heated seats dont work??????? help!!! - BMW M5 Forum and M6 Forums
Old 1st March 2001, 16:11   #1
randy
Post heated seats dont work??????? help!!!
ok so last night my girlfriend and i pressed each heated seat button and the three lights came on and then 1 second later they turned off???? anyone else have this problem??
randy is offline   Reply With Quote
Old 1st March 2001, 16:59   #2
MarkM5Lauderdale
MarkM5Lauderdale's Avatar
Garage: 2002 Mini Cooper S
Post
Yup..took 3 months to get it repaired. Had to replace the entire assembly because it kept shorting out.
Good luck
Mark
2000 Dinan M5
2001 X5 4.4 Sport
Mark's M5 Page
modo2@email.msn.com
MarkM5Lauderdale is offline   Reply With Quote
Old 1st March 2001, 17:00   #3
Stephen385
Garage: 2000 Silverstone M5
Post
I have the same problem. I just need to bring it in also. It isn't a fuse. I've tried that. Whoever gets it fixed first, post the answer... Good luck.
Stephen385 is offline   Reply With Quote
Old 2nd March 2001, 04:10   #4
brutus
brutus's Avatar
Garage: '06 E60 M5 Black Sapphire Metallic / Inianapolis Red Full Leather
Post
Just had my M5 in for this problem, the diagnosed as the a drivers seat short, disconnected the seat and replaced the
fuse while waiting for the heating pad.
Went back in on 2001.02.26, sent it to the upholstery shop to have the seat opened up so they could replace the pad
only to find that it was the wrong part, figured out the correct part number for the sport seat, put the seat back
together, just picked it up today 2001.03.01.
So if you have the sport seats make shure the dealer knows that there are three pads (not one), also the part is on back order and the dealer (Allison in Mt. View) had know idea when it might be in.
I used the heated seat a few times on the drive back home from the dealer last year (Edison NJ to Sunyvale CA) then
went use the seat a year later and it was bad.
Brutus http://L1-A.net
brutus is offline   Reply With Quote
Old 2nd March 2001, 05:03   #5
randy
Post
well the car goes in at 8am tommorow so we will see........thanks again ,what a great group we have here
Old 2nd March 2001, 13:19   #6
Jim Dolan
Jim Dolan's Avatar
Garage: 2006 M5 Silver Grey Metallic
Post
Our seats here in hot tropical south Florida work just fine
Jim
07/00 M5 Titanium over Red
Jim Dolan is offline   Reply With Quote
Old 2nd March 2001, 15:11   #7
Jester
Garage: M5 Titanium Silver
Post
I use my heated seats constantly to ail my lower back
I have the luxury seats and have not had one problem yet, knock on veneer.
'00 NBM Vette Convertible Pic #2
'00 ///M5 Titanium Silver/Caramel
[This message has been edited by Jester (edited 02 March 2001).]
Jester is offline   Reply With Quote
Old 6th March 2001, 05:28   #8
Scubabob
Scubabob's Avatar
Garage: 2000 Titanium Silver
Post
I had the same problem with the driver's side seat heater right after buying the car. You'll notice that when the seat heaters are dead, the rear sunshade doesn't work either. The defective driver's side seat heater always blew the fuse when being turned off, as strange as it sounds. I could replace the fuse, turn it on, have the heater warm up, then blow the fuse when being turned off. Had it fixed a week after picking up the car.
Scubabob is offline   Reply With Quote
Old 7th March 2001, 11:04   #9
DrJimM5
DrJimM5's Avatar
Garage: 2000 Titanium silver M5
Post
I had the same problem that took 3 tries to fix. They first thought it was the driver's lower central pad and replaced it. They blew one day later. Then they thought it was the lateral pads, but they decided to check all the wiring first. After reassembly without the new pads, it has been working fine for 2 months. Latest theory was rubbing of harness somewhere caused the fuse to blow. Not very scientific!
DrJimM5 is offline   Reply With Quote
Old 9th March 2001, 20:25   #10
randy
Post
Ok so my girlfriend took the car in on Thursday 3/8/01 and the dealership said it was a blown fuse which they replaced. They did however mention that certain production date ranges were having seat problems, but wouldnt specify which date ranges. I do remember that both me and my girlfriend had pressed the button at the same time, so i wont do that any more !!!!!!
thanks for all of your posts!!!!!
Nowack Tuning Report, The Truth (Long Version) CharlesW E39 M5 and E52 Z8 Discussion 90 2nd September 2011 09:49
Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 04:49
Picking colors: I need some help! -- Ferrari related bobafett E39 M5 and E52 Z8 Discussion 52 21st January 2001 07:15
Button next to the heated seats? Chuck E39 M5 and E52 Z8 Discussion 4 18th May 2000 09:10
