10th May 2003, 18:05
#1
Coolant fluid access question
OK... this sounds stupid but, is the only access to the coolant fluid via removing the plastic cap on the white coolant overflow reservoir?
I've got some Redline Water Wetter I wanted to add to the coolant but that's the only place I see to add it and when I removed the cover, I could see that there wasn't enough room to add a whole bottle of the Water Wetter. Should I siphon off enough fluid from there first and then add the water wetter?
(Rob, I know I asked you this the other night, but that level hasn't changed and this just seemed odd to me!)
Thanks all!
Steve
'02 M5 LeMans Blue:
Supersprint Headers and cats
Dinan Stage III suspension
BeastPower sway bar brackets
Dinan front strut tower brace
RMS short shifter
Llumar window tint (35%)
