (Wife's car)
19'' Hartge Classics, Toyo T1S 235/265, Hartge Pedals, ACS Suspension Kit, Ignition Solutions Plasma Coils
03 Sapphire Black 760Li (Parent's Car) with too many bells and whistles on it.
VanM is offline
Old 29th May 2003, 02:23   #2 (permalink)
BeastPower
Guest
This is a very complex question, because you can use several different settings, and have the car still perform well.
I used 36 in the front and 38 in the rear, which is great for track and fast street driving. 42F/42R and 42F/44R are both good combinations, but a little high for optimal traction.
Cheers.
Old 29th May 2003, 02:28   #3 (permalink)
greg
greg's Avatar
View my 2000 Anthracite
There is no "right" answer, but here are some guidelines (my opinion only):
1) Light load (1-2 people, min baggage); street driving, good ride, performance priority: 32f/34R
2) Moderate load (2-3 people, bags or other trunk load), street driving, performance priority - 34f/36R
3) Heavy Load, street driving, performance priority: 36f/38r
4) Extended driving over 100mph: bump above pressures by 4 PSI
5) Extended driving over 120mph: bump above pressures by 6 PSI
6) Extended driving over 140mph: bump above pressures by 8 PSI
If gas mileage and tire life are prioritizede over performance, (compromise in grip and ride quality OK): Bump above pressures by 6 PSI.
ALL ABOVE PRESSURES ARE MEASURED COLD - I.E., 65 DEGREES F.
7) Track driving - depends on track - but goal is about 38-40 PSI HOT. Use higher pressures up front relative to rear if front tires are rolling over.
greg is offline
Old 29th May 2003, 02:32   #4 (permalink)
XrayMD
XrayMD's Avatar
Interesting Greg thanks. I think you're right...it ends up being somewhat of a matter of personal preference and should vary with your driving habits.
For me and my S03's, 40F and 42R seems to work well!
Steve
'02 M5 LeMans Blue:
Supersprint Headers and cats
Dinan Stage III suspension
BeastPower sway bar brackets
Dinan front strut tower brace
RMS short shifter
Llumar window tint (35%)
XrayMD is offline
Old 29th May 2003, 06:14   #5 (permalink)
VanM
VanM's Avatar
Thanks for the numbers guys.
VanM is offline
Forum Jump
Bridgestone S03's and track tire pressure rprellwitz E39 M5 and E52 Z8 Discussion 20 20th June 2003 08:28
droppping tire pressure M'nd E39 M5 and E52 Z8 Discussion 4 31st October 2002 17:06
New owners: You MUST calibrate the tire pressure monitor greg E39 M5 and E52 Z8 Discussion 2 25th October 2001 01:46
Did you check your tire pressure today? SteveP E39 M5 and E52 Z8 Discussion 6 7th November 2000 19:28
tire pressure and oil type nascar E39 M5 and E52 Z8 Discussion 3 16th September 2000 03:56
