Is it ok to mix 5W-30 and 10W-30? - BMW M5 Forum and M6 Forums
post #1 of 10 Old 17th May 2003, 10:41 PM Thread Starter
B-Pac
Yes, yet another oil question for the board.... sorry. Anyway, as temps are heating up, I'm curious if i can add 10W-30 as the Beast needs it, even though the engine has only seen 5W-30 since it was new last summer. I currently have 6K miles, and have not yet had my first oil change. I've added 3 quarts of Mobil One 5W-30 since the car was new.
I would probably stick with 5W-30, except I'm moving to Austin in a few weeks where summer temps will be equivalent to the surface of the sun.
I don't want to re-open the whole 5W vs. 10W debate, I just want to know if there's any problem with mixing different weights before the first oil change. I wouldn't think there would be. Thanks for any input guys.
B-Pac
'02 TiSilver/Black
B-Pac is offline
post #2 of 10 Old 17th May 2003, 11:40 PM
TCM
TCM's Avatar
Stick with the 5w-30 as your engine is used to it and it is what the car requires. BMW has done the proper testing for the car so I would think that they tested 5w-30 in extreme heat conditions before clearing it for use.
T.C.
'01 Brushed Steel M5
front splitters
3.45 differential
'01 Silverstone M5- sold
SuperSprint:X-pipe
TCM is offline
post #3 of 10 Old 18th May 2003, 12:26 AM
Digi
Digi's Avatar
Digi is offline
post #4 of 10 Old 18th May 2003, 03:02 AM
AJ
pfffft.... as long as the high temp viscosity (the 2nd number) is 30 you should be ok.
for high-temp applications 10-30 is better than 5-30 as the smaller the difference between the two numbers the more stable the oil is.
oil is the most overrated issue i am aware of. 5-30 or 10-30 it is all the same. just make sure you change it often.
alex
02 gts
few other cars
AJ is offline
post #5 of 10 Old 18th May 2003, 12:52 PM
kwalls
kwalls's Avatar
Adding 10w-30 weight oil to your car will not provide any more summer protection than staying with 5w-30 oil that is already in the crank. While viscosity breakdown was a valid concern years ago with mineral oils this is not necessarily true with a blended synthetic.
It is a standard practice with aviation fleet maintenance to change oil on condition, not according to time events. Of course this involves testing of the oil to validate the oiling properties still exist and to check contaminate levels. In most cases I have found that we change the oil because of contamination problems before we reach a state that the oil does not comply with the physical properties of a given spec. While you and I may feel that the oil needs changing sooner, BMW developed their recommended oil change cycle based on these same facts.
Personally I intend to change my oil more frequently but left to the their computer program most cars will achieve 15000 to 18000 miles before the light goes red. BMW could only develop such a position and assure their liability for this recommendation by evaluating the affects of high mileage on crank case oil conditions and here in Germany the recommended oil is the 10w-60 synthetic.
Ken
03 BMW M5 ein gut fahrt
02 Volvo V70 XC der Frauto
Life may not be always be the party
I thought it would be, but while I am
here I'm going to DANCE
kwalls is offline
post #6 of 10 Old 18th May 2003, 01:21 PM
MIB
MIB's Avatar
Re: Is it ok to mix 5W-30 and 10W-30?
First Oil change should have been at 1,200 Miles.
Thats when all the junk from run in would contaminate the oil.
Yeah I know you don't have to, but I certainly will, as many others also have done, change it at 1.200.
Question, What colour is Oil? If you first thought Black, think again.
I never let my Oil go Black. Maybe a little over kill. But I expect high performance from my vehicles and i get it.
///M4 F82 2015 Mineral Grey
///M3 E92 2007 Jerez Black(Halle gave to my boy)
///M5 E39 2003 Steel Grey (Yoda Sold to Apples)
MIB is offline
post #7 of 10 Old 18th May 2003, 02:44 PM
D/FW M5
D/FW M5's Avatar
My car was a 6/2000 build and it has the 5W30 sticker, but being a Texas car I feel that the 10W60 is better during the summer months and certainly believe it is better if you track the car at all. As far as I know, both grades are approved by BMW for use in the S62 engine.
Doug
D/FW M5 is offline
post #8 of 10 Old 18th May 2003, 04:20 PM
atomic80
M5 Extraordinare!
atomic80's Avatar
The bottom line is that it's NOT okay to mix different oil types. The oil should be drained before you put in a different oil type if you're even thinking of that.
Jason
'07 997TT w/mods
'08 Audi A3 w/mods
'12 Ducati 1199 S Tricolore w/mods
'13 McLaren MP4-12C Spider w/mods
'14 BMW M-Sport X5 xDrive50i w/mods
atomic80 is offline
post #9 of 10 Old 18th May 2003, 05:21 PM
D/FW M5
D/FW M5's Avatar
I may have misunderstood your post, I was not advocating mixing different grades of oil together at the same time (if you are in a pinch however, and don't have a choice, it would be better to do this than run the car for very long too low). However, if you want better summertime protection in the hot temps, I think the 10W60 is a better choice.
Doug
D/FW M5 is offline
post #10 of 10 Old 19th May 2003, 03:30 AM Thread Starter
B-Pac
thanks for the input. I think i'll go ahead and get an early oil change, and put 10W in there for the summer.
B-Pac
'02 TiSilver/Black
B-Pac is offline
