Engine Temp not longer gets to the middle of the dial (Pic) - BMW M5 Forum and M6 Forums
 2Likes
post #1 of 19 Old 6th September 2013, 04:17 PM Thread Starter
m5racer111
Hey everyone,
So a few weeks back I noticed that my engine temp no long got to the middle of the dial once the car was warmed up. Now the gauge needle only gets off the blue (cold side and just barley gets over the dotted line. Does this mean I kneed a new thermostat or engine temp sensor?
I got Code 105- Plausibility engine temperature the other day if that helps
m5racer111 is offline
post #2 of 19 Old 6th September 2013, 04:38 PM
HCrawford
My money is on the Thermostat. I had the same symptoms 2 weeks ago. Replaced the Tstat and all is better now. A very common failure point for the E39. Quite a few DIYs to help with the job.
HCrawford is offline
post #3 of 19 Old 6th September 2013, 04:42 PM
AGM5
AGM5's Avatar
Originally Posted by m5racer111 View Post
Hey everyone,
So a few weeks back I noticed that my engine temp no long got to the middle of the dial once the car was warmed up. Now the gauge needle only gets off the blue (cold side and just barley gets over the dotted line. Does this mean I kneed a new thermostat or engine temp sensor? I scanned the car and will post up the code that was there once its emailed to me from my friend.
Do you know if the code that registered was P0128 (Coolant Below threshold (or something to that affect)). If this is the case most likely it is time for a new T'stat.
///M - The most powerful & expensive letter in the alphabet
1 of 123 ANTHRAZIT METALLIC (397) / WALK NAPPA/SCHWARZ (M1SW)
Tuned by BMW Motorsports 4/2001, Bone Stock at 185,000 Miles. 355.78 WHP / 345.33 WTQ
2 facts you might not know: Ducks cannot fly and they nest in trees.
Updates:
BM53 Radio / Gen-13 ULF / OEM Sirius / MK-IV Navigation / Aux input / Intravee II / KCA-410c / KCA-420i / 5th Gen i-Pod Nano / CHA-S634 / Umnitza VXX Angel Eyes / F10 ///M5 Shift Knob /
Schmiedmann Shadow Chrome Grills / Rear Fog Lights
DIY: Retro-Fit Auxiliary Audio Input Harness /// DIY: E39 - BM53 & (BMW) Sirius Radio Retrofit /// DIY: E39 - Replacement of the Left and Right Firewall Covers
For Sale:
BMW Style 5 17" 2 Piece Wheels And Tires
AGM5 is online now
post #4 of 19 Old 6th September 2013, 04:48 PM Thread Starter
m5racer111
post #5 of 19 Old 6th September 2013, 04:48 PM
gsfent
gsfent's Avatar
Hey everyone,
99% chance new thermostat needed. Go to secret menu and confirm actual temps. #7 water temp, #16 oil temp.
I believe Peake reads a "69" code (could be b9, don't remember).
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, Sachs high performance PP and CCC proprietary clutch disc, stock DMFW, open brake ducts, Hamann front splitters, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, 6k super white low beams, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge, Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup.......
gsfent is online now
post #6 of 19 Old 6th September 2013, 04:48 PM Thread Starter
m5racer111
The only code I had I posted at the top right after your post
post #7 of 19 Old 6th September 2013, 05:41 PM
Hakon
Hakon's Avatar
Check secret menu, anything less than 79c and it's new thermostat time.
I've gotten through two in four years. Get lots of spare associated rubber o rings that seal the three little pipes that go to and from the t-stat. if they pinch and tear in the process, coolant will be lost and you'l have to do it again.
Hakon is online now
The Following User Says Thank You to Hakon For This Useful Post:
gsfent (6th September 2013)
post #8 of 19 Old 6th September 2013, 10:11 PM
m5 deamon
m5 deamon's Avatar
Thermostat
2003 M5 Carbon Black, Black sport interior.
Evolve Alpha N tune, headers,race cats,heads
Rakkiu modified throttle bodies
Schrick cams
e46 m3 oil cooler gulf oil filter housing
Kw v3 with ground control camber plates , Dinan rear sway bar, Beast power brakets
Stop tech st 40 and st22
UUC light weight flywheel 850csi clutch, Evo3 shifter and dssr
Gas mono balls
Rouge wheel studs aluminum lugs
Vorstiner front splitters
Exotics tuning finned diffuser
Euro headlights and taillights with rear fogs
Euro arm rest
40% Lock lsd
m5 deamon is offline
post #9 of 19 Old 7th September 2013, 12:00 AM
DirtyHarry
Why does this happen on some cars that have no thermostat issues?
The two cars I went to see and the one I bought were all like this. My thermostat works without issue.
DirtyHarry is offline
post #10 of 19 Old 7th September 2013, 01:47 AM
HCrawford
Are you certain that your thermostat is working without issue? I had a non-functioning thermostat for about a year before I realized it was an issue. The car ran fine and the heat worked etc., but I kept getting that vague error code #69 "Engine Coolant Temp Plausibility" more and more frequently. ALSO, I constantly had an amazing buildup of black soot on the back of the trunk and bumper. I could write my name in it after just 50 miles or so. Now that I put in a new t-stat and the car is reaching its design temp. that buildup is no more.
Changed tsat and water temp gauge is still not in middle ILOVEMYBEAST E39 M5 and E52 Z8 Discussion 20 11th October 2013 03:19 PM
Idle Speed, Engine Temp and Oil Temp mercutio2511 E39 M5 and E52 Z8 Discussion 27 19th February 2012 11:59 PM
S38 How many degrees is being indicated by the water temp gauge when the needle is in the middle First e28 M5 E34 M5 Discussion 3 16th March 2008 06:07 PM
Engine Temp or Oil Temp? Realtycar E60 M5 and E61 M5 Touring Discussion 1 13th January 2006 01:53 AM
Performance Friction no longer selling temp paint stever E39 M5 and E52 Z8 Discussion 5 14th June 2002 08:04 PM
