Old 6th April 2003, 04:02   #1
Bokke
Bokke's Avatar
Garage: 2005 545i / 6 speed
First timer....
I am going to track the Beast for the first time next weekend at a Drivers Edge event at the Texas Motorsport Ranch and wanted some tips from those that have tracked before me....
I will have the tech inspection on Monday and also having the brake ducts opened from the front air dam.
What advice or tips does eveyone have for me?
As always the advice and info that is given on this board is truly appreciated
Philip
01 TiSilver/Black
02 X5 3.0i Steel Gray/Black
Bokke is offline
Old 6th April 2003, 06:36   #2
glowrider
Garage: CL 63, S550, Cayenne
Drive out of the garage the same way you drive in Have fun! And don't do anything you're not comfortable doing.
glowrider is offline
Old 6th April 2003, 06:38   #3
DZeckhausen
DZeckhausen's Avatar
Garage: 2001 540i 6-Speed, Alpine White
Send a message via AIM to DZeckhausen
Re: First timer....
What brake pads are you using? Have you replaced your brake fluid recently with some fresh, high temperature stuff like Motul 600? Have you done any sort of motorsports before (e.g., autocross) or are you totally new to this?
Dave Zeckhausen
Owner, Zeckhausen Racing
2001 540i 6-Speed
M5 Front Swaybar
Dinan Stage 3 Suspension
Dinan Front Strut Tower Brace
European Dash Conversion
CDV Deleted (of course!)
Bluetooth, NAV-TV, DVD Player
2006 Chrysler 300C SRT8 w/StopTech ST-60 front/ST-40 rear BBK
2007 Corvette Z51 Coupe 6-Speed w/StopTech Trophy ST-60 front/ST-40 rear
2009 Honda Fit Sport w/NAV w/Acura Integra front calipers, StopTech floating rotors on order
DZeckhausen is offline
Old 6th April 2003, 07:04   #4
Bokke
Bokke's Avatar
DZeckhausen - have the original brake pads, having a brake flush and oil change on on Monday.
I have autocrossed a couple of times with BMW but never in my own car.
I'll have to ask about Motul 600.
Thanks,
Philip
Bokke is offline
Old 6th April 2003, 07:10   #5
DZeckhausen
The odds are not very good that you'll find Motul 600 on short notice. But you might be able to find ATE TYP 200 or ATE Super Blue Racing brake fluid. It boils 50 degrees sooner than Motul, but it's still better than most other fluids.
When you come off the track after a bunch of hot laps, be very careful not to leave your foot on the brake pedal while sitting in the pits. The rotor will be very hot and you will imprint pad material onto it, causing a vibration problem and possibly ruining your rotors. It's very easy to forget about this during the adrenaline rush of your first track event.
How many miles on your brake pads? If there isn't much material left on those pads, you can easily burn through them in a couple of 30 minute lapping sessions.
Dave Zeckhausen
2001 540i 6-Speed
M5 Front Swaybar
Old 6th April 2003, 07:59   #6
greg
greg's Avatar
Garage: 2000 Anthracite
Another suggestion - start with DSC ON. See where on the track the yellow light blinks - and try to work on being as smooth as you can, to go as fast as you can through those sections WITHOUT the light blinking. This is a GREAT teaching aid. If the light is blinking a lot, OR AT ANY TIME YOU'RE NOT in a corner-exit section (meaning it is probably arresting an impending yaw event, as opposed to merely ******ing tire slip under heavy acceleration) you are probably not predicting the car's limits well enough and/or being smooth enough. Once you are being smooth enough and in particular feeding the throttle in smoothly enough on exit to keep the light from coming on while still getting as much power down as possible, you will have the "feel" you need to (if you want) turn DSC off safely. You'll find you CAN put more power down with it off, but if you're not "close" in your technique to begin with, the car could surprise you, and it just isn't worth risking hurting the Beast. If you are smooth, though, the car is very predictable and easy to control.
greg is offline
Old 7th April 2003, 01:59   #7
Bokke
Bokke's Avatar
Thanks Greg very useful information, I was not sure if or when I would turn the DSC off.
Thanks again
Bokke is offline
Old 7th April 2003, 02:31   #8
Richard in NC
Richard in NC's Avatar
Garage: 2008 BMW 550i
I just did my second track event in my M5 last weekend. I echo others thoughts on the high temp fluid and the brake ducts. This should be fine for a first session and on steet tires. You'll learn that quick hard braking is better than long easy braking and this will make your brakes last much longer. One other thing, try to find a level spot to park after a run and don't use the parking brake.
Also, check tire pressures before the first run. I set mine to 40 front and 40 rear cold. This helps balance the handling of the stock set up. The M mobility kit is handy at a track for giving the tires a bit more air.
I used DSC only half my first session since I had been to that track before. The next morning during the rain it was on ALL the time. I was able to push the car a bit, feel the traction limits, and easily out corner the Mustangs and older 3 series in my group. DSC only needed to really kick in a few times to control the car but it was a great safety net.
Richard
NEW 2008 550i Space Gray, Creme Biege/Black/Dk Poplar : Sport Package, Cold Weather, Sport Auto, Nav, HUD, CA, Logic 7, iPod/USB, SAT, HD Radio, Lane departure warning
'06 X3 Black Sapphire/Tan PP, Steptronic, Xexons, Heated seats, Privacy glass, UGDO, Compass, bike rack, iPod adapter
Sold '06 650i Black Sapphire/Cream Beige sport package, 6 speed
'02 M5 Titanium Silver/Black Luxury/Burl
Richard in NC is offline
Old 7th April 2003, 11:47   #9
MIB
MIB's Avatar
Garage: 03 M5 Steel Grey/Petrol-LMB/Ti
Send a message via Skype™ to MIB
Hey Bokke, I am sure you will enjoy your event.
I'd try 42.5 in the fronts and 37.5 in the rears just for a fine tune of decreasing understeer.
MIB is offline
Heater/Vent timer on OBC plisken E34 M5 Discussion 8 19th December 2003 14:53
My visit to the Old Timer Grand Prix on the 10th of August raymondw Regional Forums and Events and group meetings for M5, M6 and Alpina owners 2 26th August 2003 01:05
Stowatch and Timer Roton E39 M5 and E52 Z8 Discussion 2 27th April 2002 01:02
Turbo timer for M5 tfung E39 M5 and E52 Z8 Discussion 2 12th July 2001 04:52
Page generated in 0.16168 seconds with 11 queries
